Old 05-20-2003, 06:49 PM   #4141
Default Re: Bevel and Ring gears.
Originally posted by rcpilot
Anyone know how to solve the problem of the bevel and ring gears stripping out? I am using a one-way in the front and even the white gears strip out with the slightest board tap.
I'm using the AE new heavy duty with the white gears and I must have at least 1 1/2 hours of run time on the white gears and so far so good, and I 've tapped boards. Knock on wood
thomasf is offline   Reply With Quote
Old 05-20-2003, 06:52 PM   #4142
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
you can't stay on the gas and hit boards with a shaft drive car.....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-20-2003, 08:16 PM   #4143
If you say so
Old 05-20-2003, 08:26 PM   #4144
I'm looking to sell my ntc3 and would like to know basically what it's resell value is. It's a non-p/s version with ALL the factory team hopups, hitec digital servo, and a os hyper cv-r .15 with a Futaba magnum fm radio. What's it worth? Thanks
Twist 2 Go is offline   Reply With Quote
Old 05-20-2003, 08:41 PM   #4145
Number 11's Avatar
Huh lost me on this one.
Number 11 is offline   Reply With Quote
Old 05-20-2003, 08:42 PM   #4146
Number 11's Avatar
Check Ebay and compare. I'll give you a 100 bucks right now and pay for shipping.
Old 05-20-2003, 08:44 PM   #4147
Registered User
Send a message via AIM to bbntc3
I'll go $150 and you can keep the radio and the OS engine.
bbntc3 is offline   Reply With Quote
Old 05-20-2003, 08:47 PM   #4148
kilokhan's Avatar
100 to 150
that's the resell value.
Try to post a pic.. should be good
kilokhan is offline   Reply With Quote
Old 05-20-2003, 09:02 PM   #4149
InitialD's Avatar
and some guy called me crazy 'cause I've seen the new Serpent 700(AAA) mah packs get drained by 2 digatal Futabas in a 30 minute main....and I read the Mugen guys had the same problem..he told me no prob..run the new 800 packs...
In the last world meet in Ohio, I thought Team Serpent was using 700 mAH Sanyo AAA receiver packs. I don't think at that time they had 730, 750 or even 800 mAH AAA batteries. And they lasted for one good hour of racing.
A good trick is to use a good analog throttle / brake servo and a digital steering servo.
I find that on mine, a 750 mAH receiver pack can last me a good 40 minute main with 2 digital servos (9451). Have not tried beyond that.
Old 05-20-2003, 09:06 PM   #4150
thefuzzclub's Avatar
Twist 2 Go,
You have a PM please check.
thefuzzclub is offline   Reply With Quote
Old 05-20-2003, 09:31 PM   #4151
Default ntc3 body
i'm selling a custom painted body for a ntc3 if you are interested e-mail i have pics .thanks
junior is offline   Reply With Quote
Old 05-21-2003, 09:58 AM   #4152
I use 2100mAh 9.6V NiMH battery for my Futaba 3PK and 1000mAh 6.0V NiMH battery for R113iP (PCM1024) receiver. So far the max I went was 4 hours plus without recharge and still got plenty of power (Tx shown 9.3V and Rx shown 5.8V)
patricktoh is offline   Reply With Quote
Old 05-21-2003, 10:44 AM   #4153
Registered User
OB42TC3's Avatar
You have to shim out the gearbox for the least amount of backlash, this also needs to be done each and everytime you change gears, diffs, input shaft, input cups, bearings etc. All of those things have tolerances and can throw the mesh off.
OB42TC3 is offline   Reply With Quote
Old 05-21-2003, 10:57 AM   #4154
Thanks, I'll try that.
I actually have a round metal ring holding the gear on on the one-way so it applies even pressure to to whole gear and prevents it from flexing so much. It uses longer screws to hold the ring on tight but the gears still break.
rcpilot is offline   Reply With Quote
Old 05-21-2003, 01:33 PM   #4155
highwayman's Avatar
Default Re: Re: Bevel and Ring gears.
do i need to add shims or just to reposition the ones that came with the kit?
also are you just referring to the shims that go with the input shaft assembly?
highwayman is offline   Reply With Quote
