Old 03-02-2002, 09:06 AM   #331
Regional Moderator
kansasracer's Avatar
There, I fixed it...
rough crowd, can't even mistype something here...
kansasracer is offline   Reply With Quote
Old 03-04-2002, 08:00 AM   #332
ernestf's Avatar
Send a message via ICQ to ernestf
Default 3-shoe type clutch
anyone try that ? are u using the same kind of clutch spring from stock kit ? will AE release harder spring and lighter shoe ?
ernestf is offline   Reply With Quote
Old 03-04-2002, 03:53 PM   #333
Registered User
Send a message via AIM to bbntc3
I have'nt tried the 3 shoe clutch setup yet. Barry Baker said it was'nt that much difference from 3 shoe or 2 shoe. You might want to drill 2, 1/16 holes in each of the clutch shoes in the thickset part of the shoe. It gives the car alot more rpm's, you will notice a big difference!!
bbntc3 is offline   Reply With Quote
Old 03-04-2002, 08:34 PM   #334
ernestf's Avatar
can i have a look on how u did the work ?
Old 03-04-2002, 09:20 PM   #335
Registered User
Ernest, sorry no pics. Just take the clutch shoes off and on the side of the shoes drill 2, 1/16th holes clear through the shoe, measure the shoes if you want for length, I put 1 hole dead center of the shoe and then the other hole split the difference between the first hole and the end of the shoe for the other hole. Anywhere from the center of the shoe to the outside of the shoe should work. All your trying to do is lighten the shoe on the outside, so it will take more rpm to make the shoe make contact with the clutchbell. It is the same thing as using a heavier clutch spring or shorter clutch shoes. You could also cut some of the outside edge off the shoes and do the same thing. I never do that though because you cut to much off and you junked the shoes, by drilling the holes if you go to much you can always fill the hole with something like epoxy or even a alum or steel pin to make up the difference. Hope this helps!
Old 03-05-2002, 02:54 PM   #336
Send a message via Yahoo to Bigfishe
Default .12TR NTC3
anyone happen to have what needle valve settings you are running on your OS .12TRs?
just got done breaking in at 2 turns and wanted to start leaning out, and wanted something to compare to.
TIA.
Bigfishe is offline   Reply With Quote
Old 03-07-2002, 11:06 PM   #337
Regional Moderator
has anyone has any experience with the hardcore products for the NTC3 yet?
Old 03-08-2002, 09:35 PM   #338
vthondaboi's Avatar
Send a message via AIM to vthondaboi Send a message via Yahoo to vthondaboi
Hey guys, does anyone know if the Hudy set-up for the nitro tc3 will work with the serpent impulse.
vthondaboi is offline   Reply With Quote
Old 03-08-2002, 09:42 PM   #339
ernestf's Avatar
i only have one set of hudy setup tools and it works for all my cars !
Old 03-08-2002, 09:45 PM   #340
vthondaboi's Avatar
thanks for the info
Old 03-09-2002, 01:12 AM   #341
CreepingDeath's Avatar
I had one of my local hobby shops call Great Planes to order one of the titanium Chassis's but the lady at Great Planes said that they are not in the database for shipment for yet. One things for sure, the titanium chassis is gonna stiffen the car up at least 20%. Carpet nitro racers, get ready to fall in love-hehe!
I'm new to nitro but not electric. I've been racing electric touring cars now for 5 years and was wondering if the Mega engines by Serpent were any good? Comments welcomed.
CreepingDeath is offline   Reply With Quote
Old 03-09-2002, 05:39 AM   #342
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Someone had mentioned on oneof these forums that the HUDY set-up hits the rear toe links on the nitro.....Also,be aware that the axles on the tc3 are 8-32nd,you might have to drill the hole on the set-up plates,as the axles won't go through...I know,I have it....And I thing drilling the holes renders it useless for the std 4mm axles on my Serpent,Kyosho's and HPI's.......
Ernest F,Comments??>........
fastharry™ is offline   Reply With Quote
Old 03-09-2002, 06:04 AM   #343
D_Ames's Avatar
Send a message via AIM to D_Ames
Nitro carpet racing???????
D_Ames is offline   Reply With Quote
Old 03-09-2002, 07:02 AM   #344
I had to do the same(open up the holes) I had the same problem with the rear toe links. I think it will work but its not the best set up.Any thoughts on "notching" the hudy where the link hits it?
blimey is offline   Reply With Quote
Old 03-09-2002, 10:30 AM   #345
Regional Moderator
where do you do Nitro carpet racing????
that seems a little odd
