Old 04-03-2002, 10:16 AM   #451
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by ernestf
how come everyone change their fuel tank on ntc3 now ? i remember someone say that the assoicated fuel tank design is the BEST .......
i wonder where is the guy gone now ???
I think he is in hiding....after splashing fuel all over is hands and saying...this is the BEST fuel tank....this is the BEST fuel tank!!!!!!
dtm is offline   Reply With Quote
Old 04-03-2002, 11:25 AM   #452
Z Man's Avatar
These tanks must be hit and miss. My NTC3 will only run 3-4 min. in the stock setup, but my buddys will run 8-9 min with a cold plug. I don't think the plug makes that big of a deal.
Z Man is offline   Reply With Quote
Old 04-03-2002, 01:22 PM   #453
glitch44's Avatar
ZMAN,
Cat, the other PINK meat. Cat, it's what's for dinner!
glitch44 is offline   Reply With Quote
Old 04-03-2002, 01:39 PM   #454
Z Man's Avatar
OH YA !!! DAS IS GOOT!!!
Old 04-03-2002, 02:10 PM   #455
INFERN0's Avatar
Hey I like cats..............on a slow spit.
Proudly driving for Kyosho America, Team Maclan and RC Pitstop
INFERN0 is offline   Reply With Quote
Old 04-06-2002, 12:21 AM   #456
Z Man's Avatar
By adding the nipple to my lid my car went from 3 min. runs to 9+ min runs. It was amazing how much mooving the pressure nipple helped. You don't need screws to seal the ols hole. Most all of you have a soldering iron don't you. It is sealed in a second. Good Luck I hope you have as good of luck as I did.
Old 04-06-2002, 06:44 AM   #457
Hey Z-Man.......
Great idea on the use of the soldering iron!! I plan on picking up two pressure fittings tomorrow and can't wait to see the results. Now if the weather would just cooperate for more than a day at a time I could get some run time on my car
Schuie Driver is offline   Reply With Quote
Old 04-08-2002, 06:14 PM   #458
Ok I've got the pressure fitting installed on my tank and have sealed off the old location with my soldering iron. Hopefully, I'll pick up a larger pressure fitting later this week to jb weld to the pipe. Now that I am installing the two pressure fittings what length pressure line do you guys recommend? Should I stick with the stock 10" or so?
Old 04-08-2002, 08:15 PM   #459
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
I was lucky enough to get a Irrgang bumper for my NTC3. This thing looks like it'll never break. Basically two of his carbon fiber chassis' glued together and cut to the shape of the bumper. I was even told by Mr. Irrgang himself if I break this he'll replace it for free. And the way I drive I'm definitely going to be putting this bumper to the test. He also told me that he might not be selling these bumpers to the general public. So don't be surprised if you can't get one.
Flash Gordan is offline   Reply With Quote
Old 04-08-2002, 11:02 PM   #460
First chance to race the NTC3 this past weekend, wow.
Took the engine out of my SNRS4 which ran at 235 + degrees F, and I had to hope I could make it through a 5 minute qualifier, well it ran 218 at the hottest and I had almost half a tank of fuel left. The car would most likely make 8 maybe 9 minutes on a single tank.
Very impressive car and a lot can be said for how free the drive train is, I think that is what made the biggest difference.
Now if I can only get it to handle the way I want it to.
rmac is offline   Reply With Quote
Old 04-09-2002, 09:05 AM   #461
che
che's Avatar
Default New NTC3 Chassis
Found this new Item (FYI):
http://www.ghhobby.com/products/Car/...ated/02410.htm
Che
che is offline   Reply With Quote
Old 04-09-2002, 10:58 AM   #462
Corse-R's Avatar
Default Servos for steering & brake/gas
Hi to all:
I've spent the last weeks on assembling and keeping all the most free of my new ntc3. Now it's time to install all the radio gear on the car and I have a question, since my experience is almost none on touring gas cars.
I have two servos to choose: A KO FET 2000 and a Futaba 9450 servo. The two are pretty much similar on torque specs (the two are >100oz.), but the KO is way faster (0.06 - KO vs 0.09 secs Futaba).
Which servo is better for the steering and which for the gas/brake linkages?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 04-09-2002, 11:07 AM   #463
INFERN0's Avatar
Default Re: New NTC3 Chassis
Che
Ya those are nice,I got one on my car a few days ago and are they ever nice.They weigh 7 grams less than stock.
Old 04-09-2002, 11:55 AM   #464
che
che's Avatar
Default Re: Servos for steering & brake/gas
Originally posted by Corse-R
Hi to all:
If you already own both of these servos and the torque is very similar, I'd use the faster of the 2 for steering (KO).
Che
Old 04-09-2002, 02:26 PM   #465
Registered User
Send a message via AIM to bbntc3
I would think you'd want to use the faster of the 2 servos for steering.
bbntc3 is offline   Reply With Quote
