Old 09-10-2003, 07:36 AM   #5191
Originally posted by simonfdr
Hey guys! What's new for the good ol NTC3? I haven't touched it all summer. Still nice and dirty from the last race.
Simon, your mt12 is fast enough. Did you get rid of the other engine? Either will be fine. Trust me, driving time is what will make you faster
CHUCKMANDO is offline   Reply With Quote
Old 09-10-2003, 08:54 AM   #5192
Send a message via AIM to loosenut
I have a venom fail safe unit..lost the instructions...can someone tell me how to set it up again?
I remember you press the setup button and then move yoru controller to the desired location and then press the button again?? LMK if tha'ts correct. Thx.
Gary
loosenut is offline   Reply With Quote
Old 09-10-2003, 05:08 PM   #5193
Registered User
Send a message via AIM to bbntc3
I've been using the tube and air filter deal for a year or so. I've tried it long, short ,med. It all helps anytime you get it away from the hottest air, it's gotta be better. The longer you make it, the louder you can hear it pull air, especially with the Richey's and the Smeltz. Some use it beside the right rear tire, but it gets alot of foam rubber build up, I like it towards the rx box, sorta gives it a ram air effect. I now use one on a 45 angle and a short piece of pipe just long enough to clear the head, and get the clean air thats in the top of the car. They are easy to make , just use brass tubing from the LHS 5/8 dia., or 1/2. I use traxxas exhaust pipe rubber, don't remember the part#, it has a 45 angled end and is about a 4" straight end, cut it to the length you want.
bbntc3 is offline   Reply With Quote
Old 09-10-2003, 06:49 PM   #5194
XER987's Avatar
Does the Kawahara centax clutch have optional gears for the NTC3? I know it doesn't use the factory gears because it comes with the 26T one...Does anybody know if the K-Factory clutch use the stock gears??
XER987 is offline   Reply With Quote
Old 09-10-2003, 07:05 PM   #5195
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
BB..you think a std motor savers airfilter that was bent over 45 degrees to the centerline of the car would be a help?...(I guess about 60% of the airfilter would be in clean air..)
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-10-2003, 08:11 PM   #5196
Registered User
Yes, it would help some Harry I think. Like I said , any cooler air will help. It seemed to help cool the crankcase, maybe alittle. That's where I had my trouble earlier, (crankshaft overheating).
Anybody who had trouble, when the car just shut off or flameout, not starting back up and being able to watch the fuel in the line go to the carb and then just shoot back to the tank. This is do from the crankshaft being overheated.
Old 09-10-2003, 09:39 PM   #5197
fastharry™'s Avatar
Thanks bud...I'm talking to motor savers..I'll be sure to relay your thought....
btw,got my R40 running..its pretty sweet...
I'm not sure I'm faster with it though..won't know that till I get timed...but it is a real stable car...and has more steering than the tc3..its not dependent on the right line to turn.,,
Old 09-10-2003, 11:46 PM   #5198
FREAKAH's Avatar
Originally posted by fastharry
Freakah..is that your car,or if not,do you have that installed on your Tc3?.....And have you noticed any benefit?....
Nope. Sold the NTC3 about a month ago.
No, I haven't tried it on mine but it does look like it would help.
Not too sure about the length though(too long). Imagine sucking through a straw really hard and notice how the straw collapses. I think half the length would be better.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 09-11-2003, 01:17 AM   #5199
Registered User
NTC3 Kid's Avatar
Hey I just saw this on the Team Associated site.
NTC3 Kid is offline   Reply With Quote
Old 09-11-2003, 01:18 AM   #5200
Registered User
NTC3 Kid's Avatar
and another pic of the rear floating body mount
Old 09-11-2003, 01:21 AM   #5201
Registered User
NTC3 Kid's Avatar
There are more pics of this in the Racers Spotlight on the Team Associated web site
Old 09-11-2003, 05:26 AM   #5202
fastharry™'s Avatar
yep,I agree..ot it also not deal with heat..I think angled,at least into the air path,would be best.....
Have fun racing...
Old 09-11-2003, 01:47 PM   #5203
Old Skool's Avatar
It's about bloody time!
Old Skool is offline   Reply With Quote
Old 09-11-2003, 02:48 PM   #5204
what bodies work with the floating mount?
Josh K. is offline   Reply With Quote
Old 09-11-2003, 04:21 PM   #5205
speedydave's Avatar
Send a message via AIM to speedydave Send a message via Yahoo to speedydave
You may have already said this somewhere, but what'd you buy in place of the NTC3? MTX3(guessing because of your sig...)?
speedydave is offline   Reply With Quote
