Old 03-23-2003, 11:12 PM   #2941
Registered User
Send a message via AIM to bbntc3
another
bbntc3 is offline   Reply With Quote
Old 03-23-2003, 11:17 PM   #2942
Registered User
another
Old 03-23-2003, 11:20 PM   #2943
Registered User
1 more
Old 03-24-2003, 05:14 AM   #2944
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by OB42TC3
Anyone thought of insulating the header?? I had a problem like many of you have described and it turned out to be a piston and sleeve that was too tight on an RB X12. After I fixed that it ran like a top. When the p/s fit is too tight it will overheat itself, and when richened it will stall. Try a picco based .12, or get a buddy to let you run a known good engine. Also swap out the fuel tank, and drill a hole and use the second chamber of the pipe for pressure. Hold on to that NTC3 fuse, it will walk all over the belt cars.
I agree......there have been THOUSANDS of Tc3's sold...the original gas tank(Chicken hopper design) could have been a problem with tuning(same as it couyld have been on the GT for the past 10 years)....and to be honest,there were more people who NEVER had a problem with that tank on the tc3,than did...
the new top feed tank solves the EASE of tuning issue....
Maybe the pipe that comes with the rear exhaust makes it a little harder to tune,but I personally don't see a problem with teh car at all....
BTW<if the car is thermally challenged,how does putting an exhaust pipe half of an inch from the air cleaner help?....
but I'll bet there are more people who cant tune a NOVA style engine than there are problems with teh car..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 03-24-2003, 05:43 AM   #2945
Send a message via AIM to deanspoors
Default diff cases
hi i want some alloy diff cases! who makes them? except for RD Logics coz i cant get them!
thanks, Dean
deanspoors is offline   Reply With Quote
Old 03-24-2003, 06:23 AM   #2946
Default front one way
What’s a good set-up on the rear diff when running a front one way? Should it be set full tight or allowed to slip?
Thanks for the help!
veesix is offline   Reply With Quote
Old 03-24-2003, 06:51 AM   #2947
dvargas's Avatar
Send a message via Yahoo to dvargas
Hey guys,
I am brand spanking new to r/c and i ordered a NTC 3 RTR and i am wondering what should i get as either extra parts or hop ups, stuff like that???
This is what i have.
(on the way)
NTC 3 RTR
Transmitter case
3 OS #A3 glow plugs
Glow wrench
DuraTrax Standard Screwdriver Set w/Pouch
After run engine oil
Glow starter
(i have already)
500cc fuel bottle
250cc fuel bottle
Nitro fuel
So i should be set when my car and stuff gets here to start bashing.
I just bought a fuel filter today, and i bought a BMW 328 Ci body.
Is there anything that you would recommend getting?? Anything you think of let me know. i would be greatful.
Thanks for your help,
David
[email protected]
dvargas is offline   Reply With Quote
Old 03-24-2003, 07:18 AM   #2948
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Hey all you guys looking for a better cooling head! Check this out Crazy Nut Racing these heads are awesome and the one on my car is lighter than my stock RB head. I ran it yesterday and wow does it cool alot better than the stock head. It's actually amazing.
He is also working on some diff cases for me. These would be actual machined and anodized diff cases not like the cast one's the RD Logics has. (not to put them down I'm sure they are great, just stating a difference) Send him an email and ask him about the diff cases. He's a great guy. And check out the heads, he does awesome work.
Jon
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 03-24-2003, 08:41 AM   #2949
Send a message via AIM to moshmxpx
sounds more like a tuning issue to me. when it is sluggish off the line it sound like your top and bottom are out of balance... try richening the top and leaning the bottom. nova/rb 12's should idle for 25-30s before they load up and die. how much fuel have you run through the engine? these engines are so tight they need to be run for a gallon before they really rip and are easy to tune. check also for air leaks; seal the backplate and where the carb seats with high temp RTV sealant. make sure your fuel system holds pressure.
moshmxpx is offline   Reply With Quote
Old 03-24-2003, 08:41 AM   #2950
Aluma's Avatar
who sells/makes aluminum shock towers for the nitro tc3?
Aluma is offline   Reply With Quote
Old 03-24-2003, 08:58 AM   #2951
torchedlh's Avatar
Send a message via AIM to torchedlh
http://www.rdlogics.com/
torchedlh is offline   Reply With Quote
Old 03-24-2003, 09:58 AM   #2952
Registered User
OB42TC3's Avatar
Default Re: front one way
Depends. Just make sure it isn't slipping. Tighter will make the car rotate under power better. With the new HD gears out I think I'm going to try my solid axle in back. That's how a lot of the r-type belt drives come out of the box.
OB42TC3 is offline   Reply With Quote
Old 03-24-2003, 10:03 AM   #2953
Regional Moderator
Aluma- K-Factory makes a nice set that uses all four holes on the diff case to mount with. Then the shock mount is made of carbon fiber. It's the best looking one I've seen so far.
Jon
Jon Carlson
Old 03-24-2003, 01:23 PM   #2954
Send a message via ICQ to drive4fun
Damn guys reading all these bad things about the ntc3 is making me change my mind of buying it.... All i hear is problems about this car i was looking forward to my ntc3 rtr (my first nitro) and now i might change my mind i dont know what to do and i have a week to decide what im getting so im confused hehe damn...!
drive4fun is offline   Reply With Quote
Old 03-24-2003, 01:28 PM   #2955
hey drive for fun. Hit me up if you have AIM ill talk to you alot about RC. TheNiceAzn is my AIM
Yokomo_King is offline   Reply With Quote
