Old 05-08-2003, 10:19 AM   #3901
WVRACER's Avatar
Send a message via AIM to WVRACER
someone might have already said this but i can't find it .
do you have to prep the rd diff cases any befor you use them i seem to be getting some pinch in my diff bearings
thanks
wvracer
WVRACER is offline   Reply With Quote
Old 05-08-2003, 12:23 PM   #3902
puma1824's Avatar
Send a message via AIM to puma1824
Originally posted by fastharry
HEY Puma...you reading all this?.......Come back to the light!!!!
hehe...I still need to take my MTX3 out for it's maden voyage. "The light" (NTC3) is still with me on standby. All this talk is really starting to worry me. I spent so much on the MTX3 and hate to see it go to waste again, you know what I'm talking about.
Later,
Puma (Still a NTC3 fan , just have this belted car to see what everyone's talking about)
puma1824 is offline   Reply With Quote
Old 05-08-2003, 02:00 PM   #3903
NTC3NUT's Avatar
Don't worry, the Mugens a good car, just not without it's problems. Just like every other car out there, you simply have to work thru them like we all did with the NTC3.
Fastahrry, Go to Speedtech for the TiR parts.
NTC3NUT is offline   Reply With Quote
Old 05-08-2003, 02:57 PM   #3904
Whats a good temperature range for the RTR stock engine? MInes is at 260 F
nitrosaurus is offline   Reply With Quote
Old 05-08-2003, 03:05 PM   #3905
RedScorp's Avatar
Send a message via ICQ to RedScorp Send a message via AIM to RedScorp Send a message via Yahoo to RedScorp
thanks
wvracer
I've heard quite a bit of complaints on the same issue. I think it's due to the diff. cases being cast and not machined...you can't hold machine tight tolerances on cast parts....something I would think the RD Logics crew should answer how to solve. Otherwise they seem to be a waste of $$$.
RedScorp is offline   Reply With Quote
Old 05-08-2003, 03:13 PM   #3906
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
thanks nut.......
puma,we'll be here waitin'........
I'll tell you what car I might buy...
that new G 40 is sure a good lookin' car...I might have to have it for looks alone....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-08-2003, 03:43 PM   #3907
puma1824's Avatar
OH DO I KNOW! That thing looks nice! I should of waited for that for my first belt car. Would actually run about the same $$$ too or less.
-Puma
Old 05-08-2003, 04:17 PM   #3908
torchedlh's Avatar
Send a message via AIM to torchedlh
Originally posted by dvargas
Is the XTm Fail Safe universal? So i can use it with the cheap Ace jaguar radio system until i get a new FM radio system like the MX-3?? Will it owrk on both. I will be getting the MX-3, in a package type deal, you know it comes with the transmitter, reciever, on-off switch, 4 cell battery holder, and 2 servos. So will he XTM work on the MX-3 and the Ace Jaguar?
yea i'm pretty sure it's universal. doesn't specify a certian brand. works great on my MARS.
torchedlh is offline   Reply With Quote
Old 05-08-2003, 04:28 PM   #3909
RedScorp's Avatar
NTC3NUT-
I think I remember, athough I can't find it...you said something about moving the servo arm on the steering servo clockwise one tooth.
I tried that a few weeks ago and it didn't give me more throw...well, it did...in one direction but took away steering in the other.
Did I do something wrong?
Thanks.
Old 05-08-2003, 04:45 PM   #3910
highwayman's Avatar
has any one tried to dremel or remove some material from the diff cases so that it wouldn't bind with the bearings?
highwayman is offline   Reply With Quote
Old 05-08-2003, 04:48 PM   #3911
RedScorp's Avatar
The problem with trying to dremel material out is then you create a surface that is no longer smooth. The best and maybe the only way to fix it is to machine the material.
Old 05-08-2003, 04:50 PM   #3912
highwayman's Avatar
BTW,have you seen the new G40 team magic car?..
that Mugen,and all the other belt cars on the market,suddenly seem outdated.....
may i ask about the g4? anything special about it as compared with the other belt cars?
thnx...
Old 05-08-2003, 05:04 PM   #3913
highwayman's Avatar
how would you machine the diff cases?
i gather you wouldn't recommend i use them?
Old 05-08-2003, 05:09 PM   #3914
Mugens Use Hudy spring steel pillow balls right? if so thats likely why they are stronger because they are supposed to have similar properties of titanium
ImportRacer1187 is offline   Reply With Quote
Old 05-08-2003, 05:13 PM   #3915
fastharry™'s Avatar
HUDY only makes parts for serpent...
