Old 04-09-2002, 11:06 PM   #466
kitracer's Avatar
After 4 hrs endurance race , here is what I found on the NTC3
Clutch setting ( finally, got close to what I want!)
3 shoe, cut on the edge, with heavier spring.
The Oneway will hold but need to maintain with oneway oil after racing.
Alumi drive shaft, amazing, it will hold as well!
The mod on pressure line on the tank's lid help a lot on setting the low end needle. did not gain on run time like some guys found. 9 mins per tank, sheeeeet, how lean u guys are running.
watch out for the 2 speed. check the screws that hold the spur. They do come lose sometime!
Rest I think have been said like the weak front bumper.
Try the V1 RR rear floating mount, it works on this car if you use Lola style body. More for looks, it did not help my lap time
kitracer is offline   Reply With Quote
Old 04-10-2002, 12:47 AM   #467
Send a message via AIM to ZER01
Originally posted by Schuie Driver
So the question becomes.........can you just modify the stock tank with a new pressure fitting in the cap to do the same as putting on a Serpent tank? Seems like it would be an easier solution than having to put on a whole new tank with custom mounts.
Yes you can and it helps alot. It was easy for me to make the modification.
ZER01 is offline   Reply With Quote
Old 04-10-2002, 12:48 AM   #468
Another pic
Old 04-10-2002, 02:44 AM   #469
INFERN0's Avatar
Has anyone found a cure for the oily mess from the pipe pressure line hole?I found the fuel line is not snug enuf to fill the hole up so ya need to install a nipple.
Proudly driving for Kyosho America, Team Maclan and RC Pitstop
INFERN0 is offline   Reply With Quote
Old 04-10-2002, 08:24 AM   #470
Z Man's Avatar
All you have to do is epoxy or J B weld a pressure fitting into the pipe
Z Man is offline   Reply With Quote
Old 04-10-2002, 11:00 AM   #471
glitch44's Avatar
Inferno,
If you don't want to mod the pipe, you can use Losi fuel tubing. It has a larger gauge that fits more snug in the pipe.
glitch44 is offline   Reply With Quote
Old 04-10-2002, 03:02 PM   #472
Registered User
Send a message via AIM to bbntc3
I get about 7 mins. to a tank with the new serpent tank, to get 9 mins. the car would have to be very lean or just cruisin around the track. The new serpent tank is I think a better fix because when the car is running you don't have the washing machine effect and it holds tuning even better than the lid mod. I like your mod on the stock tank though Proundwiinner! I just did my mod like Dennis talked about early.
bbntc3 is offline   Reply With Quote
Old 04-10-2002, 07:16 PM   #473
does anyone know what kind of engine u get with the rtr nitro tc3? and do u still get all the metal parts like in the team kits?
rctc3 is offline   Reply With Quote
Old 04-11-2002, 09:39 AM   #474
I don't believe it comes as an RTR. Check on Associated's website to verify.
rmac is offline   Reply With Quote
Old 04-11-2002, 08:51 PM   #475
Ok guys,
Set your NTC3 down on the table. Look at the left and right steering knuckles near where the steeing linkeage connects. Look to see if the left knuckle is lower then the right. I have the left on the left side and the right on the right side, however, there is a 4mm difference. Can someone explain?
Also, I used a lid off the HPI tank and it worked like a charm.
nitrorcfan is offline   Reply With Quote
Old 04-11-2002, 09:34 PM   #476
Thumbs down Team Associated
Originally posted by nitrorcfan
Ok guys,
You think that is bad, look at the rear. This is the kinda shyt that pisses me off.
Old 04-11-2002, 09:45 PM   #477
AMGRacer's Avatar
Mayby it was designed that way to fight torque steer from the shaft!
AMGRacer is offline   Reply With Quote
Old 04-12-2002, 08:35 AM   #478
che
che's Avatar
I see Yokomo is now making a new front one-way for the NTC3.
Has anyone seen it yet? Does it differ from the AE one, as some people are having troubles with AE's one-way?
Please post your findings or close up pictures here.
Che
che is offline   Reply With Quote
Old 04-12-2002, 02:17 PM   #479
Registered User
After reading the steering knuckle problem, I checked my car and they are at the same height frt. and rear.
Old 04-12-2002, 05:51 PM   #480
Craig's Avatar
Send a message via AIM to Craig
Craig is offline   Reply With Quote
