Old 10-08-2003, 04:33 PM   #5296
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Thumbs up FOAM TIRES
Purchased many tires from this guy....very good service
http://cgi.ebay.com/ws/eBayISAPI.dll...category=34063
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 10-08-2003, 07:38 PM   #5297
thefuzzclub's Avatar
Originally posted by sook
Spawn, I have used the steel cvd's and came to a conclusion that the stock cvd's are better. I know someone that uses the ae front one-way and he rebuilds his every race, sometimes twice in one day of racing and he is the fastest around our tracks with the ntc3.
i plan to change my stock rtr dogbone to alloy cvd(color blue), are you referring to the team factory cvd's? please advise before i buy. thanks.
thefuzzclub is offline   Reply With Quote
Old 10-08-2003, 08:30 PM   #5298
sbmon's Avatar
i have found the rtr dogbones to be less prone to bending than the blue kit ones , actually i have even used the composite
cvds from the electric tc3 , they held up fine for a few races
when i took them out they were slightly twisted but not bent
it seems like when you get a slight bend in the cvds the outer
hub bearing always goes too, so if you keep blowing outer
hub bearings check for a bend in the cvd
sbmon is offline   Reply With Quote
Old 10-08-2003, 10:31 PM   #5299
noted with thanks.
Old 10-09-2003, 12:38 AM   #5300
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Nuts fix = Camber fix
Hey All, I came up with an idea from the makers of the FIX. I was wondering has anyone tried to put the nut from the toe FIX on the pivot balls that controll the camber, to stop the camber setting from becomming off set. If it would lock similar to the toe FIX, would this not solve the problem of the camber?
Let me konw your thoughts?
jason
jscamry is offline   Reply With Quote
Old 10-09-2003, 07:27 AM   #5301
With my driving style, I am way harsh on the throttle for the electric composite cvd's. I have noticed that the inner bearings blow before the outer bearings when the cvd's have a bend. Good call on that one.
sook is offline   Reply With Quote
Old 10-09-2003, 07:28 AM   #5302
Alloy blue cvd's is what I would stick to for now. So far all the aftermarket cvd's have not held up as long as the alloy cvd's.
Old 10-09-2003, 07:30 AM   #5303
sbmon's Avatar
i have seen this done but
when done in the front the nuts
would very likely bind the steering prematurely
so you could not get full steering throw from the car
and the nuts would not have to be reverse thread
to do this , if you do try this i recomend the most narrow
nut you can find . with really narrow nuts this would
probably work okay
Old 10-09-2003, 07:35 AM   #5304
Default Re: Nuts fix = Camber fix
jason
The most simple solution that has been used in this case is to drill a small hole in the a-arm housing of the pivot balls and insert a set screw to hold the position. Good luck.
ps. no binding of the steering with this fix.
Old 10-09-2003, 09:45 AM   #5305
Boomer's Avatar
Send a message via ICQ to Boomer Send a message via AIM to Boomer
That's what I've done - works great.
and it hasn't seemed to weaken the arms at all - no pivot balls pulling out (in fact, when I've broken one PB, it broke LEAVING the portion that the set screw was touching. . .still got it out though) or arms breaking.
Simplest method is better. . .imho
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-12-2003, 11:03 PM   #5306
to all ntc3 owners,
i need better torque for our technical tight track.
my engine is novarossi s5
dynamite inline pipe (long manifold)
gearing: 21/27(pinion) 48/54(spur)
should i change my gearing to 20/24, 50/54 as recommended ny some or change my pipe to a shorter manifold like the rd logics or ae dual chamber?
your inputs please...
Old 10-12-2003, 11:28 PM   #5307
jscamry's Avatar
Default foam tires
Hey all, I agree with racecar850. I too have bought foams from Tim, the same guy on ebay that sells the nitro shoes and ellegies. It took about a week to reach me in FL from HK, you just cant beat the prices, I plan to order some more tires in a few weeks...
J.
Old 10-13-2003, 02:28 AM   #5308
InitialD's Avatar
Shorter manifold will give you higher rev, not better low end torque. Go with the 20/24 pinions. 21/27 is pretty tall. What track is this? High speed one? You may want to try 20/26 if you need to drive on a long high speed track.
Old 10-13-2003, 02:37 AM   #5309
Smile
its a small track and its technical, more on tight cornering not high speed, just one straight. i was about to buy the rd logics pipe, will try the gearing first, thanks
Old 10-13-2003, 06:40 AM   #5310
johnsoa's Avatar
Default K Factory CENTAX GEARING
Has anyone experienced gear mesh problems when using the K Factory centax with the following gearing:
21/27 pinion with a 48/54 spur
The problem I've experienced is that the diameter of 21 tooth pinion for the K Factory centax is a little too large, causing the gear mesh on the 27 pinion 48 spur to be way too loose. Actually the teeth on the 27/48 barely come together.
Actually the gear mesh problem occurs when using the 21 tooth pinion with in any combination.
I wrote Trinity and anticipate a response soon, Joel is usually pretty good at responding, but just wanted to canvass you guys to see if anyone besides me has experienced this problem.
johnsoa is offline   Reply With Quote
