Old 08-20-2003, 03:50 PM   #5086
EnriqueV's Avatar
Are they any new hop ups for the NTC3 that will make a difference on the track?
EnriqueV is offline   Reply With Quote
Old 08-20-2003, 03:56 PM   #5087
Default Protection
Originally posted by loosenut
Hey you guys know if the carbon fiber chasis brace or guard is worth the investment? I wonder if it protects the exhaust pipe from a side impact?
Gary
It doesn't protect your pipe, but does protect your fuel tank, and makes your chassis stiffer...
herb is offline   Reply With Quote
Old 08-20-2003, 09:42 PM   #5088
Best hop ups that make a difference on the track are practice and maintenance, without either you're just wasting money better spent on fuel, tires and track time.
AreCee is offline   Reply With Quote
Old 08-20-2003, 09:44 PM   #5089
EnriqueV's Avatar
With i think i found that out a while ago
Old 08-20-2003, 10:32 PM   #5090
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Gary
like they said,it does protect the tank,somewhat..i've got them on both my tc3s.....
one car took a real hard sideshot from a 40 mph Impulse last week,and cracked.....(didn't go all teh way through,so i glued it)..but it did protect the tank,so I finished the race...
I think they are worth it...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-21-2003, 09:39 AM   #5091
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Doesn't need many NEW hopups, just stick with TheFix, f/r sway, updated servo saver spring, etc. and you should be fine.
If you're achin for a good hopup - get TheChassis. It's expensive enough to get you past that spending hump that hopupitis seems to create and it seems to be a worthwhile hopup. Those who have it seem to rave about it.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 08-21-2003, 10:14 AM   #5092
They better be happy with that price But you know I will be taking the plunge soon after baseball season is over and I can concentrate strictly on rc. Personally, I have all the FT lightweight rotating mass. Did notice a slight difference while punching the throttle. I had the shinny cvds, but took them off, because they seemed to negate the other lightweight items installed. As Harry has stated, most races are won in the turns.
CHUCKMANDO is offline   Reply With Quote
Old 08-21-2003, 10:26 AM   #5093
fastharry™'s Avatar
hey charles..
Old 08-21-2003, 11:11 AM   #5094
Send a message via AIM to loosenut
Hey thx for the advice guys,
I finally decided to do the following hopups to my ntc3,
RPm tie rod ends/balls and new tie rods
3racing chasis (nice!!)
The fix (f/r)
Blade front anti roll system
Crazy nut clutch shoe
New bumper
D. Stratus 2.1
Rdlogci 1-piece none turbo pipe
I think this is all I'm going to do to the car. BTW, the rdlogic pipe looks awesome! So does the 3racing chasis....very good quality.
G
loosenut is offline   Reply With Quote
Old 08-21-2003, 11:24 AM   #5095
Crazy nut shoes are nice, but you have to get your trusty dremel out after each days racing.
Old 08-21-2003, 11:49 AM   #5096
ya have to do that after every race?? SAnd it with a dremel?
G
Old 08-21-2003, 11:52 AM   #5097
Question,
Any wisdom in how long the fuel tube and exhaust pressure tube has to be? I just got my car second hand. The original owner has his tubes pretty long - and I was thinking of cutting them shorter but I wanted to ask you guys before I do that.
G
Old 08-21-2003, 11:52 AM   #5098
Why don't you guys check out the new anti-strip gearboxes on ebay. They are the standard plastic gearboxes with stainless steel inserts. Go to ebay and type in "ntc3 diff". Then you can go right to it. I use one right now and have yet to strip it out. It works GREAT!
SpeedyOB-4 is offline   Reply With Quote
Old 08-21-2003, 12:13 PM   #5099
G
Well, I can usually get a few hrs in before I notice some slipping. The shoes eat into the fly wheel much quicker, and while doing that, also eat some of the shoe and form a ridge on the bottom. This causes the shoes to sometimes stick and not open and close correctly. The bell gets some serious wear too. I believe a fix might to get a shim that will raise the shoe slightly off the flywheel but with little play. This should let you race a little longer, but I would still take inspect the whole area after each day.
Harry,
The team I am coaching only has 2 tounaments left, this weekend, and in the end of Sept. So basically after this weekend I am back. Will look to start racing in Jackson next week.
Old 08-21-2003, 12:21 PM   #5100
Here's a pic of the diff case. If the demand is there for me to make more, then I will. If not, then I'll be the only one using them.
