Old 08-18-2004, 08:35 AM   #6856
Send a message via ICQ to Mugen Power
haha...still mtx-3....
haven't try the sharf carˇI
How about you?you haven't go to rcmodel?
NTC-3 now have many membersˇI
Mugen Power is offline   Reply With Quote
Old 08-18-2004, 08:35 AM   #6857
Originally posted by Rookie Solara
Yes....how could I forgot....and THANKS for your information.
I am going to get a used one to try cause I want to slap the 22/29 for more speed....LOL
Thanks.......
Are you still MTX3 or already jumped onto the FT NTC3 wegon?
http://www.rcmodel.com.hk/lb5000/top...tart=36&show=0
i think this post may helpful!
Old 08-19-2004, 06:51 AM   #6858
I use 35/35 shore Jaco, but the traction on our tracks is low. They only last 1 event, 30 min.
CTurbo is offline   Reply With Quote
Old 08-20-2004, 08:41 AM   #6859
Registered User
Send a message via AIM to bbntc3
Originally posted by The Black Kat
What did you find works better on your NTC3? 42/42 or 40/40
I'll be running on VHT-treated tracks...DIZZIALED!
40/40
bbntc3 is offline   Reply With Quote
Old 08-20-2004, 12:27 PM   #6860
Thanks....I'll order some more tires before next Nitro season. Theres only 2 more races for me (and I'll probably only make 1) I'll probably try a one-way next race to see how it handles
The Black Kat is offline   Reply With Quote
Old 08-20-2004, 02:56 PM   #6861
Try 42/40 shore tires, with a 21/27 and 48/54 gearing setup.
-Dust
Dust is offline   Reply With Quote
Old 08-20-2004, 06:57 PM   #6862
wild gopher's Avatar
Trader Rating: 39 (100%+)
or even 42/37. That seems to work for me. I also choose Mono for my NTC3 since they grip nicely and dont chunk as easy
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 08-20-2004, 07:57 PM   #6863
Default mtx3 clutch in tc3
rookie solara,
i did this conversion it will work but you need the ld3 motor mounts.also the flywheel will be very close to the brake disc.too close for me actually,i took some material off the flywheel in a lathe.it also puts the motor very close to the fuel tank.its too bad the k factory one cant use the same gears as mugen,serpent,ofna.it will work but its tight.check nitro house for the ld3 one its alot cheaper than the mtx clutch and its exactly the same.hope this helps.
morpwr is offline   Reply With Quote
Old 08-20-2004, 09:19 PM   #6864
teammpp's Avatar
Found these while surfing through ebay for those elusive bargains. Thought you guys might be interested. Look real good.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5916362570
teammpp is offline   Reply With Quote
Old 08-20-2004, 09:23 PM   #6865
Number 11's Avatar
He only has one set for sale and feedback is not that good. I wonder where he got them from?
Number 11 is offline   Reply With Quote
Old 08-20-2004, 09:28 PM   #6866
revzalot's Avatar
Default Tire Truing
Anyone true their tires. What camber do you true the fronts or the rears? Any good articles on this subject?
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 08-20-2004, 09:40 PM   #6867
Registered User
I would like to learn more in this area of truing. I think I can cut about 3 degrees camber with my machine. Never tried it yet, and No one seems to want to help with setups in this area. So if I was too true foams with like 2 camber, would I set the car up with 0 camber or use the same camber?? This is an interesting subject anyone have an experiences with this?? BB
Old 08-20-2004, 09:50 PM   #6868
Registered User
If none or not much results from the one way put a solid in the front and back the rea diff off to 1/4 to 1/2 and see if you like it. I would reccomend going to the mip shiny cvds. with the solid it eats the stock blue cvds with modded HP. The shinys are heavy but you won;t spin one out in a main like the bue ones. With our track configuration we shaved alost a full second off lap times and 2 to 3 extra laps in 5min mains with the solid. BB
Old 08-20-2004, 09:52 PM   #6869
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
here..I found this while bench racing....
http://www.mytsn.com/publ/publ.asp?pid=2665
http://www.mytsn.com/publ/publ.asp?pid=4328
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-20-2004, 09:56 PM   #6870
revzalot's Avatar
Thanks good buddy!
