Rc10ntc3
#391
Hey guys I'm hoping one of you might be able to help me out on a question I have concerning throttle linkage. I'm running a rear exhaust MT12 with a slide carb. When I initially set up my servo throw there is only a very small slit in the carb at idle which is how it's supposed to be I believe. However, when I give the car throttle and then release the trigger the carb does not close all the way to where it was previously. It's almost like the carb is sticking or something. When I hit the brakes the carb closes back to idle, but shouldn't it do that even when I don't hit the brakes? Do I need to rotate the servo horn so there is more pressure on the spring to keep the carb closed when I'm not on the brakes? Seems like if I do that the servo is constantly under strain. (I can hear it working when I initially turn on the car.) Any suggestions?
#392
Just sounds like you need to adjust the linkage to me!
#393
Registered User
Does the slide carb return to the closed position with the linkage unhooked? My slide on my RB was alot higher than the servo, the linkage was in a angle and binded up so I added a nut under the linkage to space the linkage up on the servo arm. Also turn the carb so that you have the straightest throw to the servo arm.
#395
Thanks Blimey, I picked the spring up today and installed. The steering feels much better now.
-Brock
-Brock
#396
You're welcome...makes a big difference huh!
#397
#399
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
I would check that....The diff spring from a GT,and the slipper pad spring almost look the same,but the slipper spring is a tad shorter,allowing the screw to catch the nut when installing on the servo saver...The diff spring is #6582....the spring you want is the "tourque control spring"#6587..........
BTW,when I mentioned the silocone on the engine mounts on the Veteq,it was for vibration with the monoque chassis.......I tried to find the original post,but couldn't..I have it printed up somewhere,but with 60 cars,Sometimes it's hard remembereing where I put everything......
#401
Dennis: No problem brotha. Man your engine is awsome in my NTC3, I just need to fix the tank. I'll kick Dansby butt at the next race for you haha!!
#403
Dennis: What's up, how'd you get the Collari to fit? Just wondering because I had one a while back before I returned it and got the RTU. It didn't seem like it fit that well for me. It's just a matter of time till John post some smack haha!! I can't wait to put the smackdown on his million dollar mugen LOL! I heard that it got outlawed because it's so light. Later
#404
The collari fit fine it was the collet that was a drag. I had to make a small precision split sleeve to put into the associated collet to make it work properly. The collari collet taper won't fit the associates flywheel. (actually associated uses a wierd taper that is why they supply a collet in the kit.) I know someone out there makes a collet that will work off the shelf I'm just not sure who.
#405
to work at Castle or Antioch with the stock gearing...the lowest
you can go is 20/54 in first which works out to be 6.75 to 1.
A stock MT-12/RS12/RB12 needs 18/54 and my engines run at
17/53 with 62 mm diameter foam tires....(that is, if I was running
a NTC3, this is what I would need). Jeff Lewis is running
20/54 with as small as possible foam tires and he still wants
a lower gearing with a stock RS12....what does this all mean?
Ask your motor guru.
