Old 07-12-2003, 06:51 PM   #4786
does anyone have the part # for an MR-12?
Thankx
Dust is offline   Reply With Quote
Old 07-12-2003, 07:45 PM   #4787
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
swen nope but i think steve is.....
Matt M. is offline   Reply With Quote
Old 07-12-2003, 07:54 PM   #4788
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
yes i am coming to the hobbytown race.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-12-2003, 08:23 PM   #4789
Originally posted by nitrosaurus
Does anyone have a problem with the FT blade roll bar and the rpm bumper interferring/touching each other?
I have no problem.
AreCee is offline   Reply With Quote
Old 07-12-2003, 09:09 PM   #4790
hooked_on's Avatar
hmmm.... thanks for the assistence guys!
Aren't i worthy to get some assistence?
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 07-12-2003, 10:11 PM   #4791
sbmon's Avatar
Default side vs rear exhaust
hooked on
i think you covered all of the differences in your
initial post difference is motor mounts, fly wheel , header,
and pipe i think thats it
sbmon is offline   Reply With Quote
Old 07-13-2003, 12:44 AM   #4792
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
wat kind of crank does the ntc3 use? sg or standard... i plan on gettin the sirio
cHckbOY5 is offline   Reply With Quote
Old 07-13-2003, 01:08 AM   #4793
Short shaft and pilot(sg) shaft engines work in the ntc3, get the pilot(sg) shaft version of the sirio.
AE Racer is offline   Reply With Quote
Old 07-13-2003, 01:10 AM   #4794
My friends getting out of rc and hes got some TRC foams that are pretty new that I could buy off him. In one set the compounds are pink and purple and in the other set the compounds are magenta and pink. Will these be any good for the ntc3? theyre all 26mm because theyre off his electric tc3.
Old 07-13-2003, 01:10 AM   #4795
cHckbOY5's Avatar
this is my first nitro, is this hard to tune?
Old 07-13-2003, 03:58 AM   #4796
hooked_on's Avatar
Default Re: side vs rear exhaust
Originally posted by sbmon
hooked on
Thank you sbmon!
Old 07-13-2003, 06:21 AM   #4797
Default blade swaybar
nitrosaurus
yea the blade can rub on the rpm bumper ,just wipe out the dremel and grind down some of the bumper . if you hit alot of boards head-on keep an eye on i, the bumper will move around !
isuzuguy is offline   Reply With Quote
Old 07-13-2003, 09:10 AM   #4798
oh man, this thing is kinda fragile with the stock bumper! Guess it doesn't help the local track uses concrete barries around some of the turns ... but damn, I wasn't even on the throttle, just coasting gently going wide to go around a puddle and the front pushed out and got caught ... snapped the stupid stock bumper no problem, and snapped the shock tower right where the hinge pin goes through.
Wow, I wasn't even going fast at all! Just trying to take it slow around the puddle in the corner until it dried up. Damn Anybody have good reccomendations on aftermarket bumpers?
chorner is offline   Reply With Quote
Old 07-13-2003, 09:22 AM   #4799
Registered User
Send a message via AIM to bbntc3
RPM makes the best bumper for the NTC3. You can't break it. The stock bumpers are trash! I use IRS carbon fiber bumper, they are expensive and do last longer than the stock but they will and do break too.
bbntc3 is offline   Reply With Quote
Old 07-13-2003, 09:33 AM   #4800
I'll have to pick one up then .. I can't believe how easily the thing snapped in half. Literally, was going no more than 5mph TOP. I smashed my darn MTX3 into the barried at atleast 30, and walked away clean; very surprised.
Off to buy an RPM bumper, and some spare shock towers + arms it is.
