Rc10ntc3
#3526
Re: My fuel tank FIX
Originally posted by jscamry
hey all. I know that most of you all have your fix, to stop the pipe from comming over and smashing the pipe. It took me 2 tanks to come up with this design. Please let me know your thoughts on my design..
J.
I hope these are not too large. This is my first time posting pics.
J.
#3527
its called torque steer its the only problem with Shaft Driven carz thats why your car pulls to one side. just by adding a lil more weight on the Right side should help. onroadmaniak the reason is the shaft is rotating to the left or counter clockwise so thats why your car drift up left to find the right spot to put a lil more weight to the right side. Just got back from work and im falling asleep hahaa
#3528
2 Speed Tranny
I heard MIP has made a 2 speed, and right now the opinion I got was to stay away from the Kawahara Centax clutch because of some people not being satisfied with the engineering and setupability...hehe new word.
MIP supposedly made one with 1 spring that goes all the way around the clutch shoes but I'm unable to find any info on it...retail sales or otherwise.
Any ideas or links you have avail?
Thanks.
Thanks.
#3529
Have you guys tested or heard how the Proline 350 Z body handles?
#3530
Regional Moderator
Jon
#3531
Re: 2 Speed Tranny
#3532
SWEN.... there's no servo saver on a TC3.......SWING-RACK is called
thanx for the info anyway......never had problems with me IMPULSE......i might try to hook up with fastharry and see.
i'm gonna put the ball diffs back in the car and see.
#3533
Regional Moderator
Jon
#3534
It is built into the swing rack. Did you purchase the RTR? If so, then you didn't build this piece and may not know it's there. If you did, then you should remember the funky little cam-shaped linkage that connects the servo to the actual swing rack - and the spring that is in there - THATs the servo saver. It works pretty well and is a decently simple design.
However, the spring in it (part no. 3929) is stupid weak and just doesn't hold up. Replace it with part no. 6587 - the spring from the slipper clutch on the RC10GT. You still get servo saving action but much more positive action.
#3537
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
any of you guys know the link to the gear ratio chart that associated had..or can you paste it here(you know,pinion and spur combos)..as I recall,there was one on their site,and someone had posted an even more varied one..I looked in teh tc3 forun archives,but could locate it..thanks..
#3538
Chart
#3539
thank you ..what site was that on,if you don't mind me asking...
#3540
I have no idea to tell you the truth. A friend of mine just showed me that and I bookmarked it.
