Old 05-30-2003, 02:40 PM   #4231
highwayman's Avatar
Same here... we tried different lubes for both the TC3 and the NTC3, they fried the Diff gears... now, we went back to the original AE steath lube, seems to work better, especially on the electric car.
highwayman is offline   Reply With Quote
Old 05-30-2003, 04:33 PM   #4232
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
great..thanks guys...I'll mount it there..I was also thinking of mounting it on the front of the car..with one screw going into that unused 4th gearbox mounting hole....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-30-2003, 04:39 PM   #4233
Registered User
OB42TC3's Avatar
If you guys want to how to build a good diff go to IRS' web site and follow the instructions, except for the pinning of the rings. Results in very smooth diffs that don't slip. I need to try gluing some rings when I get a chance.
OB42TC3 is offline   Reply With Quote
Old 05-30-2003, 06:19 PM   #4234
hey ntc3nut are u using a centax or the aluminum shoes from crazy nut? I have some aluminum shoes on the way, thought i would try them. Dave from crazy nut set that you have tried them. What did you think? do you like them?
thomasf is offline   Reply With Quote
Old 05-30-2003, 06:24 PM   #4235
ntc3nut, he also said that you have one of his heads. How do you like that as well? I bought one for my 1/8 buggy
Old 05-30-2003, 06:28 PM   #4236
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
I have used his shoes for a while now and they are good. I would suggest running the stock springs with them first to see if you want more snap. I felt with the copper springs it would get too many rpms before engaging. I might try the copper springs again at the track though. I only tried them in an unprepped parking lot. The car would break the tires loose all the time.
His heads are awesome, I don't know what more to say. Dave is a great guy and you won't go wrong with anything you buy from him.
Jon
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 05-30-2003, 06:41 PM   #4237
NTC3NUT's Avatar
I have only had a chance to try the shoes off the track, I will get to try them on the track this Sunday. I can tell you that they hook-up! I have been running a Kawahara centax since mid season last year and I loved it, but I just had to try these shoes from Crazy Nut. Dave makes Awesome stuff. I have one of his heatsinks on my NTC3 and it works great, better than anything else I have tried. I have convinced several other guys at my local track to invest in his heatsinks as well, and they are all very happy. One note on the aluminum clutch shoes, I weighed them verses stock clutch shoes, and clutch shoes I had drilled (what I was using before my centax). Here's what I found:
(3) stock clutch shoes - 4.5356g
(3) drilled clutch shoes - 3.8693g
(3) aluminum Crazy Nut shoes - 4.3304g
I went ahead and drilled the Crazy Nut shoes with a 3/32" bit, to get them more in line with the drilled shoes that I used last year. I also use the "heavy" copper clutch springs. I'll let you know how they work out.
NTC3NUT is offline   Reply With Quote
Old 05-30-2003, 06:49 PM   #4238
I'm looking for more snap. I'll give them a shot. might end up buying a centax. I tried the MIP shoes, wasn't to impressed. The spring gets weak after a while
Old 05-30-2003, 06:52 PM   #4239
Oh thanks for the info guys, thanks for the weight comparison, saved me the trouble
Old 05-30-2003, 06:54 PM   #4240
Regional Moderator
Your track must have some serous traction. At least I hope it does because these shoes really grab hard. Well good luck and I'll get to try them on a little better track on Sunday too so Monday I'll have some more information on them.
Jon
Jon Carlson
Old 05-30-2003, 06:55 PM   #4241
oh yeah, they lay VHT
Old 05-30-2003, 07:03 PM   #4242
NTC3NUT's Avatar
Yes, we have ALOT of traction. That along with 28mm & 30mm - 45/40 shore foams, and you don't get alot of tire spinning, even with a really good .12. I also like alot of snap, I ran my centax tight, with 20/26 gearing.
And just my 2-cents, if these work as well as I think they will, why spend the cash on a centax. $15 bucks vs. $75? Not to mention the maintenance, lubing the thrust bearing every 2-3 runs, ect.. Don't get me wrong, you can't beat the adjustability of the centax, and boy does it look cool, but it's not cheep.
Old 05-30-2003, 07:15 PM   #4243
I used to have the sepent impulse with the centax and it was great, never had a problem with the thrust bearing . the kawahara thrust bearing wears out that fast?
Old 05-30-2003, 08:23 PM   #4244
NTC3NUT's Avatar
No, the thrust bearing has to be relubed, like every other centax out there. You have to do this every 2-3 runs max, or the thrust bearing will fall apart.
Old 06-01-2003, 02:11 AM   #4245
Old Skool's Avatar
No, not that often. I clean/relube the thrust bearing on my 1/8th scale only once, before a full day of practice. A .12 engine can get away with a relube between race weekends. Have had no problems with either.
Old Skool is offline   Reply With Quote
