Old 11-19-2003, 06:41 PM   #5491
thefuzzclub's Avatar
Originally posted by Boomer
without knowing anything else, I would suggest:
It sounds like you need a bit more weight transfer to the front (upon entering a corner)
First - go to the stock 9deg caster (I never touch this. . .try to work around it)
then I would try these (one at a time, see how each works)
Lower your RH a mil in the front
go to +1 degree on toe
drop the sway bar
go one step softer on front springs
Just some ideas.
GREAT! i'll try this weekend, many thanks!
thefuzzclub is offline   Reply With Quote
Old 11-20-2003, 01:18 AM   #5492
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: hey boomer
Originally posted by frank13
hey boomer, can you im me at fcsntjg77.. i have some ntc3 questions for ya ,
is that AIM? I'll try tomorrow (Thursday)
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 11-20-2003, 05:35 PM   #5493
Send a message via AIM to frank13
YES SIR IT IS,
frank13 is offline   Reply With Quote
Old 11-21-2003, 01:11 AM   #5494
Boomer's Avatar
Sorry, Th was bad for me - I had a visitor from Australia that I had to give a tour through my labs and give an orientation on the status of our Academic Computing facilities. . .whew what a pain. Nice guy, but that sucked up most of my day.
Old 11-21-2003, 11:37 AM   #5495
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default shoes cutting into flywheel
has anyone seen this on a Ntc3, the stocks shoes cutting grooves into the flywheel. which is not letting the clutch engage? When I would give my car gas, sometimes the car would not move, I tried to change the two-speed one-way bearing. However the problem reoccured. So finally I took a cut-off wheel for my good-ole dremel, and sanded down the grooves a bit for a temp fix, until I can get to the hobby shop. I will try to get some pics up here soon.
thanks Jason
jscamry is offline   Reply With Quote
Old 11-21-2003, 12:26 PM   #5496
Another quick fix for that problem is to put a small washer between the flywheel and the shoes.
sook is offline   Reply With Quote
Old 11-22-2003, 05:21 AM   #5497
Default Re: shoes cutting into flywheel
[ So finally I took a cut-off wheel for my good-ole dremel, and sanded down the grooves a bit for a temp fix, until I can get to the hobby shop. I will try to get some pics up here soon.
thanks Jason [/B][/QUOTE]
I haven't been on in a while. Need a new pc and they locked out this forum at work . I have 2 engines. One of them I use the crazy nut shoes, and after each day out, I dremel everything down. Even the shoes need some dremeling. With the stock shoes, you can get away alot longer without dremeling. I have yet to find a shim the right size to put between them and the flywheel. I wouldn't want to put something too loose in there.
CHUCKMANDO is offline   Reply With Quote
Old 11-23-2003, 07:19 AM   #5498
JLMG1971's Avatar
Has anyone got the 3Racing 4mm chassis, it looks to me as one of the nicest chassis on the market, please do not answer that the BMI is the best, that is not the question, I just would like to read comments on the 3Racing chassis from people that got one.
JLMG1971 is offline   Reply With Quote
Old 11-23-2003, 08:04 AM   #5499
Registered User
Send a message via AIM to bbntc3
jscamry: The flywheel does not have a hardened surface. If you can get your hands on the K-factory 3 shoe clutch system, it comes with a hardened flywheel. Ae should make a hardened flywheel to cure this problem, but as of now they don't.
bbntc3 is offline   Reply With Quote
Old 11-23-2003, 08:14 AM   #5500
Default do u have a part number
do u have a part umber on teh hardened flywheel,, i am using the kawahara centax right now ,, but id like to have a backup 3 shoe clutch as an incase of problems, not that i have had any i am still on myoriginal thrust bearing for over 4 monthes now ,
hey i know someone was looking for a gh chasis here a while back if you still want one , lt me know ,as i have one used for two or three race for 20 bucks shippedin the us , is scratched underneath --changed cause i am using th rd logics one now,
frank13
Old 11-23-2003, 09:24 AM   #5501
Registered User
I use the K centax and lost 2 thrust brgs this season. I tried shimming it on the loose spec and the tight spec, still had failures. What really sucks is that you can buy the complete clutch setup through alot of places. But theres no parts support of the K parts, only through Trinity at full retail price.
I'm using a special thrust brg we've come up with that seems to last very well.
http://www.kfactoryracing.com/dm.htm
Theres the addy for part #'s. The clutch comes in a kit, and is very hard to get your hands on, unless you order direct from HK. Trinity had a few of them last summer and I manage to get one.
Old 11-24-2003, 03:19 AM   #5502
crashed_1's Avatar
I use the Mugen thrust bearings for my KFacCentax and they work well.
crashed_1 is offline   Reply With Quote
Old 11-24-2003, 02:47 PM   #5503
Registered User
Crashed : Thanks! I'm using a special aftermarket brg that seems to work ok. Do you know of any other parts that will interchange? Here, it's cheaper to buy another clutch, than buy the parts from Trinity.
Old 11-24-2003, 03:18 PM   #5504
Default i heard that too ,
a few gusy at the track use mugen thrust bearings in other k factory clutches, but from what i have heard thats i know of to be interchangable , i am using the kawahara clutch ,, i am not sure whats interchangable between those two ,,
i understand about the whole trinity thing, i do not htink i have one trinity part on my car,
frank13
Old 11-24-2003, 08:35 PM   #5505
crashed_1's Avatar
Ummm..you guys should've already found out abt the gear meshing problems with KFac Pinions right? ie: no 6 tooth jump. Well, I'm currently using a 20pinion from KFac for the G4 with 27 pinion(NTC3) to mesh them up properly and it works.20/27pinions with 48/54spurs.
