Old 04-03-2004, 12:43 PM   #5941
Niklas Edlund's Avatar
Default Booty view
Another view, straight from the booty.
Niklas Edlund is offline   Reply With Quote
Old 04-03-2004, 12:45 PM   #5942
Default Head shot
Yet another view of its behind, this time a head shot. If you check the upper link, inner pivot point - that is attached with an M3 screw (yes, you heard me right) but there was of course an normal steel M3 nyloc nut for it. I did my own M3 nut out of an AE 4-40 aluminium locknut (#6937). Just run a M3 tap through the aluminium part of it, but no the nyloc part - hey, an american M3 FT nut... Bling, bling.
Old 04-03-2004, 12:46 PM   #5943
Default Rear hub
Side view of the rear hub.
Old 04-03-2004, 12:49 PM   #5944
Default Radioplate
Thought I would leave that alone ? Wrong...! First of all its made in the stiff grey carbon reinforced composite plastic. Personally I like it a lot, I have no clue in why people would like to have it in the normal milled carbon plates... no clue. I like, I like.
Lowering of the battery pack
The normal 5-cell flat battery pack can sit about 2 mm lower. So I made some spacers out of parts of the camber tool that is included in all NTC3 kits (I've never used it anyway). With a big drum-sander in my Moto-Tool I shaped them so they would fit the cells good. See the pix, before (right) and after (to the left). The thickness at their thinnest point is about 2 mm.
Old 04-03-2004, 12:50 PM   #5945
Default No more camber tool
Here's a picture of where I got the spacers from... no more camber tool...
Old 04-03-2004, 12:52 PM   #5946
Default Spacers glued in place
I glued them in place with green Zap CA.
Old 04-03-2004, 12:54 PM   #5947
Default S9550 as throttle / brake servo
The throttle servo I will use is the low-profile digital Futaba S9550. That can be lower just a little by grinding down the servo posts on top of the plate. If you choose to use it also, dont remove all material flush with the plate leave about 1 mm, otherwise one of the radiobox 2-56 screws will interfere with the servo rubber. I recon the car will be too light with all of the graphite stuff on it, so I plan to mount the extra needed lead weights under the S9550 throttle servo.
Old 04-03-2004, 12:55 PM   #5948
Default S9350 / S9451 as steering servo
I know, a Futaba digital S9350 would be concidered even by Pro's to be a tad over-kill for an FT. Thats more like a perfect 1/8 off -road servo. But again, I recon the car will be underweight so why not? It has an aluminium waist-line and all. A Futaba digital S9451 would be a more sane choice... Of course I recomend you to use the optional FT aluminium steering mounts (#1779). Use some blue loctite on the screws.
Old 04-03-2004, 12:57 PM   #5949
Default Starts to look like a car
Here's a picture of the car with the battery pack and plate mounted on the car.
Old 04-03-2004, 12:58 PM   #5950
Here's another view.
Old 04-03-2004, 12:59 PM   #5951
Straight from the right - here you also can see that while I thinned down the handle-bar I also remoived some material on the inside edges of its holes...
Old 04-03-2004, 01:01 PM   #5952
Straight from the left. BTW, I used some aluminium 2-56 button head screws to attach the radio box to the plate from www.fastener-express.com - just for a bling, bling factor. Done wrenching for now...
Old 04-04-2004, 03:48 AM   #5953
Niklas, what was the exact rpm bumper you were talkin about? was lookin for it the other day and dint know which you meant..
edit: this one?? ->http://www2.towerhobbies.com/cgi-bin...?&I=LXCRU0&P=7
Skoob is offline   Reply With Quote
Old 04-04-2004, 04:06 AM   #5954
Skoob: what is it U wanna do?
If you're buying any of the newest Version 2 NTC3 cars, the new wider one is included. See the attached picture. This is the partnumber for that one.
AE #2223 - Front bumper wide (replaces booth the AE #2232 and #2226) - 8 USD
The optional RPM bumper is for the "old" car. It replaces the original AE "kydex" flat bumper that is #2232. The original one (2232) brakes very easy and I doubt it does any good at all, except braking... All of those are to be used with the 3 original rubbers and the foam bumper.
So if you wanna buy an optionalpart - go for the RPM one.
If U dont think it does any good at all (like me), make an thin 1/4 foam spacer (as I showed earlier) and remove it completely.
Or if U want to buy the new AE wide bumper buy the AE #2223. All of them uses the original foambumper also... Hope it helped.
Old 04-04-2004, 04:30 PM   #5955
I've got the v1 car, not the ft..
so then i should just get the rpm bumper since the one i've got doesn't do anything really?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
