Old 07-07-2003, 08:58 PM   #4726
alucard13's Avatar
Originally posted by fastharry
also,try the Lunsford SD rear toe links(in the turnbuckle kit they sell)..along with the RPM cups from RPM,not the RPM associated ones
do you have happen to have a link to the RPM ball cups for the front and rear turnbuckles? the ones in the front of my ntc3 keep popping off. sometimes i swear they pop off just by looking at them.
alucard13 is offline   Reply With Quote
Old 07-07-2003, 09:20 PM   #4727
Send a message via AIM to Lythion
Be careful with the rear, the RPM cups that I put on my rear bind the suspension up. You may need to polish the balls a little to get the resistance out. Also the cups on the servo turnbuckle should be AE cups because the cups may bind on the servo and on the fuel tank.
Lythion is offline   Reply With Quote
Old 07-07-2003, 09:36 PM   #4728
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Lythion - if your rear cups are binding - it's because you got the normal sized ones. The ones for the back are larger than normal. Get the specific ones for the rear buckles of the NTC3. They don't bind.
Also - if you shave the RPM cups a bit they will work quite well for the steering.
(look back a bit in this thread for that discussion - do a search for RPM and ballcups)
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-07-2003, 09:58 PM   #4729
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
these are for the rear..
http://www2.towerhobbies.com/cgi-bin...?&I=LXALN0&P=7
this is for the front.
http://www2.towerhobbies.com/cgi-bin...?&I=LXRB06&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXEV19&P=7
now don't get spoiled with all this easy access info...you can go to tower and use the search engine also.....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-07-2003, 10:51 PM   #4730
sbmon's Avatar
Default thanx fastharry
thanks for the help on the kyosho collars
i'm gonna look for em at my lhs, by the way
did you decide to get an os tr turbo 12 or
not just wondering, i too recently got the
regular non turbo 12 tr for my ntc3s
my only problem is the clutch bell not covering the
clutch shoes completely , i think you mentioned this too a while
back but you were running alloy clutch shoes i am using the stock
ones for now , didyou try putting a spacer behind the the
clutch shoes to remedy this ? and if so did it work and is your
engagement still consistent.
thanks have a good day
sb
sbmon is offline   Reply With Quote
Old 07-08-2003, 12:11 AM   #4731
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
BOOMER- i used the rpm cups on steering because i want them to be durable. I used them on the servo linkage as well. I just dremeled the top plate a little bit for clearence.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-08-2003, 06:16 AM   #4732
alucard13's Avatar
LOL, thanx for the help Awhile ago i did a search on tower for them, but a whole bunch of them came up: http://www2.towerhobbies.com/cgi-bin...PM&S2=&S3=&S4=
Different colors and everything. i wasnt sure which one to get. thanx again
Old 07-08-2003, 10:49 AM   #4733
Boomer's Avatar
Right, me too. I shaved a little off the back and they cleared just fine.
Old 07-08-2003, 01:19 PM   #4734
what is the tool size needed for taking the nuts(6493)
off the wheels? Does the car use mm sizes because my manual says inches?
nitrosaurus is offline   Reply With Quote
Old 07-08-2003, 02:03 PM   #4735
The NTC3's wheel nuts are 11/32"
Old 07-08-2003, 04:49 PM   #4736
fastharry™'s Avatar
the wheel nut is 11/32nd..Thats the size of the wrench..
the thread size is 8/32nd thread.....
Old 07-08-2003, 06:58 PM   #4737
what other size tools do i need to work on this car, besides the glow plug wrench? What size allen drivers?
Old 07-08-2003, 07:05 PM   #4738
Send a message via AIM to frank13
Default tools to run the ntc3
this is my list of tools i take when i race :
long shank flat screw driver for engine tuning ,
a set of associated allens- best i ever used
small phillips no1 or 0 tip srewdriver for the sevro screws
needle nose pliers in various shapes
wheel nut WRENCH
plug wrench
the small 5/32 allen that came in the kit to adjust the diffs--- DO NOT THROW THAT TOOL OUT
xacto knife
LOCKTITE
medium size flat screw driver - in case linkage comes off steering servo
set up tools --i use the integy and the ride hieght gauge in the kit and the one for setting track
small sized mini adjustable wrench for the turnbuckles,
and the most important tool of all ---PATIENCE
I HOPE I DIDNT FOGET ANYTHING
frank13 is offline   Reply With Quote
Old 07-08-2003, 07:11 PM   #4739
Default OTHER STUFF IN CASE
other stuff i ake to the races,
chairs
cooler for drinks
ext cord about 50 feet
batt charger
charger adapters for your reciver pack
spares,
rags
rubber gloves,
soap
for a table i use two plastic saw horses from home dpot cause they have little shelves under them and they fold down , and a sheet of 20 by 36 inch laminated shelving
small fan to cool car and charger on very hot days
if you can afford it get a canopy dicks have them for 70 on sale right now from 99
batts for the radio , just in case
even if you use rechargables, also the 4 cell pack for the car in case you blow a reciever pack -- you never know,, better safe than sorry
thast al i can think off,
Old 07-08-2003, 07:11 PM   #4740
Default Re: tools to run the ntc3
do you use all of the allens thats included? do you know what sizes they are? I lost my manual, and im trying to purchase the allens are wheel nut right now. thanks
