Old 06-27-2003, 12:03 PM   #4591
Originally posted by Boomer
[BAnyway, I did speak in generalities when I said that I look at a NTC3 without the FIX in some incarnation and see a newbie - please excuse the overgeneralization! [/B]
No problem . Actually I see more newbies with the fix at my track then seasoned racers. Though I have spotted the K-factory shocktowers on a couple cars, talk about cost ($60+) , those use all four screw positions
AreCee is offline   Reply With Quote
Old 06-27-2003, 12:45 PM   #4592
Hey Puma,
Well I had the kit out for the first time today just on the driveway/street and man oh man do I love the handling!!
Wow. All I can say. It feels like you can just keep throwing it into the corners harder and harder. Thats with the stock rubber tires The thing is dialed in better than I had my mugen with foams, granted I didn't have enough time to get my setup just right before getting pissed and buying an NTC3. So once I work some more on the Mugens setup/tire/diff combo I'm sure it will be pretty compareable. Really havn't felt this kind of responseiveness though since driving my old RC10.
Note about the foams though .. the last set of foams apparently were duds (atleast for tracks and pavement around here??) 35shore Fast Tires and Ellegis just have no bite at all. The car was spinning out like mad, front and rear ... same goes for when I put them on the NTC3 now. The 37shore Ellegis seem to be the only half decent Ellegi foams .. otherwise, 40 and 35shore Jaco's are awesome, much better tires.
chorner is offline   Reply With Quote
Old 06-27-2003, 01:03 PM   #4593
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Aint it great?!?
I talked with an Expert A-Main class driver who had one and went back to his Mugen - he said he could actually drive the NTC3 faster, but just couldn't get comfortable with how reactive and positive it was. He was just so used to belt driven cars and the way they reacted that he eventually went back to it just cause he was more comfortable with it even though he was a tad slower with it.
chorner - do you have the blade for the front? I found it makes a huge difference in reaction times on the car.
Happy to hear you like the car!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-27-2003, 01:59 PM   #4594
Boomer,
Awesome ... just awesome I love this thing!
I do have the sway bar kit (front blade+rear bar), but havn't put
it on yet as I'm not on the track with it Running it with no front bumper or body just burning! haha comfortable enough that I forget the bumper isn't even on yet, just goes exactly where I want it!
Anybody know some good rubber tires? I think I might pick up a stack of the Vrage (although I've heard they don't last very long?) or some other good rubber tires as well as some foams.
I'm getting such good grip and response with just the rubbers its great!
Old 06-27-2003, 02:18 PM   #4595
Chorner, if you could find some take-offs cs32 or cs27's will last you the summer on concrete surfaces and cs22's will stick pretty well to asphalt. Take-offs is the choice brand locally on the concrete surface tracks. Glad you like the handling of the car.
On the big asphalt tracks I use either nitro shoes/fast tires 50 - 45's on the front and 40 - 42's on the rear with front anti-sway bar and a very stiff setting all the way around. Good luck out at the track.
sook is offline   Reply With Quote
Old 06-27-2003, 03:28 PM   #4596
Cool, thanks for the tip ... I'll have to pick up some take OFF tires then
Btw,
http://www.rchub.com/gfx/media/NTC3m...case01-700.jpg
Take a look at the graphite radio tray. I want something like that
except change the following :
Cut off the ends where it joins right onto the diff cases, and instead have it mount to the top of the chassis braces like the AE graphite, but leave the rest of the shape/design the way it is.
Next, those aluminum posts ... make hole so you can put in the aluminum posts where the stock radio plate touches the chassis plate.
THEN I would be a very happy camper
This AE aftermarket graphite deck is junk, the stock or carbon radio tray seems much stiffer to me.
My graphite radio plate is just sitting in the origional bag now on the shelf ... not much use for it; maybe I'll try it someday though.
Old 06-27-2003, 03:37 PM   #4597
alucard13's Avatar
Originally posted by chorner
I do agree, that most newbies do NOT properly care for their car .. and even alot of not so newbiews don't take the time to properly care for the kit. I for one, rebuild my kit entirely after every race weekend. Trust me, this is one of the reason I switched to the NTC3 ... ease of use. I can see this thing takes less than half the time it did to properly maintain my MTX3.
When you rebuild your kit, what does that consist of? Like what do you replace, lube, grease, etc? I'm trying to see what other people do to thier cars. Right now I only clean it thoroughly and check to make sure nothing is broken, check the screws and the engine.
alucard13 is offline   Reply With Quote
Old 06-27-2003, 04:49 PM   #4598
Francis M.'s Avatar
I don't rebuild my car after every race weekend but i do keep
my cars clean and inspect the drivetrain for wear. i try not
to take the car apart too much so that the plastics stay
tight and i try not to pop off the ball cups if i don't have
to because i don't want to replace them sooner than
i have to.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 06-27-2003, 06:37 PM   #4599
When I clean/rebuiild my kit I check to make sure there is enough grease on everything, check the shocks for leaks/jammed dirt on the pistons and all moving parts (including the bearings to make sure they still rotate freely and smoothly).
On a kit like the NTC3 I may only check my diff tightness after every weekend and check all the arms, cvd's and any other moving part which is open to dirt. I won't take my diff case/shock tower off for a while; perhaps the end of every month or so as dirt doesn't really get in there. You can tell if your diff gears are messed/bearings need maintenance just by picking up the kit, and rotating the spur gears and feeling for any tension or rough spots through rotation (I had a little in one spot when I just finished building it, but is gone now that its been worked in).
Then of course, I clean ever last bit of dirt off the kit :P
This usually took me about 6/7 hours with my MTX3 to fully strip it, check everything, clean and reassemble. The NTC3, I have yet to do a full rebuild as its brand new Ran it this afternoon through about 6 tanks ... all I needed was to blow it off with compressed air quickly, and get in with a Q-tip in some spots. Total time spent = 20 minutes.
:P amazing
Old 06-27-2003, 06:45 PM   #4600
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Now theres a happy tc3 owner..
and just think..for the price of all the hop ups the guys are adding to their cars on the Mugen forum,,you could have 2 tc3 nitros..
DRIVE ON!!!!!!!!!!!!!!!!
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-27-2003, 07:11 PM   #4601
haha, the Mugen sure is expensive ... looks nice on my shelf
Although, I would like to buy some hop-ups for this kit. Some 4-40 lock nuts for the top shock mount, some better -RPM- ball cups for the front linkages (the RPM cups and balls that come with the kit for the rear toe are great, no play whatsoever) a new pipe, and perhaps some eye candy like the blue anodized Fteam screws for the radio plate, shocks caps and blue center shaft.
Other than that, I wouldn't change anything else.
Btw, have the new white delrin diff gears solved the stripping problem with hi-power engines, anybody have experience with them? Thankfully they were in my kit ... hope they hold up for a while.
Old 06-27-2003, 08:03 PM   #4602
puma1824's Avatar
Send a message via AIM to puma1824
Fastharry...
Now I know what you mean "wait until you have to change the belt" Tonight I tore up my rear belt and I'm not looking forward to stripping the rear to replace Looks like tomorrow I'll start using the NTC3 for tomorrow's race Hopefully I remember how to drive it. I really don't feel like replacing the belt tonight - I'm being lazy and I'm heading out.
Well I'm off to the bar to unwind from the work week...
Hmmm should I keep the MTX3 This is my third TC and the I still have old reliable NTC3 with me.
Later,
Puma
puma1824 is offline   Reply With Quote
Old 06-27-2003, 08:40 PM   #4603
haha, Puma .. by that I take it you have yet to do a full rebuild of the kit Oh the joy with that MTX taking it apart and putting it back together again.
Old 06-27-2003, 08:55 PM   #4604
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I usually take a bottle of 99 percent denatured alch. in a spray bottle and hose everything down till it runs clean then blow it off with a compressor, check for wear, things like that.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 06-27-2003, 09:25 PM   #4605
fastharry™'s Avatar
don't add the ft blue screws..believe it or not,the composite material Associated uses wears out the aluminum screw threads...
I had them in myu gearbox,and couldn't figure out why I was stripping threads..the screws were worn out..stick with the steel..
