Rc10ntc3
Old 03-28-2003, 12:18 AM
  #3061
theRED5's Avatar
It'll fit fine.
I use either McCoy MC8, 9, or 59...depending on the ambient temperature.
theRED5 is offline
Old 03-28-2003, 12:31 AM
  #3062
Number 11's Avatar
Perfect thanks for the quick response.
Number 11 is offline
Old 03-28-2003, 04:00 AM
  #3063
Default Re: MT12 engine question
Originally posted by Number 11
I am planning on buying a new engine and wanted to know if the MT12 needed any modification to install it into the car? Also what glow plug should you use with this motor?
MT12 is great, no modifications needed. McCoy glow plug I believe the 59
simonfdr is offline
Old 03-28-2003, 04:58 AM
  #3064
Regional Moderator
kansasracer's Avatar
both the MT 12 and the MR 12 fit fine in the car without mods. Glow plugs are kinda dependant on your application and enviroment....
I agree with the others about plugs...
kansasracer is offline
Old 03-28-2003, 06:12 AM
  #3065
MR Spyder's Avatar
Hi! I just acquired a NTC3 after having much consideration from other manufacturers' cars. I'm thinking of running rubber tyres all round, but the trend now seems to be going for foams. Is anyone running rubber tyres on their NTC3? If so, any advice(s)?
MR Spyder is offline
Old 03-28-2003, 07:38 AM
  #3066
rod_b's Avatar
For rubber tires, these are my experiences and from what I've seen in general from other racers. On sealed asphalt, Take Off CS27 when it's cold and Sorex 36 with a semi-firm insert when it heats up. On cement and rough asphalt, Yokomo 138Gs work pretty good but I noticed that they work a bit better once they've been "broken-in " a little bit. None of the 32s (Sorex, Take Off) seem to work at the places I race but they might for you. Also, HPI 33Rs used to work well for me on my other cars. Never tried them on the NTC3 but you could give those a try also.
rod_b is offline
Old 03-28-2003, 08:29 AM
  #3067
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
do you happen to know the temp range of the Yok 138G's?
Jon
Jon Carlson is offline
Old 03-28-2003, 08:44 AM
  #3068
Number 11's Avatar
Just to make sure the SG or stuby shaft should fit fine then?
Old 03-28-2003, 09:06 PM
  #3069
either way the car comes with provisions for both shafts, if you get the threaded, you might need to cut it down but there are instructions in the kit.
JPHRacer is offline
Old 03-29-2003, 06:08 PM
  #3070
GP40X's Avatar
Quick question guys.
I just bought a Team Orion 1100 mA Ni-Mh receiver pack to loose the 4 cell battery tray in my NTC3 RTR. I also bought a Piranha Digital peak charger to charge the Rx pack & the two 6 cell Ni-cd packs for the starter box. How long should it take to peak charge the receiver pack @ .9 amps (900 mA). TIA, I'm trying to get the car ready for the race tomorrow.
Bill (NTC3 RTR)
GP40X is offline
Old 03-29-2003, 07:07 PM
  #3071
Default charging receiver pack
It shouldn't take no more time than charging a regular pack.When I forget to turn the switch off,i charge up the pack. As I wait,I check the set up,clean a few bearings and by that time it is done.
tc3-in is offline
Old 03-29-2003, 07:33 PM
  #3072
charging a rx battery pack? hmmm the rx is 1100mAH ..the charge rate is .9 A or 900mA....it'll be 1100mAH/900mA . mA will be cancelled leaving just H. if my math is correct the answer is 1.22 hours. hope this helps.
penggoy is offline
Old 03-29-2003, 07:50 PM
  #3073
Default nitro tc3 for sale
for sale brand new nitro tc3 with some kfactory ,rd logics and titanium racing hop ups,e mail me for more info ,price and pics
thanks
kaozzlord is offline
Old 03-29-2003, 07:55 PM
  #3074
Default sale
i forgot also 3 brand new engines os 12tr turbo,sirio 5 port turbo and a mt12,e mail me at kaozzlord @yahoo.com
Old 03-30-2003, 06:01 AM
  #3075
dvargas's Avatar
Default Electronics in the NTC3 RTR
Can someone tell me who makes the electronis in the NTC3 RTR???? I know it is the Ace Jaguar Transmitter. but who makes this stuff??? Airtronics, Futuba????
Any help would be great.
David
dvargas is offline
