Old 07-26-2003, 09:55 PM   #4936
FREAKAH's Avatar
Even a perfectly flat NTC3 chassis can get warped by just mounting the drivetrain and suspension components on it.
Great care must be taken when mounting the gearboxes and such. I usually mount them loosly and then tighten them in a predetermined sequence. Check with a straightedge as you go.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 07-26-2003, 09:57 PM   #4937
Registered User
Send a message via AIM to bbntc3
10 chassis's is a guess, I dunno how the hell you could ever hurt this thing. Other the engine mounting slots. I have had my engines on and off a dozen times now and theres not even a bolt mark in the slots, so maybe not even wear it out there.
bbntc3 is offline   Reply With Quote
Old 07-26-2003, 10:00 PM   #4938
Registered User
Hmm, I did'nt know AE made a flat chassis, I thought they were all warped!
Old 07-26-2003, 10:05 PM   #4939
FREAKAH's Avatar
Second-Hand Racing
RACE WORLD HAWAII
Old 07-26-2003, 10:17 PM   #4940
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Exclamation warped stuff !!!!!
if the manufacturer s made cars that were 100% correct (indestructable, long lasting, unwarped, etc etc )......WE COULDNT AFFORD TO BUY THEM
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 07-26-2003, 10:22 PM   #4941
FREAKAH's Avatar
Default NOT!!
If they made them that way there woudn't be any need for aftermarket manufacturers.
Second-Hand Racing
RACE WORLD HAWAII
Old 07-26-2003, 10:33 PM   #4942
Registered User
Also if they made them that way, they could'nt sell spare parts. They love it when you wreck and warp a chassis, break the chassis braces wipe out a diff case and a shocktower or two and a driveshaft. I guess you can all so say it helps the economy
Old 07-27-2003, 01:13 AM   #4943
Manufactures must make a fortine off of spare parts when you think about it the parts are actually worth a fraction of the cost of what we pay for them. A day or two ago I stripped out a shock end on my gt and it cost 3 bucks to buy another two, it couldnt have cost the manufature more than 20 cents to make them and for the materials, mabey even less.
AE Racer is offline   Reply With Quote
Old 07-28-2003, 11:39 AM   #4944
HI to all! New to this forum....anyone here running an OS12TR Turbo on there NTC3? Somehow I cannot get mine work right and thinking of putting back my non-turbo 12TR. The Turbo won't run below 200F and have to set the idle high. I started 2 1/2High & 2 1/2Low(from flush) as per manual and now I'm 1 1/2High needle....done already with the break-in and still won't run right....I'm using an OS medium turbo plug/20% Trinity nitro.... your inputs Please....Thanks!
adlawoo is offline   Reply With Quote
Old 07-28-2003, 12:13 PM   #4945
sbmon's Avatar
i don't think you will be able to run the
tr turbo under 200 degrees
i think the turbo motors need to run quite a bit
hotter/leaner to run correctly, but i am not sure
i am interested to hear responses regarding this
good luck
sb
sbmon is offline   Reply With Quote
Old 07-28-2003, 02:12 PM   #4946
Old Skool's Avatar
Anything below 200 degrees F is far too cold for an ABC engine. You'll have to get around 240 before you start seeing any real performance.
Old Skool is offline   Reply With Quote
Old 07-28-2003, 02:13 PM   #4947
True you will see best performance between 225 and 240.
RC311 is offline   Reply With Quote
Old 07-28-2003, 02:22 PM   #4948
alucard13's Avatar
do you know if the Mugen MR12 is an ABC engine? I bought it from someone and he didnt have the mnual, just the engine. And i've been trying to keep it around 220-250 range.
alucard13 is offline   Reply With Quote
Old 07-28-2003, 07:39 PM   #4949
Yes the MR-12 is ABC, all itilian engines are abc and most of the other engines including all os's except the cv's are abc. Anything made recently except some rtr engines are abc.
Old 07-28-2003, 08:12 PM   #4950
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
old school...seen the R40 run?..I hear its a HOT car..
I am buying the first one I can get......
and if its a great car,it will be my next car..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
