Old 09-24-2003, 04:49 AM   #5236
hooked_on's Avatar
People,
Do the Kfactory spur gears fit onto the orginal bell housing and how do they compare to the stock gears? I am finding the stock gears are very soft and don't take much to get too a point of needing replacement.
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 09-24-2003, 09:03 AM   #5237
Hey guys, i was getting my ntc3 for this weekend and i found that when the car hits 2nd gear then goes back down to first the engine revs real high with no load. would it be the primary clutch not re-engaging? sorry but i dont run nitro onroad much so im having a tough time figuring this out.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 09-24-2003, 09:08 AM   #5238
Sorry, don't really have an answer to your question Spaz456. I do not have the same occurance with my cars. Where do you race at in Maine?
sook is offline   Reply With Quote
Old 09-24-2003, 09:22 AM   #5239
alucard13's Avatar
Make sure the 2 shoe clutch is clean and doesnt have any oil residue in it. That could be causing it not slip.
alucard13 is offline   Reply With Quote
Old 09-24-2003, 02:32 PM   #5240
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
It almost sounds like the one-way bearing in your two-speed is going out. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 09-24-2003, 08:17 PM   #5241
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
change the one way bearing in the 2 sp..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-24-2003, 08:41 PM   #5242
InitialD's Avatar
Shouldn't it be "K factory pinion gears" instead of spur gears? Anyway, I thought K Factory ones are for their Centax clutchbell?
Try the GH (Golden Horizon) pinions if you can find them. They are much harder. 7076 aluminum if I'm not mistaken.
Old 09-24-2003, 08:45 PM   #5243
Registered User
Send a message via AIM to bbntc3
The K pinions will fit the Ae clutchbells, I use them, they last much longer.
I've had 2 oneway brgs. go out on me in 2 years and both times my car would'nt even move, in first or second gear.
bbntc3 is offline   Reply With Quote
Old 09-24-2003, 08:55 PM   #5244
soc123_au's Avatar
I am after new ends for my shocks, I have RPM ball ends but I cant find replacments for the shocks. My originals are just about RS & I would like to get some sexy blue ones. By the ends I mean at the bottom not the cap. Any help would be appreciated. BTW I got an RB C12 to fit in my BMI Chassis, it kicks A$$. 5th place at the NSW ROORDA Titles. I popped a rod 25 mins into the main costing 1st place. Oh well maybe next year.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 09-25-2003, 10:57 PM   #5245
thefuzzclub's Avatar
People,
hooked on,
i think you're pertaining to the k factory pinion gears, they don't have the spur gears after market parts yet. i'm currently using it now and it fits perfectly fine. the material used is much harder and would last longer than the stock ones. go ahead and you will not regret.
thefuzzclub is offline   Reply With Quote
Old 09-26-2003, 06:58 AM   #5246
Default Steering problems
Does anyone else have this problem? Sometimes after I turn right, and go back to center, the car will veer right. Same thing for the left, it will veer left. Doesn't always do it. You can actually see the wheels do not center. I use top of the line speed servos, which I put in my mrx3 and never have this problem. I just accepted it like this for so long, but is there something I am missing? I do not see a bind. I think I have the servo saver spring pretty tight too.
Tks in advance
Oh yeah, pretty quite here since Harry has gone HPI again.
CHUCKMANDO is offline   Reply With Quote
Old 09-26-2003, 09:32 AM   #5247
Chuck, do you have the steering bushings or do you actually have the bearings?
If it is the original bushings, you may consider changing them to the steering bearings.
I have not had that problem and I do use digi servos.
Old 09-26-2003, 10:03 AM   #5248
I do use bearings. I am useing the ko2173 now, and was using the airtronics 9347 I believe, the speed one.
Tks
Old 09-26-2003, 10:04 AM   #5249
Talking carbon shaft for NTC3
GP doctor is offline   Reply With Quote
Old 09-26-2003, 10:09 AM   #5250
The only other thing for you to check are the lower pivot balls on the front to see if they are still straight and your shock lengths. That is all that I could think of at the moment. Good luck. Let me know what you find.
Gp,
nice shaft!! Does it really help the rpm's?
