Old 04-21-2004, 05:56 AM   #6151
alucard13's Avatar
Originally posted by clarkrw3
Just picked up my FT NTC3 today.....have much building to do. What do you think of the BMI chassies...and also a Rossi engine?
Also if any of you have any suggestions of pointers on the build feel free to give your .02
Thanks All
I have the BMI chassis (V1) and it is really good. I have since switched to a Mugen MTX-3 since alot of the people I race with have switched.
alucard13 is offline   Reply With Quote
Old 04-21-2004, 07:18 PM   #6152
Default version 2
has anybody found a starting setup for the version2,if so could you post it.i just got my new rear pieces and all the mounting points are totally different,shocks,camber link,everything.
morpwr is offline   Reply With Quote
Old 04-21-2004, 08:53 PM   #6153
soc123_au's Avatar
R/C Tech Charter Subscriber
I set mine the same as version 1, 2nd place in the A first time out, at a track I had never raced before. Seemed to be fine.
2 deg rear toe in, 3 deg rear camber, 6 droop & soft springs & 25 oil, 5.5mm ride height all round. front 2 deg camber 1 deg toe out
4 droop & same oil & springs as rear. This was on a bumpy low traction track with a nice mix of tight & open sections. I also ran the one way & 35 tyres all round (foam nitro shoes)
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 04-21-2004, 09:55 PM   #6154
spawn's Avatar
congrats man!, Are there many who run NTC3 in your location? I am testing the lowest rear arm position on the new V2 shocktower. Hopefully it works for me.
spawn is offline   Reply With Quote
Old 04-22-2004, 01:04 AM   #6155
Originally posted by jwf_frani
heres a clutch made by yokomo that is made for the
ntc3 it has the same specs as the mugen clutch but
the clutch bell is spaced alittle different to make it a
direct bolt in.
Where exactly did you find this?
Or the mugen clutch for that matter, can't seem to find either
Skoob is offline   Reply With Quote
Old 04-22-2004, 01:10 AM   #6156
InitialD's Avatar
At the yokomousa website?
Old 04-22-2004, 04:15 AM   #6157
Default mugen clutch
you can get the mugen one at mitro house for about 50 dollars,motor mounts also if they have them (about 15 dollars).i just got mine this week and the ld3 2 speed so i can use the .8 gearing.if you buy the trinity one you are stuck using the gears they offer only.hope this helps you out.
hey guys how about the camber link position as this makes the roll center,thats what i really want to know.any shims on the carrier?
Old 04-22-2004, 04:30 AM   #6158
spawn's Avatar
Default Re: mugen clutch
you mean that you are using the mugen clutch on the NTC3 with LD3 pinions?
Higher inner camber link = lower RC.
Old 04-22-2004, 04:35 AM   #6159
InitialD's Avatar
Default Re: Re: mugen clutch
I believe he means Mugen 0.8 pinions with LD3 spurs...
Old 04-22-2004, 05:24 AM   #6160
soc123_au's Avatar
Not too many NTC3s getting around in AU, Everyone here is either a Mugen or Snake lover with a handfull of RRs & FWO5s.
I run it because I have been an AE fan since getting my first RC10 in 1991. I only know of one other V2 in AU at the moment, at least in Sydney anyway. The V2 I think is a big improvement, mainly no rear links to pop off. I dont understand all of the tuning options it offers like roll centre etc. Any more than the basics, shocks, caster, camber, toe & droop & I get a bit lost. I am trying to organise one of the pro guys to hold a setup night to explain all that stuff to some of the guys at my club that are ready to move up to the next level.
Auswide Hobbies
JPM Racing
Old 04-22-2004, 07:37 AM   #6161
Yea i looked there, couldn't find the exact one, but i tihnk i did find it..
What do you guys think of the K-factory centax clutch?..
Old 04-22-2004, 08:28 AM   #6162
Trader Rating: 16 (100%+)
What is the real advantage (actual advantage) of having a centax on NTC3..? I have seen quite a lot of centax (kawahara and yokomo and 3racings....) they are not any faster, reaction are definitely not faster, launching is not better but definitely heavier.....
At the end they are changed back to 3 shoes or stock 2 shoes with holes at the shoes clutch....
Simple things out sometime is not a bad idea....and isn't it the stock NTC3 is already a somekind of 0.8 pitch gearing already...?
Old 04-22-2004, 10:32 AM   #6163
Guys, I need some info about the FT NTC3 rear upright parts #....please see picture
Can someone tell me what are the screw size or parts # of these screws/nuts....all I need is the factory #...not the master NICK mod parts #.....thanks
Also, what is the parts number for the rear sway bar (the wire one and the black plastic caps....)
THanks again
Old 04-22-2004, 11:10 AM   #6164
Default Can someone tell me what are the screw size or parts # of these screws/nuts....all I
BHCS M3 x 18 with an M3 lock nut
Part#'s are: 2308 & 2309 respectively
no4hitter is offline   Reply With Quote
Old 04-22-2004, 01:07 PM   #6165
Default Re: Can someone tell me what are the screw size or parts # of these screws/nuts....all I
Thanks for the quick respond.........again, thanks.
