Old 04-21-2003, 02:18 PM   #3481
What size foam are you guys running on your NTC3's?
Front 26 or 28?
Rear 28 or 30?
Thanks in advance!
HauntedMyst is offline   Reply With Quote
Old 04-21-2003, 02:24 PM   #3482
26mm front 30mm rear
Yokomo_King is offline   Reply With Quote
Old 04-21-2003, 06:00 PM   #3483
thefuzzclub's Avatar
Default Re: Re: Wanted Suspension Experts
Originally posted by highwayman
1. move rear camber link to optional position
2. add rear toe-in... 3 degrees
*** are you using front one ways? NO
*** what is your diffSetting? NO IDEA. MINE IS RTR.
*** what tires are you using? SLICK WITH MMEDIUM INSERT
*** does your car oversteer on entry or exit? ON ENTRY
*** does your car have rear sway bars? NONE
- try loosening your rear diffs
- try moving front shock outward
- try moving rear shock inward
- try removing rear sway bars...
ANY SUGGESTIONS ON SHOCK SPRINGS OR SHOCK OIL WT.
thefuzzclub is offline   Reply With Quote
Old 04-21-2003, 06:56 PM   #3484
speedydave's Avatar
Send a message via AIM to speedydave Send a message via Yahoo to speedydave
I'm a little poorer after today...but quite happy!
speedydave is offline   Reply With Quote
Old 04-21-2003, 07:02 PM   #3485
how much heavier are the aluminum gearbox's, shock towers, and side braces compared to the lightweight graphite pieces? The aluminum parts were made by RD logics. Will I notice a difference in speed, handling, etc?
Thanks in advance!
-Andy
SpeedyOB-4 is offline   Reply With Quote
Old 04-21-2003, 08:53 PM   #3486
Only Get the diff cases... the rest of the parts are not strong enough for what they do... if you want a stronger chassis get the kfactory left side brace, and either the hardcore racing chassis braces if you want the stock radio tray or just get the kfactory radio tray... for shock towers get either a hardcore racing or kfactory one the kfactory one uses and extra screw for more strength... personaly again i would get the kfactory one, because of its added strength... either way only get one for now... cause they just released a new one that strengthens the chassis even more as it uses 5 or 6 screws... if you get this you wouldnt even need the alluminum diff cases which is what i will likely choose to do...
ImportRacer1187 is offline   Reply With Quote
Old 04-21-2003, 09:22 PM   #3487
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
or you could save yourself 150 dollars and put "THE FIX" on the shock towers...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-21-2003, 09:26 PM   #3488
theRED5's Avatar
R/C Tech Charter Subscriber
I'm breaking down and selling my NTC3....look to Items for sale/trade.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 04-21-2003, 09:43 PM   #3489
Y you selling? and as for the fix... it is still not as effective as reinforcing the parts themselves... the and where did u get 150 ? all you need is in the front... thats 50... the fix is 10... and it doesnt strenthen near as much as the shocktowers do... they also give a little bit beter shock action as the towers wont bend at all... plus it looks beter... plus... the fix just moves the stress from the diff case to the shock tower... so instead of killing the case i ripped up my shocktower... which takes longer to switch out...
I got those lunsford shock mounts... well worth the money... make adjusting shocks far easier... and they help prevent tweak... as on the car i put them on the old ones were bent...
Old 04-21-2003, 09:47 PM   #3490
Default blah blah blah
hey bolisario
if u live by the the belt , you'll drive faster by the belt!
isuzuguy is offline   Reply With Quote
Old 04-21-2003, 11:28 PM   #3491
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Default Re: blah blah blah
Originally posted by isuzuguy
hey bolisario
Yeah it looks like TheRed5 is jumping ship too. I can't sell mine cuz it seems there are ALOT of NTC3's for sale
I'll probably keep the NTC3(ANY TAKERS??) and wait for revisions or improvements to be made on the car(hint-hint AE). I got way too many spare parts for it and foams.
How about you?
BOLISARIO is offline   Reply With Quote
Old 04-22-2003, 12:09 AM   #3492
me too I bought an mtx3. Im not yet finish with assembling it so I cant tell which is better for me. For me ntc3 is a good car I bought the mtx3 coz I want a belt driven car. And I dont want hpi. But Im not going to sell my ntc3 even if its not the best car out there ( according to some people) its my first rc and I learned a lot from it. thats just me.
penggoy is offline   Reply With Quote
Old 04-22-2003, 07:08 AM   #3493
Im only selling mine cause like i said right now i have 3... need to get rid of 1 cause i need cash...
Old 04-22-2003, 08:45 AM   #3494
Default Cool receiver pack solution
I needed to add some weight to the battery side of my NTC3 to balance the car, so I investigated some alternative receiver pack solutions. I wanted to use something slightly larger than the 5 cell trinity pack that I had been using. I found some NiMH 4/5 AF size cells at the local battery store. The new cell pack puts out 6 volts and has a capacity of 2600 mAh instead of 1100 mAh. Also, it managed to add just enough weight to the right side of the car, and now the car is perfectly balanced side to side. Anyway, it is so cool having so much capacity in the receiver pack and the 4/5 AF cells fit perfectly in the NTC3.
Shiloh is offline   Reply With Quote
Old 04-22-2003, 02:18 PM   #3495
Default New NTC3 K-Factory Shock Towers
Anyone know about pricing and availability for the new K-Factory NTC3 shock towers?
TimA is offline   Reply With Quote
