Old 03-16-2004, 04:13 PM   #5821
Default Fix images
Originally posted by Jeff Werner
Info and pics of the "FIX"are here at this addy: http://www.bmiracing.com/products2.htm
Jeff
Here pictures of the fix too : http://shop.the-border.nl/customer/p...42&cat=&page=1
herb is offline   Reply With Quote
Old 03-16-2004, 04:54 PM   #5822
alucard13's Avatar
Default Re: Re: Problems with tranny
Originally posted by cow buster
A bit contradictory message you put up there. U say the car picks up - does that mean the car is running? If it is running how can you tell if the shaft stop moving? If you are holding the car and reving it, and the shaft don't move and your pinions are moving then it means your front and rear diff are not screwed in properly. The manual set up is front diff 1/4 turn and rear 1/2 turn. If your car moves very slowly at high rev then it confirms that your diffs are not screwed in properly. If the standard set up don't work that means your spring is out of whack so you need new springs
I was driving it up and down my street and noticed that even though i was pressing the throttle nothing was happening. so i went over to the car (which had stopped by this time) and started reving it up and thats when i noticed that the pinion and spur gear was moving, but nothing else (shaft, wheels.) I have done rebuilds before and this is the first time it has done this. I also held it up off the ground and it did the same thing. I will take it apart and start from scratch then. thanx for the help.
alucard13 is offline   Reply With Quote
Old 03-16-2004, 08:27 PM   #5823
Registered User
Send a message via AIM to bbntc3
The oneway brg is out of the two speed guys.
bbntc3 is offline   Reply With Quote
Old 03-16-2004, 09:57 PM   #5824
A buddies car did the same thing last weekend. Took the one way out, cleaned it, lubed it, put it back in, works fine now.
nitromike is offline   Reply With Quote
Old 03-17-2004, 07:49 PM   #5825
Default 2-spd problem
It sounds like the problem that I had. I was setting the car up for a short track that does not need the second gear. I did not have it adjusted right. When I would be driving the car would "slip" and I would not go anywere in the middle of a race. When the rpms came back down it would go again for a while.
squeeker138
squeeker138 is offline   Reply With Quote
Old 03-17-2004, 07:59 PM   #5826
alucard13's Avatar
I will check my hobby store later this weekend for one. is there a particular part number or just ask for a one way brg for a NTC3?
Old 03-17-2004, 08:03 PM   #5827
Default 2 speed one-way bearing hub
Part# 2288
no4hitter is offline   Reply With Quote
Old 03-18-2004, 07:44 PM   #5828
alucard13's Avatar
Default Re: 2 speed one-way bearing hub
Originally posted by no4hitter
Part# 2288
Thank you for the info
Old 03-19-2004, 10:24 AM   #5829
Niklas Edlund's Avatar
Default New updated Nitro TC3 V2 info
The first Factory Team kits are now here and it seems AE miss informed us slightly earlier regarding part numbers for the V2 suspension etc. This is the right info + some news!
2238 - Rear suspension arms V2 - 5 USD
2339 - Rear suspension arms V2 carbon - 11 USD
2237 - Rear shock tower V2 - 5 USD
2327 - Rear shock tower V2 carbon - 7 USD
2268 - Rear hub carrier V2 - 5 USD
2336 - Rear hub carrier V2 carbon - 7 USD
2283 - Turnbuckle .825 steel - 5 USD
1418 - Turnbuckle .825 titan - 8 USD
2271 - Rear turnbuckle eylet and ball set V2 - 7.5 USD
2275 - Lower suspension arm mounts front & rear V2 - 5 USD
2319 - Suspension upgrade set V1->V2 - 35 USD
2342 - Complete carbon set V2 (same as 2371 but that is for V1) - 67.99 USD
2223 - Front bumper wide (replaces booth the 2232 and 2226) - 8 USD
Complete NTC3 car line up 2004:
2033 - Nitro TC3 Factory Team kit (V2) - 599.99 USD
2034 - Nitro TC3 Team kit for pull-start side exhaust (V2) - 459.99 USD
2035 - Nitro TC3 Team kit for non-pull-start rear exhaust (V2) - 469.99 USD
2042 - Nitro TC3 RTR-Plus (V2) - 559.99 USD
Niklas Edlund is offline   Reply With Quote
Old 03-19-2004, 02:07 PM   #5830
racer-oZ's Avatar
R/C Tech Charter Subscriber
Are you saying that your hobby shop has received the first kits?
racer-oZ
racer-oZ is offline   Reply With Quote
Old 03-19-2004, 02:24 PM   #5831
I just checked....Hobby store just received shipment...Limited supply tho.
Old 03-19-2004, 03:10 PM   #5832
Yes, the first #2033 kits arrived today. Not the carbon parts though. We only noticed these partnumbers when opened the 2033 box. The earlier mentioned # numbers (from AE) where for the upcoming new standard V2 kits and RTR-Plus that doesnt have the carbon versions as in Factory Team Nitro TC3 #2033.
Old 03-19-2004, 04:42 PM   #5833
racer-oZ's Avatar
What hobbyshop? Any left?
Old 03-20-2004, 02:26 AM   #5834
Wholesale distributor - not in the US either... sorry.
Old 03-20-2004, 06:45 AM   #5835
racer-oZ's Avatar
