Old 01-15-2004, 02:12 AM   #5671
highwayman's Avatar
Default Re: Re: Re: advantages of one way diff
Originally posted by thefuzzclub
thanks for the reply misterntc3.
is there a AE solid diff? what part should i replace and buy?
Pitshop has a solid axle in stock... if you get the axle, just put in a bevel gear and replace the stock diff...
I really wouldn't recommend the solid axle... puts too much strain on your drive train, i would just rather have a really tight front diff as a good compromise.
highwayman is offline   Reply With Quote
Old 01-15-2004, 02:21 AM   #5672
thefuzzclub's Avatar
Default Re: Re: Re: Re: advantages of one way diff
well noted with thanks.
thefuzzclub is offline   Reply With Quote
Old 01-15-2004, 02:04 PM   #5673
Ducati998's Avatar
HI!
Ducati998 is offline   Reply With Quote
Old 01-15-2004, 02:55 PM   #5674
Registered User
Send a message via AIM to bbntc3
The NTC3 diff with the friction ring can't be tighten down to lock it , like a solid, no matter how tight it is, it will still slip some. If you feel the need to have a locker, use the electric TC3 diff in the front it does'nt use the friction ring. AE will tell you it won't hold up but this is just BS, we used the electric diff in the NTC3 for a long time with no failures.
bbntc3 is offline   Reply With Quote
Old 01-15-2004, 03:23 PM   #5675
Very True. I tried tightening the diff but it just works loose. If you have not tried a locked diff i strongly suggest you do. Ignore what some people say about the drivetrain not being able to take it. I wonder whether these people have even tried it. As i said i have tried locked front and rear as well as 1 ways and i have never had a single problem. I'm not trying to start an argument it's just that people say that the NTC3 cant do this can't do that as it isn't strong enough, it's no wonder this car has a bad name as far as strength. Give it a go if it doesn't work it's not the end of the world
misterntc3 is offline   Reply With Quote
Old 01-15-2004, 06:15 PM   #5676
Send a message via AIM to Johnnytc3
Mister,
ive always been a fan of the solid, thats all i run in my elec tc3, do you have a good setup for the ntc3 with a solid on asphalt?
thanks
johnny
Johnnytc3 is offline   Reply With Quote
Old 01-15-2004, 08:26 PM   #5677
If I put in a solid axle in the rear, what will that do for me?
I have a Front one-way also.
- Dust
Dust is offline   Reply With Quote
Old 01-15-2004, 09:38 PM   #5678
Registered User
delete
Old 01-17-2004, 06:31 AM   #5679
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Just to clear it up, you are using the guts from the ETC3 and the outdrives from the NTC3 right? The outdrives from the E aren't long enough to use in the Nitro I don't think.
Jon
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 01-17-2004, 11:18 AM   #5680
Old Skool's Avatar
Maybe I'm missing something here, but what is the advantage of a solid front axle on a 4WD TC? I usually set up my NTC3 like a 1/8th scale on large tracks (solid rear, one-way front).
Old Skool is offline   Reply With Quote
Old 01-23-2004, 03:05 AM   #5681
ntc3 racers,
where are you?
Old 01-23-2004, 09:50 AM   #5682
crashed_1's Avatar
ntc3 racers,
where are you?
We're here...tadaaa!!
crashed_1 is offline   Reply With Quote
Old 01-24-2004, 01:20 AM   #5683
InitialD's Avatar
Ummm, are you sure the car still exist?
Old 01-24-2004, 03:03 PM   #5684
I guess there is no more things to talk about. Hey, what are the cheepest foam tires that you guys can find?
- Dust
Old 01-24-2004, 04:21 PM   #5685
TOEBSTER2's Avatar
GQ foams for nitro touring are the cheapest I've seen. The new ones for this year are on an orange mesh wheel , but cheap if you're burning up a set in weekend.
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
