Old 06-02-2003, 06:00 AM   #4276
NTC3NUT's Avatar
No, with new pillow ball caps, I had to tighten the cap head screws down tight, then back them off 1/4 turn each until broken in. After a few runs they could be tightened back down completely.
Also, tried the new Crazy Nut aluminum shoes, WOW! I think everyone should spend the $10 or $15 (2-shoe/3-shoe) and try these things out. Man do they engauge. I drilled mine to match the weight of the teflon shoes I ran earlier last year, I also started out using the heavy copper springs. Let's just say it was a little much. I went back to the stock black springs and it tamed it down quite a bit. I was having problems with a slipping front diff, and the super hard engaugement wasn't helping matters. I look forward to getting back out on the track and giving the shoes another go, this time with a freshly rebuilt set of diffs. I think a stock set of the aluminum shoes, along with the standard AE springs, would make for alot of happy racers.
NTC3NUT is offline   Reply With Quote
Old 06-02-2003, 06:03 AM   #4277
NTC3NUT's Avatar
Here's the P/N your looking for: TR9511
This is a front & rear input shaft set. The other is a driveshaft.
Old 06-02-2003, 06:05 AM   #4278
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
you da man....(nice to have some company)..also,we can't forget bbnt3...he gets a little edgy if we don't give him props(which he deserves)
did you try the 2 shoe or three shoe?...(with the stock springs)..
also,can I call crazy nut on the phone?...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-02-2003, 06:16 AM   #4279
NTC3NUT's Avatar
No problem, glad to help the faithfull. Don't worry, there are still quite a few of us out there.
Used a 3-shoe w/factory team bellhousing.
Here's Dave's (Mr. CrazyNut) phone number:410-282-5085
Old 06-02-2003, 06:24 AM   #4280
fastharry™'s Avatar
thanks....so you'd start with the 3 shoe....how did that compare with the stock 2 shoe and heavy springs...thats the set up I have on my car now...no drilling...its not bad..could use a TAD more snap...tell me what you think to get the desired results..
Old 06-02-2003, 06:35 AM   #4281
NTC3NUT's Avatar
Start by keeping what you have, I'm not sure how big of a differance the 3-shoe would make over the 2-shoe, especially if your going to go to aluminum shoes. Drill your teflon shoes and see how you like them. I started by putting a 3/32 hole thru the big end of each shoe, then progressed to a 1/8 hole, then added another 3/32 hole between the 1/8 hole and the hole for the flywheel pin. I was very happy with the performance of these super light shoes with copper springs. Keep in mind that I had a very light drivetrain, all of the FT parts (LW clutch bellhsg/LW 2-spd bellhsg/LW 2-speed 1-way), plus the TiR shafts.
I have also just switched to MIP Shiny CVD's, not sure if I like them yet or not. I wanted the extra strength/life of steel, but I hate adding rotating mass, and they are much heavier than the original aluminum CVD's. Stay tuned.
Old 06-02-2003, 06:37 AM   #4282
NTC3NUT's Avatar
I wanted to give you a pic of the drilled teflon shoes I used last year.
Old 06-02-2003, 06:50 AM   #4283
fastharry™'s Avatar
thanks bud....I'll call him today and order the 3 shoes anyway.....what the heck....its not like I'm spending thousands on an HPI...
then I'll try the same progression you did...
thanks again..
I'll keep you posted on what lunsford says..
Old 06-02-2003, 07:30 AM   #4284
Old Skool's Avatar
how about the balls themselves ....any slop in the cup?....
My balls have always been the perfect size, I've heard no complaints...
Sorry, couldn't resist!
Old Skool is offline   Reply With Quote
Old 06-02-2003, 08:50 AM   #4285
Fatboy Joe's Avatar
FASTHARRY...
what are the ball caps that you are using?
Fatboy Joe is offline   Reply With Quote
Old 06-02-2003, 10:09 AM   #4286
Registered User
OB42TC3's Avatar
I twisted off one of my shiny CVDs off this weekend in the main at Cincy. It broke right where you would expect it to, where the diameter changes. In my experience the shinys are no stronger even in bending. I have some of the IRS big dawgs, and I did the calculations and they are the strongest, that or the niftech 7075 ones.
OB42TC3 is offline   Reply With Quote
Old 06-02-2003, 11:03 AM   #4287
ice-wolf's Avatar
Send a message via AIM to ice-wolf Send a message via Yahoo to ice-wolf
Thumbs down hardcore pro chassis
I was racing my car yesterday caught on fire couse of the
wire on the bottom start hitting the damm ground
so dont get this chassis is not worth it just cost you money(lot)
ice-wolf is offline   Reply With Quote
Old 06-02-2003, 12:18 PM   #4288
Did the chassis ground out your wires causing a short or did you leave the wires hanging loose so they could be scraped by the ground and then shorted out on the chassis?
If the chassis caused a short then why did you put uninsulated wires on a metal chassis?
AreCee is offline   Reply With Quote
Old 06-02-2003, 03:21 PM   #4289
Registered User
Send a message via AIM to bbntc3
Hey man!! I'm on the right medication now, It's racing season! I'm cool with everything!
bbntc3 is offline   Reply With Quote
Old 06-02-2003, 03:32 PM   #4290
NTC3NUT's Avatar
That's what I thought, not worth the added weight. I think they have the "Big Dawgs" at the shop, I'll pick-up a set of those. Are they also thicker around the pin area, near the axle? I have had to replace a set of the originals due to heavy wear in that area.
On another subject, have any of you tried titanium axles? I have a set on my electric TC3 and they are very well made, just not sure if they would hold up well on a nitro car. They weigh 1/3 the weight of the steel MIP axles. I would think their short length, along with their large diameter, would allow them to be very strong. Just a thought.
