Old 12-15-2003, 11:18 PM   #5566
highwayman's Avatar
Originally posted by torchedlh
hmmm i seem to have a bad case of torque steer right now. whenever i gun it, my ntc3 pull left pretty hard. i've tried tightening the front diff way down but it doesnt' seem to help. something i can do with the rear diff?
number cause of torque steer... tweak, your car is improperly tweaked...
... check first if all your shocks are still ok. (no leaks)
... adjust tweak
another reason for a slight torque steer, the rear of the car dumps to much weight on the rear, i replaced my red springs (rear) to copper and raised ride height by .5mm to compensate.
... just a couple of suggestions.
highwayman is offline   Reply With Quote
Old 12-16-2003, 12:11 AM   #5567
torchedlh's Avatar
Send a message via AIM to torchedlh
i've reset the tweak to factory settings (4 in the front, 3 in the rear). i also set the ride height to the stock setting all the way around. not sure about my shocks leaking tho... i'll have to take a look.
torchedlh is offline   Reply With Quote
Old 12-16-2003, 01:46 AM   #5568
highwayman's Avatar
kinda hard to explain tweak, but 4 and 3 are droop settings, not tweak, there is no factory setting for tweak.
(also, aside from my droop screws, i try to have the same shock lengths equal.)
... tweak is more of "balance" like when a portion of your car is heavier (example... rear left, where the engine is, ) tweaking you're car is the process by which you must compensate for this, so that you'll still have a level chassis. (i.e. by direct tweaking, you put more preload on the rear left shock, indirect tweaking, putting more preload to the front left shock, and remove the same amout of preload to the right front shock.)
You can check the tweak either by an MIP tweak station or just by lifting the center of the chassis and looking which tire leaves the ground first.
there are other articles you can look for to help explain tweak better.
Old 12-16-2003, 03:10 PM   #5569
Registered User
Send a message via AIM to bbntc3
Since you guys are on the tweak subject. I used a laser tweak board and a MIP tweak station. Other than using 4 seperate scaling system I have found this Integy tool to be of some better use than balance beams.
http://integy.automated-shops.com/cg...33103198664.8f
bbntc3 is offline   Reply With Quote
Old 12-16-2003, 08:38 PM   #5570
highwayman's Avatar
i agree, i find that the tweak station is a better alterenative to the scale system.
Old 12-17-2003, 07:08 AM   #5571
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
If you can afford the scale system that is the most accurate. The Tweak Station is a lot easier to transport to the track though. But you do want to get all four tires to have the same amount of pressure somehow.
Jon
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 12-18-2003, 10:34 PM   #5572
Just got my new ntc3. Anyone got any tips for problems I might see during building?
Shawn Plume
www.pmhobbycraft.ca
Frantic Racing (Est. 1988)
Ophidian is offline   Reply With Quote
Old 12-19-2003, 05:11 AM   #5573
Hi all
nice to see the ntc3 thread is still hanging in there - pun intended
I still race mine
fiasco is offline   Reply With Quote
Old 12-22-2003, 01:09 AM   #5574
Mercury Racer's Avatar
Just follow the manual exactly, and you shouldn't have problems. the kit settings work ok.
Mercury Racer is offline   Reply With Quote
Old 12-22-2003, 01:34 AM   #5575
spawn's Avatar
you might want to get the FIX for the shock towers and maybe some 4-40 1/2 to replace the 3 shock tower bolts for the front and rear. Also polish the hinge pins and pivot balls till shiny for freer movement.
spawn is offline   Reply With Quote
Old 12-22-2003, 04:16 AM   #5576
... yep, u need the FIX and an RPM front bumper, the stock one doesnt work.
Old 12-22-2003, 08:15 AM   #5577
Send a message via AIM to Bobby Flack
Lifting the car up at the center and watching how far the tires lift is "Droop" not a method of setting tweak. For tweak you have to use a balance beam or scales or make darn sure all the shocks are the same length and the spring collars are all in the exact same place, of course this does not show any weight bias problems.
I had problems with the one-way until I started using the Serpent oil, not much of it though.
Ted
Bobby Flack is offline   Reply With Quote
Old 12-22-2003, 09:32 PM   #5578
Originally posted by spawn
you might want to get the FIX for the shock towers.
What's this FIX for the shock towers? And thanks for the other info everyone.
Shawn Plume
www.pmhobbycraft.ca
Old 12-22-2003, 09:46 PM   #5579
Registered User
I have The fix and the Rear Jam nuts in a kit form, 1 kit does the whole car $25 shipped in the US. Email me
The fix uses the other 2 holes in the diff cases. Keeps the shocktowers tight on the car. Loose shocktowers is common with this car.
Old 12-22-2003, 09:58 PM   #5580
What company makes the fix?
Shawn Plume
www.pmhobbycraft.ca
