Old 08-30-2003, 06:22 AM   #5146
coastaltony's Avatar
Fastharry
I just got a Trinity Team Only Reflex.
Are you familiar with these?
I have a question re: adjusting shift
point.
Is this adjustment like the NTC3s?
coastaltony is offline   Reply With Quote
Old 08-30-2003, 07:19 PM   #5147
hooked_on's Avatar
People,
Last night was the first night for my NTC3 and i can't say everything went to plan.
Brain Fade at the end of the straight resulted in having to replace the front hub. Then two heats into the night after having struggled with finding a sweet spot of the engine tune, i discovered the clip that holds the o ring in the fuel tank had snapped and fallen into the tank. (Haven't seen that since my old Ts4n days from Thunder Tiger).
Then after replacing the fuel tank for the final the pressure delivery tube blew of the inlet on the tank during the race.
Things can only improve.... I hope!
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 08-30-2003, 07:35 PM   #5148
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I can help with the inlet problem....
get a DUBRO #241 pressure inlet..
Cut off that outside guard,and the fuel nipple....
Take a screwdriver,and GENTLY enlarge the hole in the tank..then screw in that Dubro fitting...works great...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-30-2003, 07:53 PM   #5149
hooked_on's Avatar
Fast Harry: I thought that was the fix for the outlet on the tank that goes to the carby? I am having problems with the delivery inlet on the lid.
Old 08-30-2003, 08:58 PM   #5150
fastharry™'s Avatar
On the fuel tank lid?..
Old 08-30-2003, 09:04 PM   #5151
hooked_on's Avatar
Yes, the bloody thing blew off the fuel tank lid?
Has anybody actually managed to get a Novarossi to fit using the stock mounts with the BMI Chassis?
Old 08-31-2003, 04:58 AM   #5152
fastharry™'s Avatar
no problem there......
I always use the stock associated line,made by Dubro,Or aerotrend fuel line...(they both have the best grip,teh Aero is better)
Cut about a 1/4 inch of fuel line,and with a needle nose pliers,Expand it and put it over the regular fuel line..
Now,put on the regular fuel line,and push the small piece over the nipple also..it will hold the other fuel line on....
Old 09-01-2003, 01:21 AM   #5153
spawn's Avatar
I need help on handling setup. I have a push when transitioning in a s-turn. I seem to have a bit of a push and can't carry as much speed as some other car. Should I reduce the rear droop? or lighten the clutch shoes? Anyone has any pict. of how the clutch shoes are lighten?. what else should I do to help the transition?
spawn is offline   Reply With Quote
Old 09-01-2003, 07:12 AM   #5154
Default push
hey spawn!
an on power push mines u have to much rear traction at that time of transition. without knowing your set-up tire shore ,camber,toe,caster,ride height and body u use its hard to say,but u can try to limit the amount of rear traction (weight transfer) to the rear while on power in turns bye using harder
rear springs ,softer in front less droop in front and even less camber in rear .more in front i would start with tie shores first .try
different shores in front hope that helps!
isuzuguy is offline   Reply With Quote
Old 09-01-2003, 08:10 AM   #5155
In S Florida, this time of year, the
best spring & shock oil combo is,
40/40, red front & copper rear.
Tires are Nitro Shoe 40/40.
Our air temp runs 97/99°, track temp
was up to 145° yesterday at 2:00PM
Old 09-01-2003, 09:03 AM   #5156
spawn's Avatar
Default Re: push
Originally posted by isuzuguy
hey spawn!
Setup :
Front
Foam 42
copper springs
2degrees camber
0 toe in
ride height 5.5
blade = horizontal
damper hole top = inner. bottom = outer
50wt oil, piston = 3
Diff = stock
caster = stock
droop = 4
rear
Foam 40
red springs
2 degrees camber
2 degrees toe in
ride height 6
roll bar
50wt oil, piston =2
diff = stock
droop = 4
Old 09-01-2003, 09:07 AM   #5157
spawn's Avatar
145°! wow, you could burn your hands, that is hot. I would stay in if I were you.
Old 09-01-2003, 10:31 AM   #5158
What fun would that be?
Sweat burning your eyes, mix that with
some 30% nitro, have 9 other drivers
on the drivers stand going at it!
Then race "pro stock" electric after
turn-marshalling the "inter stock
electric" class.
Old 09-02-2003, 10:35 AM   #5159
Send a message via AIM to loosenut
Default yokomo or associated one-way
Which one is better? Yoks or Associated one-way??
loosenut is offline   Reply With Quote
Old 09-02-2003, 07:10 PM   #5160
mckrooz's Avatar
Send a message via AIM to mckrooz
Get the Yokomo one way. It's more durable than the AE one. I had my AE one go out on me in 2 weeks. The bearing in the Yok is better than the plastic AE one.
mckrooz is offline   Reply With Quote
