Old 09-28-2003, 11:44 AM   #5266
InitialD's Avatar
Default Re: K Factory Centax Cluth problems
Originally posted by crashed_1
Here's the scenario...I've got a K Factory clutch which I love very much...I've been using it for 3 months without any problems until recently..The retaining nut for the springs tightens after 1-2 tanks...Asked around LHS and they said to use thread lock on it...??? Do any of you centax users use thread lock for your retaining nut? What's the purpose of having an adjustable clutch if you're gonna lock it down???
Crash, how did you set the Centax clutch? Does the clutchbell have a lot of play when installed?
I think your problem is that the clutch retaining nut is rubbing against the clutchbell which causes the retaining nut to self tighten after a tank or two.
In order to keep the retaining nut away from the rotating clutchbell, you need to put shims between the retaining nut and the normal bearing that goes directly behind the clutchbell.
There are 2 benefits from doing this... Firstly, this may avoid the clutchbell rubbing against the clutch shoe at idle and prevents the engine from stalling. To check, your clutchbell should rotate freely when installed and turned on the engine shaft with the clutchbell upwards facing you. Secondly, your thrust bearings will thank you for this. By putting shims in between the retaining nut and the normal bearing that goes directly behind the clutchbell, you lessen the clutchbell free play you get once installed. This will be easier on the thrust bearing and extends it's life. How many shims? That you need to find out yourself.
The rule of thumb is that the total shim thickness added in between the retaining nut and the normal bearing that goes directly behind the clutchbell must be 0.2 to 0.3 mm less than the end float (i.e. distance of the clutchbell and the clutchshoe). Good luck !
Old 09-29-2003, 12:03 AM   #5267
crashed_1's Avatar
Default Re: Re: K Factory Centax Cluth problems
Thanx Buddy...I knew I could count on you for expert advise...
Hows the snake?...mebbe I should post my distress calls in the Serpent forums for quicker replies...
crashed_1 is offline   Reply With Quote
Old 09-29-2003, 12:06 AM   #5268
crashed_1's Avatar
Originally posted by treky11
I always thread lock mine - always. Unless you run on lots of different tracks most people dont find themselves making lots of centax adjustments. That's the beauty of a good centax.
If you do need to adjust it and its has lock on it. Pop the bell off, make an adjustment and put another drop on thread lock on.
That's what I do.
I think I'm gonna do that on my next time out on the trax. If it works hell I'm gonna stick with the thread lock thingy and have one less problem to worry about.
thanx.
Old 09-29-2003, 12:08 AM   #5269
InitialD's Avatar
Default Re: Re: Re: K Factory Centax Cluth problems
Well, the Centax clutch is pretty generic. Most of the time, its the same method of installation regardless of the brand of the car.
The snake is too good. Besides, you're too deep with the NTC3 ! There's no turning back !
Were you in Titi on Sunday? I went there at about 3 pm and guess what... It rained again ! Really not a productive weekend !
Old 09-29-2003, 05:20 PM   #5270
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally posted by CHUCKMANDO
I know my ball are as tight as can be. I will loosen them up a little amd let you know. Tks
When you have the steering (or toe link) disconnected, it should flop around very freely. When I assemble (or reassemble as the case may be) the carriers, I make sure that the balls are tight, then back off just enough to let them flop around but not have slop.
DON"T overtighten your servo-saver spring. That is actually harmful because it has only ONE effect - it limits the amount of travel the servo-saver can have.
I know the illustration is crude, but it should give a good idea of why it's a bad idea. Essentially, if you tighten the screw all the way down, you have a direct link between steering and your servo and that can be a bad thing. If you are perfect, then you don't need the servo saver, but since Barry runs one, I figure I will too!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 09-29-2003, 06:00 PM   #5271
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default GP doctor
hey hows it going? About the shaft, does harmony model have a web site? As to where we can purchase the shaft??
thanks Jason
jscamry is offline   Reply With Quote
Old 10-03-2003, 10:23 PM   #5272
thefuzzclub's Avatar
this thread really slowed down. i remebered early part of 2003 where i always see this thread always on top of the list. many of the drivers shifted to another car like R40, mtx3, vir evo etc.?
well just a thought since i still have my ntc3 close to year now and liking it a lot.
thefuzzclub is offline   Reply With Quote
Old 10-03-2003, 10:31 PM   #5273
of course Barry runs a servo saver, its probably tightened up though You think? I mean, who needs a buncha push in sweepers and hard corners from the servo saver taking in some of the required torque?
chorner is offline   Reply With Quote
Old 10-03-2003, 10:52 PM   #5274
Send a message via AIM to kreidel
I think pretty much any question you could ask has already been asked....not much to say. Maybe some NTC3 owners can post some pics of their cars and list there setups for some others to view.
kreidel is offline   Reply With Quote
Old 10-03-2003, 11:13 PM   #5275
spawn's Avatar
my tc3 with lola bodyshell
spawn is offline   Reply With Quote
Old 10-03-2003, 11:15 PM   #5276
spawn's Avatar
with stratus 2.1
Old 10-03-2003, 11:26 PM   #5277
Here is one of my NTC3's with a 2.1 Stratus
Old 10-03-2003, 11:28 PM   #5278
Here is another with a Honda NSX body
Old 10-03-2003, 11:30 PM   #5279
2 of my NTC3's naked
Old 10-03-2003, 11:33 PM   #5280
A friendly group pic of Nitro TC3's before the races.
