Old 07-09-2003, 08:24 PM   #4756
Originally posted by Lythion
The difference is that the spring rate of the blade bar is adjustable.
Also the mounting position is quite different between the blade roll bar and the other. The standard mounts to the balls molded into the arms where the blade bolts onto the front of the front arms and is adjustable.
AreCee is offline   Reply With Quote
Old 07-10-2003, 02:00 AM   #4757
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Hey all I found this on RCnitrotalk.com I thought that it was a good idea so i'd like to pass it on.
Tired of paying the outrageous prices for NitroBlast?
Here is the answer. A rechargeable Aerosol can.
You can fill it up with Denatured Alcohol or any liquid you wish. Holds up to 16 oz. Use a foot pump, tire pump or compressor to charge it up to 60 PSI. The unit comes with 4 changeable tips of different spray patterns or use one from an empty can you have around the house.
You can get it from Harbor Freight (Item number 01102) for $9.99
Note all info is from RCnitrotalk.com
Thanks J.
jscamry is offline   Reply With Quote
Old 07-10-2003, 06:17 AM   #4758
Sure that sounds good.
Want something easier and cheaper? Buy a pump spray bottle at Walgreens or CVS for about $1.00 fill it with denatured alcohol for about $3.00 a quart at Home Depot. Now all you do is to spray it on the same as you did with Nitro Blast.
Old 07-10-2003, 02:07 PM   #4759
Default The Fix
Where can I get a 1 1/4" screw....4-40 size, I have not been able to find a replacement for the fix anywhere. Thanks
no4hitter is offline   Reply With Quote
Old 07-10-2003, 02:12 PM   #4760
Is there a difference with the purple ball cups?
Originally posted by fastharry
these are for the rear..
http://www2.towerhobbies.com/cgi-bin...?&I=LXALN0&P=7
this is for the front.
http://www2.towerhobbies.com/cgi-bin...?&I=LXRB06&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXEV19&P=7
now don't get spoiled with all this easy access info...you can go to tower and use the search engine also.....
nitrosaurus is offline   Reply With Quote
Old 07-10-2003, 02:15 PM   #4761
Um, well yeah, they're purple which is different than blue.
Old 07-10-2003, 02:20 PM   #4762
So, color doesnt make a difference?
Old 07-10-2003, 02:22 PM   #4763
Only if it clashes with your decor.
Old 07-10-2003, 03:55 PM   #4764
alucard13's Avatar
My LHS doesnt have any Stealth Lub for the Diff's. Someone told me I could use vaseline (Petroleum Jelly) to put on the diffs. Is that true or are they just messing with me?
I'm trying to rebuild my diffs, but i dont have any lube.
alucard13 is offline   Reply With Quote
Old 07-10-2003, 05:10 PM   #4765
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
nope..Ijust figured,as long as I was getting you FREE info,you might as well go First Class and get the whole story.
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-10-2003, 05:14 PM   #4766
rrgt_kid's Avatar
where in the US can i get kfactory centax for my ntc3, and what hobby shop!
rrgt_kid is offline   Reply With Quote
Old 07-10-2003, 05:19 PM   #4767
cool...I wanted the manly dark colors, but there was only purple left. so thats the one I have.
Old 07-10-2003, 09:06 PM   #4768
spawn's Avatar
Anyone tried using the front arm in the rear and able to fit the blade stabilizer in the rear?
spawn is offline   Reply With Quote
Old 07-10-2003, 09:18 PM   #4769
nitrodude's Avatar
My friend did that and it actully worked quite well, except that it was too loose for him. If you try it you will have to shave part of the bottom of the rear diff case, as it gets in the way of the blade. It might work on a very high traction track.
Thanks,
Steven Muller
MPP
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-11-2003, 01:15 AM   #4770
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: The Fix
Your LHS should have it.
I just got my Fix and haven't installed it in place of my old-fashioned fix (lower-case f). Did you find the instructions on here for them?
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
