Old 04-30-2003, 05:05 AM   #3721
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Originally posted by BossPlaya
So if i decide to get the NTC3 over the MTX-3 what extra parts am I gonna need to avoid the typical problems all NTC3 owners inevitably face?
Get a spring from a RC10GT slipper clutch and put that in the steering rack instead of the kit one. You'll get a much better steering response. I would stick with the stock tank to start with. The RD pipe is a good choice I think. However I wouldn't get the titanium pivot balls. The ones I've had don't seem to help much they still bend rather easy. I would get some ti turnbuckles though. The TR is a good motor you should enjoy it. Other than that I'd try the car as is and see how you like it. You can always upgrade later.
Jon
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 04-30-2003, 06:18 AM   #3722
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by Number 11
Hey fastharry where do I find out more about the white gears for the diff? I haven't heard about this.
the new white gears are a running change to the car(actually,to teh elctric too)...thay are a harder,less prone to melt material..that doesn't mean you don't have to build the properly..OR that you can hit the boards with w solid axle and stand on the gas....
thew look the same,only they are pearl white...all the parts #'s are the same..they have been shipped,but they need to work they're way through the pipeline...I ordered mine from associated direct....
btw,I never blew teh stock gears...actually,no one racing with us ever did either..all last year..and we run 5 port RB turbos..
they make the pinion gears also...and the old one way/solid axles gear,AND the new HD one way gear...
ALL you guys should subcsribe to the associated news letter..the sign up is on their site.....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-30-2003, 06:20 AM   #3723
fastharry™'s Avatar
Jon
DON"T forget to order "THE FIX" for the shock tower......
and swen is right..stick with the stock tank..just make sure its teh new one with the pressure feed in the lid...
Old 04-30-2003, 01:13 PM   #3724
Trader Rating: 16 (100%+)
I would like to ask the fellow NTC racer.....how many of you are using DRAG breaking on race....?
The reason I jumped from Serpent (Belt in general) is the free wheelie feeling for the whole car.......it was really nice (for a while) untill I sees the 200 plus straight one time.....and realized that I HAVE to have brake at the end of the straight........
When I race my Serpent, I rarely need to use the brake except the emergency, I am awared that it is NOT a good habbit...but the car was just tight enough for NOT diving into the wall after WOT....On NTC3, that is TOTALLY different story, along with 21/27 - 54/48 gearing.......WOT on NTC3 is like a Dummy crash test vehicle targetting to the board...........
So I added some drag braking to help my finger out a little.....it ended up very good after the WOT on the straight, however, it is NOT that good while I am turning on those small tight corning....I am automatic brakes ON all the time....it is NOT a easy tesk for my finger (habbit) to change after racing belt for 10 plus year...
I would like to know how you guys SET the drag braking, or does anyone use DRAG braking...? Or just simply FINGER braking, like Barry Baker did all the time, I saw clips of him.........he BRAKE his his NTC3 a long....for good 45 minutes.
Old 04-30-2003, 01:22 PM   #3725
hashini's Avatar
where to order the fix? any website?
hashini is offline   Reply With Quote
Old 04-30-2003, 01:32 PM   #3726
Number 11's Avatar
Here you go.
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LX2767
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXD999
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXR824
or
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXAFV3
That should about do it.
Number 11 is offline   Reply With Quote
Old 04-30-2003, 01:55 PM   #3727
Regional Moderator
I set the drag brake on my car and then on the tight slower inside turns I just keep on the gas a little bit. I have my car setup with lots of steering so this is what works well for me. In your driving style do you like to have some push or do you like the car to be a little bit twichy? It is up to you.
Jon
Jon Carlson
Old 04-30-2003, 03:02 PM   #3728
dvargas's Avatar
Send a message via Yahoo to dvargas
Bad news i was running my car with a buddy of mine and my darn pull start snapped. the car is 5 days old too. that pissed me off. but i left my car with my buddy and he is going to fix it (i hope). if not time to order a new pull start.
dvargas is offline   Reply With Quote
Old 04-30-2003, 04:13 PM   #3729
fastharry™'s Avatar
go to ebay..type in "the Fix TC3"..
we've beenn through the 5 dollar substitute so many times already....IT IS NOT THE SAME AS "THE FIX" which which you'll see on Ebay...if your trying to save 20 dollars with a inferior substitute on a 500 dollar car..you're in the wrong hobby...
Old 04-30-2003, 05:03 PM   #3730
speedydave's Avatar
Send a message via AIM to speedydave Send a message via Yahoo to speedydave
I've been putting off running my new NTC3 because The Fix hasn't showed up yet.
speedydave is offline   Reply With Quote
Old 04-30-2003, 05:13 PM   #3731
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally posted by fastharry
go to ebay..type in "the Fic TC3"..
I am not using the $5 solution to save money, it's because I enjoy making things. . . and my $5 solution worked perfectly - the shock tower was destroyed from my fix outward and the trans cases are completely intact. In fact the remains of the shock tower are still held very solidly!
That being said, I still would like to get the fix. . .just haven't gotten to it yet.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 04-30-2003, 05:15 PM   #3732
fastharry™'s Avatar
trsut me Boomer..no disrespect intended.....(esp towards you)..
but,truth be told,even though it helped in your situation,its not as good as the 2 screws that thread together in the fix...
Old 04-30-2003, 05:24 PM   #3733
Boomer's Avatar
Oh, believe me, I agree with you.
I have also looked at getting a 2" 4x40 countersunk screw so I could go up from the bottom, use my .56" spacer, a washer and a nut to make it one single solid link from bottom to top - unfortunatley nobody makes a 2" 4x40 countersunk screw.
I'm out of racing for the summer (kinda reverse from the rest of the world, I know) so I'm not too worried about the fix for my NTC3 just yet. . . but will be in a bit. . .
Old 04-30-2003, 05:26 PM   #3734
Registered User
Send a message via AIM to bbntc3
yes the clicker shocks take the same Ae springs. Heres a link they are under TC3 hopups.https://mmm1504.boca15-verio.com/tea...=1506146_46937
bbntc3 is offline   Reply With Quote
Old 04-30-2003, 05:27 PM   #3735
Boomer's Avatar
A Proper Fix is always better than a Half-baked Fix. . .
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
