Old 05-24-2004, 07:34 PM   #6331
Speedydave- My pit partner runs a MTX3 and it is a good car, but I really like the NTC3 either car will break if you are hitting walls or other cars so you must learn to drive clean, this will also help with lap times more than anything else.
If you have good access to parts I say go for the NTC3. If money is a concern get a used team car and put on the new V2 suspension and you are ready to go.
A good set up and clean driving will get you ahead of 70% to 80% of the guys at any track with any good out of the box kit. The used car I bought had been raced for two years buy a guy at our track and he had never done better than mid pack in the B-main. I took his used car and motor rebuilt every part and put a good set up on it and put it in the middle of the A-main, he was in the C-main with his new MTX3 and Turbo 3 port motor.
Speed is about clean/smooth/consistent driving with a good setup.
FFR3582 is offline   Reply With Quote
Old 05-24-2004, 08:46 PM   #6332
nitrodude's Avatar
I runed the NTC3 for a year and let me tell you, its not as weak as people make it out to be. Back then I used to run on a board track only. We were 4 guys running the NTC3 and we pitted together, and between the 4 of us the cars saw major crashes and they kept on going.
Heres a pic of wher I sued to run
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-25-2004, 12:36 AM   #6333
Niklas Edlund's Avatar
Default Team kit V2 available
Originally posted by speedydave
However, I have a few questions. I know the updated version of the RTR as well as the FTNTC3 kit have the V2 suspension, but when will AE make the V2 rear suspension a running change for the standard kit?
The new #2034 & #2035 Team kits with V2 rear suspension are available:
http://www.rc10.com/shusting/Catalog...c3/kitntc3.htm
Niklas Edlund is offline   Reply With Quote
Old 05-25-2004, 07:39 AM   #6334
nitro rookie's Avatar
does anyone know what the part number for the Yokomo front oneway for the NTC3. Thanks
nitro rookie is offline   Reply With Quote
Old 05-25-2004, 10:55 AM   #6335
jasoncsc's Avatar
Default K-Factory fuel tank
Hi,
Has anyone tried the K-Factory fuel tank? Wonder if its any good....
jasoncsc is offline   Reply With Quote
Old 05-25-2004, 11:07 AM   #6336
jrabbito's Avatar
I assume that you mean the low profile K factory tank? Yes I have run with it. Hard to compare though because I have never run th e original. All I can say is that it has taken a couple of hits and is OK. Looks ALOT better also.
jrabbito is offline   Reply With Quote
Old 05-25-2004, 12:18 PM   #6337
ade
ade's Avatar
Trader Rating: 22 (100%+)
Default Re: K-Factory fuel tank
Originally posted by jasoncsc
Hi,
I think this is a good tank. I run one....It has a built in fuel filter. I added a piece of foam between the pipe and the tank to absorb the blow in the case of an impact. It worked well.
ade is offline   Reply With Quote
Old 05-25-2004, 02:43 PM   #6338
Registered User
Send a message via AIM to bbntc3
I also use the K- Tank, I have used it since it first came out. I only thing I dislike is the fact it leaks fuel around the fill lid. When running the car hard I guess the pressure is higher and it seeps around the seal. A stronger spring would be nice there.
bbntc3 is offline   Reply With Quote
Old 05-25-2004, 07:35 PM   #6339
YSP
YSP's Avatar
Stripped 2 speed clutch housing
can anyone suggest how to overcome this problem.The area concerned is the hole where you put in the screw to attach the spur gear.I think the material for the housing is too soft.Is the any hardened clutch housing available.
So far I've lost/stripped 2 spur gear.
For a temporary remedy I use a bigger screw found in my toolbox.Hope that it works.Have not run on the track yet.
YSP is offline   Reply With Quote
Old 05-25-2004, 07:57 PM   #6340
tallyrc's Avatar
the real question is when is the full carbon upgrade kit gonna be available for the v2.
tallyrc is offline   Reply With Quote
Old 05-25-2004, 08:07 PM   #6341
YSP
YSP's Avatar
Casualty count
Having a FT NTC3 for the past 1 month, here are the list
1) Two 2nd spur gears - due to (3)
2) One rear shock tower -running without body shell
3) One 2speed clutch housing - stripped screw hole
4) Two pivot ball - bent- Left front upper + lower
hopefully the list will stop there.
What are the other parts there are prone to breakage apart from the normal wear+ tear.Dont tell me to drive like a tortise..Your inputs are much appreciated
Old 05-25-2004, 08:16 PM   #6342
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
I use to have a NTC3, and odds are you're gonna buy alot more than that. We went through drive pinions & ring gears like crazy.
Goodbye AE... Hello HPI!!!
Nrctc3 is offline   Reply With Quote
Old 05-25-2004, 09:44 PM   #6343
tallyrc's Avatar
i just don't get it, i have now had 2 ntc3's and run them since i got my first, the week they came out! i have now broken like 3 parts and 2 of them were when i was flat rammed by an hpi super nitro. there are atleast 8 in our club and they are the cars that DON'T give peole problems. how are you guys tearing these things up?
Old 05-25-2004, 09:46 PM   #6344
tallyrc's Avatar
Old 05-25-2004, 10:31 PM   #6345
rpmmaxxed's Avatar
Send a message via AIM to rpmmaxxed
I think that talle wants an answer.
rpmmaxxed is offline   Reply With Quote
