Old 08-21-2003, 01:16 PM   #5101
Send a message via AIM to loosenut
of course the demand is there....that's cool...imagine that with the fix...you're all set. I'm certainly interested in a pair
G
loosenut is offline   Reply With Quote
Old 08-21-2003, 04:35 PM   #5102
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I run for crazy nut racing and i have the alu clutch shoes. They are very nice and do grab very hard but they do wear. I use a light sandpaper after each race day to clean the bell and shoes up.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 08-21-2003, 04:44 PM   #5103
EnriqueV's Avatar
What Spring/ Combo would work with a JP Novarossi engine?And Crazy Nut shoes?
EnriqueV is offline   Reply With Quote
Old 08-21-2003, 04:49 PM   #5104
Moderator
I'm running the heavy clutch springs and i drilled a 3/32 hole in the middle of the shoes.
SMC Racing
Old 08-21-2003, 05:12 PM   #5105
stormperson's Avatar
Send a message via AIM to stormperson
I would be VERY interested in the non-strip diff cases. I think thats a great idea, and I am glad someone finally did it! Are they available without going through ebay? I am looking to buy 4 total diff cases (for my TC3 and NTC3). Please email me, [email protected]
Thanks!
loosenut- If you can find one, pick up an RD Logics 200m body. I used to run the protoform 2.0, however the RD one I have found to like better in almost all reguards. The car is just planted and still has very good steering. Also the headlights it includes are sweet. Also I have run both the RD Logics NTC3 chassis, and been thrilled with both. The new milled out one in 7075 grade Alum is awsome. I would suggest it over the 3R one.
Also dont use RPM ballcups, since alot of the time they bind for some reason. The AE big ones that come with their offroad cars are the hookup. They are pretty much as strong as the RPM's (if you ever break one its a good thing you did because something else would have gone instead), and they dont bind at all.
Also get the RPM front bumper if you dont have it already. as well as the new style fuel tank (since it does make a difference) if u dont already.
Happy Racin' !
stormperson is offline   Reply With Quote
Old 08-21-2003, 05:23 PM   #5106
EnriqueV's Avatar
Thumbs up
I think Im going to pick up the JT Chassis for the NTC3 looks real good and I've used their stuff on my older MP7.5s
So i know its good
Old 08-21-2003, 09:41 PM   #5107
Number 11's Avatar
Looks like everybody is jumping the bandwagon and going over to the R40. This thread has slowed down a lot.
Number 11 is offline   Reply With Quote
Old 08-21-2003, 10:48 PM   #5108
Old Skool's Avatar
Originally posted by loosenut
Hey thx for the advice guys,
I finally decided to do the following hopups to my ntc3,
RPm tie rod ends/balls and new tie rods
3racing chasis (nice!!)
The fix (f/r)
Blade front anti roll system
Crazy nut clutch shoe
New bumper
D. Stratus 2.1
Rdlogci 1-piece none turbo pipe
The RD Logics pipe I love, only thing is that sometimes you may get a little leakage from the exhaust gagsket (depending on the engine manufacturer-MT-12's seem to suffer from this a bit). If you get your chassis dialed-in right you won't need swaybars. My car handles better without them. Get the RPM bumper. Stratus 2.1 body is quite neutral-handling as far as the "grocery getter" sedan bodies go. I'm running the $40 GH chassis, a bargain for the money. Don't forget to check the clearance in your diffs or you'll be eating ring and pinion gears.
Old Skool is offline   Reply With Quote
Old 08-21-2003, 11:58 PM   #5109
OF course alot of people is going to jump the wagon its just a flavor of the month most of them will be back cuz Its a HPI haha
Yokomo_King is offline   Reply With Quote
Old 08-22-2003, 12:06 AM   #5110
Number 11's Avatar
I totally agree I can't do the HPI thing anymore. I have spent way to much money in the past on my HPI cars.
Old 08-22-2003, 12:27 AM   #5111
Moderator
Guys- warpspeed racing has these diff cases with the inserts in all the holes for the screws and are blueprinted for a free rolling drivetrain.
SMC Racing
Old 08-22-2003, 12:29 AM   #5112
Number 11's Avatar
What's the link to the website?
Old 08-22-2003, 12:44 AM   #5113
Moderator
The site is under construction, talk to victor the owner, [email protected] send an email to him and he can give u pictures and prices
SMC Racing
Old 08-23-2003, 04:32 AM   #5114
thefuzzclub's Avatar
Default clutch
My ntc3 has a novarossi s5 engine and I'm using a 3pjs radio.
I have problems controlling the speed especially when cornering(in and out). With a 5port engine the car is really fast on straight and has a lot of torque when cornering. But I have a hard time maintaining a speed in between medium and high speed. When I enter into a corner, I must slow down. When I try to put a little more speed by pulling the throttle slightly the car gains speed at once that I will already loose control of the car. In short, I have a hard time putting my car into a medium high speed that will take smooth and fast cornering. Is it the engaging of the clutch? I heard of centax clutch, is this the answer to my question?
thefuzzclub is offline   Reply With Quote
Old 08-23-2003, 08:47 AM   #5115
I'd like to ask other NTC3 users. What holes do you guys strip out in the diff cases? I personally have never stripped out a single bottom screw. Which holes should be re-inforced? Is $15 a case, a good deal? Please, voice your opinions.
Thanks in advance!
SpeedyOB-4 is offline   Reply With Quote
