Old 05-22-2003, 08:12 AM   #4156
Send a message via AIM to Bobby Flack
Two questions:
What do you use for lube on the two speed, one way bearing?
How many turns out are you guys setting the two speed, the book says to start at 3 1/2 turns out?
Bobby Flack is offline   Reply With Quote
Old 05-22-2003, 08:27 AM   #4157
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I use serpent one way lube....I've also used racers edge....I think the Serpent worked better..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-22-2003, 03:03 PM   #4158
alucard13's Avatar
Originally posted by Bobby Flack
Two questions:
i've set mine according to the instructins and havent changed it yet. i think later on i may set it a little higher because most of the tracks i go to dont have big straights.
alucard13 is offline   Reply With Quote
Old 05-22-2003, 03:18 PM   #4159
Tweeter's Avatar
mine's set just under 3 turns cause i like the car to shift a little later then usual. My motor pulls the gears a little long then other engines i've used.
Tweeter is offline   Reply With Quote
Old 05-22-2003, 07:22 PM   #4160
Send a message via Skype™ to JordanC
DO NOT LUBE YOUR ONE WAY BEARINGS!
JordanC is offline   Reply With Quote
Old 05-22-2003, 07:26 PM   #4161
Number 11's Avatar
WHY NOT?
Number 11 is offline   Reply With Quote
Old 05-22-2003, 07:29 PM   #4162
Yeh.......why not. One way diffs use lube.
Old 05-22-2003, 07:36 PM   #4163
There are a few guys here who lube their one way's, and they all go throught them like post it notes. I hae never used any and have never had any one way problems at all!
Old 05-22-2003, 08:29 PM   #4164
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i have aleaysedused the serpent oil, i have not ever had a problem with them going bad, they need periodic maint.....if they get dirty, or you use the wrong oil, they will blow up.....
Matt M. is offline   Reply With Quote
Old 05-22-2003, 08:50 PM   #4165
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
One ways are bearings
- bearings need lubrication
- therefore, by transitive, one ways need lubrication.
The NTC3 (and TC3) one-ways should not be as prone to dirt and crud as other cars since the diff cases are sealed so lubing it should not be a problem.
Lube it or luse it (sorry Jiffy Lube! )
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 05-22-2003, 10:27 PM   #4166
FREAKAH's Avatar
I use AE silcone ball diff lube.
Don't use slippery greases like Ronnie Grease or oil because theyr'e too slippery. The oneway will slip often if you do.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-23-2003, 03:21 AM   #4167
alucard13's Avatar
Default ALum dif cases or the fix?
What is better? Alum dif cases or the fix?
Old 05-23-2003, 04:50 AM   #4168
fastharry™'s Avatar
actually,the 2 sp one way should be cleaned every few runs also....spray with motor spray,lube wil serpent one way lube,you're done..
Old 05-23-2003, 09:29 AM   #4169
Boomer's Avatar
True, FH, true. let me amend -
Oneways are bearings -
Bearings need to be cleaned and lubed -
therefore, oneways need to be cleaned and lubed
Old 05-23-2003, 02:52 PM   #4170
highwayman's Avatar
same here... motor spray and a drop of serpent one way lube.
highwayman is offline   Reply With Quote
