Old 06-07-2003, 09:59 PM   #4381
Old Skool's Avatar
Originally posted by fastharry
anyway,we are a united front ......
all for one,one for all....and all against the Mugens..
Hey now, bro...I also own an MRX-3 and XR, you hurt their feelings! BTW, yes that was a Lunsford ti hingepin in that pic I attached. I'm gonna' send it off in an envelope to Lunsford and request a replacement pin, since they're supposedly 'warrantied' against bending/breakage, lmfao. They can keep that arm, too!
Old Skool is offline   Reply With Quote
Old 06-08-2003, 02:55 AM   #4382
rrgt_kid's Avatar
Default set up
hi to all ntc3 racers i have got a not to bad set upp for the track i race at but i want to try another set up to see if i can get my ntc3 running alot better here is a pic attached to this post
thanks in advance
jeremy.
rrgt_kid is offline   Reply With Quote
Old 06-08-2003, 09:30 AM   #4383
I bent a hinge pin on my mugen buggy that i bought from lunsford, and come to find out they only warranty the turnbuckles.
thomasf is offline   Reply With Quote
Old 06-08-2003, 10:40 AM   #4384
highwayman's Avatar
Default Re: set up
thanks in advance
jeremy.
nice track very flowing... what setup are you running now?
highwayman is offline   Reply With Quote
Old 06-09-2003, 01:37 AM   #4385
highwayman's Avatar
i have a problem with my k-factory tank, the screw that holds the adjustable pressure fitting on top of the cover, has lost its thread, now, the fuel leaks thru it... anybody has a good suggestion on how i can repair it... thnx.
Old 06-09-2003, 01:47 AM   #4386
dvargas's Avatar
Send a message via Yahoo to dvargas
Try and get either a new screw, or use some time of sealent on the screw.
dvargas is offline   Reply With Quote
Old 06-09-2003, 10:34 PM   #4387
Old Skool's Avatar
Default Re: pivot balls
Would not a locknut help? Perhaps with a thin washer between the nut and the end of the arm so that the nut won't dig into the plastic?
Just a thought...
Old 06-10-2003, 02:59 AM   #4388
rrgt_kid's Avatar
Default Re: Re: set up
pretty much the crystal park one from the associated site!
jeremy
Old 06-10-2003, 04:23 AM   #4389
seamus0g's Avatar
OK, THATS IT, I'm moving to Auzzie!
What are the handling traits of the car (what would you like to change)? So how's the traction?
seamus0g is offline   Reply With Quote
Old 06-10-2003, 12:22 PM   #4390
Send a message via AIM to JeffS
Anyone have an idea where I can find the following items:
1731 - Shims for HD One Way
1732 - Ring Gear for HD One Way
Both my LHS and Tower Hobbies have no idea what I'm talking about when I try to order them.
Thanks!
-Jeff
JeffS is offline   Reply With Quote
Old 06-10-2003, 02:40 PM   #4391
Default Fastharry...
I know that you were talking about the pillow balls, since I can not get them yet since TIR has not started production I can only give witness to the parts that I have. I have the Pillow balls and screw set on order even before their factory had a fire break out. In vain I am still waiting for both parts, then my NTC3 will be complete with the TIR upgrades. Sorry for the confusion I was merely giving my opinion on the fitment and finish of TIR products. I am still using the oem AE pillowballs that I polished with Blue Magic metal polisher, good stuff by the way(not the AE pillowballs,LOL).
XtremeMDX is offline   Reply With Quote
Old 06-10-2003, 05:38 PM   #4392
Registered User
Send a message via AIM to bbntc3
Okay guy looks like I bought the new chassis from Jim Reeves. I will have to go back to the AE or K-factory fuel cell. Did I read back awhile ago that some people had trouble with the K-tank and the RD Lodgics pipe? Something about melting the fuel outlet or fitting maybe? Thanks BB
bbntc3 is offline   Reply With Quote
Old 06-10-2003, 07:11 PM   #4393
stormperson's Avatar
Send a message via AIM to stormperson
I have had the RD Logics pipe for some time now and couldnt be happier. some people have had problems with the header being close to the fuel exit thingie on the tank, however i have yet to expeariance such problems (although it is close, it hasnt affected my run time, engine temp, or hurt my engine tuning). Also use a .15 big block gasket, or else it might leak slightly.
stormperson is offline   Reply With Quote
Old 06-10-2003, 07:27 PM   #4394
highwayman's Avatar
jim sent me a picture of the chassis.. looks great... have you used it already? any comments?
Old 06-10-2003, 07:37 PM   #4395
alucard13's Avatar
any of you guys with the rd logics pipe, can you send a pic so i can see how you have it set up? email or here would be fine.
[email protected]
alucard13 is offline   Reply With Quote
