Old 02-24-2002, 07:12 AM   #301
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by ernestf
do u mean the physics in MARS will be totally different than in Earth ????
i dunno ! may be kevin has been in MARS so he has this theory !
so, we shouldnt be "nasty" (that is what he said) to him if he has really been there !
Manticore is offline   Reply With Quote
Old 02-24-2002, 06:44 PM   #302
kitracer's Avatar
Ok guys, one tube comments created two pages of conversation..
what should we start next
I raced the NTC3 last week at EGR and the fuel tank does NOT affect the performance but what you get is a
RUNNING WASHING MACHINE FOR FREE FROM AE.
And when you re-fill the tank when is still have some fuel left on the tank, make sure you re -fill it FAST . ( good training for your mechanisc
all else you have a lot of cleaning to do afterwards...
kitracer is offline   Reply With Quote
Old 02-24-2002, 06:49 PM   #303
ernestf's Avatar
Send a message via ICQ to ernestf
kitracer, finally i find someone who have NTC3 in HK !!!! i have sent u a PM.
ernestf is offline   Reply With Quote
Old 02-24-2002, 08:34 PM   #304
Regional Moderator
disaster999's Avatar
hahaha...or you could just pinch the pressure line when refueling right??
disaster999 is offline   Reply With Quote
Old 02-24-2002, 08:43 PM   #305
Registered User
Send a message via AIM to bbntc3
Buy the sepent fuel tank lid for 1/10 scale, no more problems!!!!
bbntc3 is offline   Reply With Quote
Old 02-24-2002, 11:53 PM   #306
kitracer's Avatar
The car is great, other than the unusual fuel tank. I did TQ in the morning but of course Mr. Chui come to the rescue to make sure TC3 wouldn't TQ at the first race
I run Foam only ;
Front - 60w oil
45 elligi at 60mm( 26mm width)
everything else standard
Rear - 40w oil
Copper or Red spring( felt similar on either spring)
45 elligi at 61mm ( 26mm width)
I set the camber until the tire wear even which is around 2 to 2.5 degree)
I would buy harder clutch spring and one-way.
And watch out for the rear ball diff. I had to rebuild my after 1 litre of fuel as all the grease was gone but after the second rebuild, I have no problem now. May be I had it too tight in the beginning. not sure
I was amazed that the car was strong. I tested many time on the airport track ( on the wallssssss and rear end of Vone R) but I did break the front bumper and no spare parts in HK
good luck
Old 02-25-2002, 12:02 AM   #307
kitracer's Avatar
yes why not, now I will tell my mechanisc to hold one hand on the car, one hand on the refill bottle and use his feet to pinch the pressure line at the start of the final
who is going to be my mechanisc
Old 02-25-2002, 12:37 AM   #308
Manticore's Avatar
DIY !
Old 02-25-2002, 01:10 AM   #309
Send a message via AIM to ZER01
And watch out for the rear ball diff. I had to rebuild my after 1 litre of fuel.
You're right about that.
ZER01 is offline   Reply With Quote
Old 02-25-2002, 01:57 AM   #310
Manticore's Avatar
.................... I did TQ in the morning ................
It seems this kind of story never end. Do you agree ernest?? hahahaha
Old 02-25-2002, 06:57 AM   #311
ernestf's Avatar
yeah yeah this always happen. in fact, i am looking for improving my lap time again ......
Old 02-25-2002, 07:09 AM   #312
ernestf's Avatar
kitracer, i heard that the optional light-weight clutch bell and 3-shoe type clutch will be available in MK tomorrow !
Old 02-25-2002, 08:20 AM   #313
Regional Moderator
wonder where kevin went....i started to like this debate...hahahaha
Old 02-25-2002, 05:40 PM   #314
ernestf's Avatar
kitracer, thanks for sharing the setting info.
a few more questions : which starter box u are using on the ntc3 ? where u can get this type of starter box in HK ? which body are u running now ? TC body or VDS ?
Old 02-25-2002, 06:25 PM   #315
Regional Moderator
kansasracer's Avatar
I am using the dynamite starter box and it works fine. I would suggest using it, but any starter box would work as long as the bump start wheel can be turned horizontal or vertical...
kansasracer is offline   Reply With Quote
