Old 03-14-2003, 01:40 AM   #2836
Send a message via ICQ to NTC3Dvr
STS 3 port .12 I dont Know If your track Is ROAR Rules Track But 5 Ports are Not ROAR legal Engines In TC Class
NTC3Dvr is offline   Reply With Quote
Old 03-14-2003, 01:47 AM   #2837
thefuzzclub's Avatar
I'm from the Philippines and everyone is racing in most of the tracks using 5 port engines.
thefuzzclub is offline   Reply With Quote
Old 03-14-2003, 03:29 AM   #2838
finchy's Avatar
Default one way
hey number 11
try the K Factory one way. it looks the goods, even though i've used the associated one way for over 6 months now i"ve had now problems with it, maybe I don't drive hard enough ( rb X12 rody roem tuned), but if you are having problems try the K Factory one way it uses a bigger bearing than the associated one this may cure the problem.
finchy is offline   Reply With Quote
Old 03-14-2003, 04:13 AM   #2839
mugen_kid's Avatar
yep i would have to agree with you finchy bout the kfactory one way!!! So hows ya rb goin run it in yet!!!!
you at the track tomorrow???
mugen_kid is offline   Reply With Quote
Old 03-14-2003, 04:17 AM   #2840
mugen_kid's Avatar
Default Re: Ahhhh!
Originally posted by xray vision
Another tank problem! NEW STYLE TANK
Racers keep an eye on the fuel line that goes from the tank to the carby,tried three different diameter fuel lines still coming off. Not the pressure line!. Am trying the tank with a pipe pressure nipple tapped into the old fuel outlet. So far so good have to do more testing though.
Anyone else have the same problem?
Hi xray vision perhaps the k factory tank might solve the problem
Old 03-14-2003, 04:22 AM   #2841
mugen_kid's Avatar
Default Re: Which centax ????
Originally posted by Never Enough
Is there a differance between the K-Factory centax and the Kawahara centax ?
Which one is the better of the two for the NTC3 ?
Do I need to buy a different flywheel or can I use the stock one with a centax ?
Thanks in advance,
Never Enough what i have seen of the kfactory centax looks pretty good instruction look well detailed in colour so for first timers you can put it togeather with ease.
Old 03-14-2003, 03:17 PM   #2842
Default Thanks
Thanks mugen kid but i don't think the k factory tank will in with a pullstart engine, bit like the chassis have to do a bit of filing to get a pull start on it...! Looks like the nipple will work
Thanks for the help racers
xray vision is offline   Reply With Quote
Old 03-14-2003, 03:36 PM   #2843
mugen_kid's Avatar
Smile
i was thinking about that idea and i think it will solve your problem xray vision.
Old 03-14-2003, 03:41 PM   #2844
Charlie did his tank yesterday i think he raced last night....Need to ask him for feedback
Old 03-14-2003, 04:56 PM   #2845
anyone here knows the size of the screw thats on the servo( futaba 9404). Its the screw that hold the servo arm. Is it ok to apply threadlock on it because I already lost 2 screws? Are u guys using rubber grommets for the servo? Also where can I buy the rx battery (separate because Im going to make it myself) AND the glow plug battery ( sanyo cadnica kf-1300sc). I called the 2 LHS here and they both told me that they dont have those parts. Homedepot, walmart etc. would be better but if they don't have those I'll just have to order them online. thnx
btw what's the maximum current (maH) that I should have on rx battery?
note: posted this too in another forum
penggoy is offline   Reply With Quote
Old 03-14-2003, 05:26 PM   #2846
modellor's Avatar
I am not sure about the screw but unless you have metal gears I wouldnt advise loctiting it in. You run the risk of snapping the head gear. As for batteries, their is no limit on the mah of the RX battery but 6v is the limit I would run in a car. I use 600mah 6v packs and find these adequate for running 3 full racing days without charging.
For that other battery you are looking for you could try the following website.
www.wholesalebatteries.com
modellor is offline   Reply With Quote
Old 03-14-2003, 05:47 PM   #2847
Never Enough's Avatar
Default Holy Sh*t !!!!
...After reading mostly positive comments about the K-Factory Centax I decided to buy one...But after seeing the price at Tower $131.99 P/N K1215 I just couldn't get myself to order it . Why is the K-Factory So much more expensive than the Kawahara $89.99. Is the K-Factory made out of Gold or what ..j/k..lol
Can someone tell me where I can get a better deal ????
Never Enough is offline   Reply With Quote
Old 03-14-2003, 06:43 PM   #2848
Send a message via AIM to simonfdr
HAHAHA Nipple Residue =) I'm just I'm mature.
Got my Ti center shaft and input shafts today.
Also got my bladebar and my blue drive cup..
simonfdr is offline   Reply With Quote
Old 03-14-2003, 09:57 PM   #2849
Registered User
OB42TC3's Avatar
Default Re: Holy Sh*t !!!!
Just buy the MIP clutch for ~$12.00. The 'team' tested all the centax clutches and were not impressed, too little surface area because of the smaller flywheel on the NTC3, not enough to transfer all the engine power. You can get all the performance you need out of the standard clutches.
OB42TC3 is offline   Reply With Quote
Old 03-14-2003, 10:06 PM   #2850
Francis M.'s Avatar
i too tried the centax when it was first available and was
not impressed by the performance of it.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
