Old 05-15-2003, 06:25 PM   #4036
Send a message via AIM to simonfdr
Default Re: GH Chassis.
Originally posted by rcpilot
Does anyone know how the Gh chassis compares to the stock one in terms of weight?
Thanks.
I have both of them, let me check it out for you.
simonfdr is offline   Reply With Quote
Old 05-15-2003, 06:27 PM   #4037
Ok, the GH is heavier, but not by much. I'm not sure because I weighed it with my hands.
Old 05-15-2003, 06:33 PM   #4038
My Gh feels lighter than the stock chassis in my hands. I wanted to know if you anyone actually waeighed them on a digital scale?
rcpilot is offline   Reply With Quote
Old 05-15-2003, 06:43 PM   #4039
Hmmmmmmm... I'm curious. I'm currently using the RD Logics 7075 chassis. But i have the stock, the Old RD chassis and the GH... =/
Old 05-15-2003, 06:56 PM   #4040
alucard13's Avatar
what kind of air filters are you all running on your TC3's and how often do you clean it/ change the foams?
right now i am using the motor saver filter.
one more thing. How often do you all clean the cluth shoes, bell and the 2 speed housing? the instructions said that after the first tank of fuel to clean any oil or residue to ensure consistent shifting. i havent done it, but it seems to shift fine.
alucard13 is offline   Reply With Quote
Old 05-15-2003, 07:23 PM   #4041
I use RD Logic's airfilter. I chean it when ever I feel like squishing something. The clutch shoes and the other stuff, I blast with nitro clean.
Old 05-15-2003, 07:33 PM   #4042
alucard13's Avatar
I like your line of thinking
Old 05-15-2003, 07:52 PM   #4043
=P Those things are expensive.. I use 1 can everytime I go out and race. So, just take a garden hose and hose everything down. =)
Old 05-15-2003, 08:02 PM   #4044
alucard13's Avatar
yea dude. they are like 7 bucks here.
Old 05-15-2003, 08:03 PM   #4045
NTC3NUT's Avatar
I have the GH chassis. I don't remember the exact weights, but the GH was slightly lighter than the stock chassis. I remember because I found it hard to believe due to it being so much thicker. If you have the RD chassis it may be lighter because of the cut outs they make.
NTC3NUT is offline   Reply With Quote
Old 05-15-2003, 08:12 PM   #4046
Number 11's Avatar
Has anyone tried the NTC3 Hard Coated Alum. Swing Rack Set by Kfactory? My last race my car kept spinning out when I came out of turns and I adjusted everything from springs, camber, toe and whatever else but nothing worked. When I got home I found out my swing rack wouldn't return full center after turning right. What's the opinion on the rack?
Number 11 is offline   Reply With Quote
Old 05-15-2003, 08:15 PM   #4047
puma1824's Avatar
Send a message via AIM to puma1824
Are sure it's not your servo? or have your tried the GT spring? I found when I used a cheaper servo I couldn't get the car to center correctly. Replacing the spring and servo type helped dramatically.
-Puma
puma1824 is offline   Reply With Quote
Old 05-15-2003, 08:24 PM   #4048
Number 11's Avatar
-Puma
I have the airtronics 94358 servo and it has 200lbs of torgue. But for some reason it isn't centering. I bought a new steering rack and added ball bearings. Correct me if I am wrong but doesn't the new racks now come with the GT spring? Isn't the GT spring black?
Old 05-15-2003, 08:28 PM   #4049
puma1824's Avatar
sorry I didn't know about the spring coming with the kit and that servo should be plenty of torque. Unfortunately I don't have any exprerience with the Kfactory swing rack.
-Puma
Old 05-15-2003, 08:33 PM   #4050
Number 11's Avatar
-Puma
No I am not sure if that is the spring or not. I was asking if it is. Do you know the part number for the GT spring I will check it out. Thanks for the tips.
