Old 03-09-2003, 05:14 PM   #2746
Thumbs up ntc3driver
i don't belong to a club ,but i do race as much as i can .
i just saw the pics at the web site and was tryinh to see if it would be worth while to try it ,i do understand about cold air or
force induction,thats why i'm interested in any performance gains
you saw when using the remote mounted air filter
isuzuguy is offline   Reply With Quote
Old 03-09-2003, 05:16 PM   #2747
Send a message via ICQ to NTC3Dvr
It would Make it hard to Drive with a 1 way In the rear Since the 1 way would be running In the Wrong Direction ..... A front 1 way Is Nice On Larger Flowing Tracks .......
NTC3Dvr is offline   Reply With Quote
Old 03-09-2003, 05:19 PM   #2748
Originally posted by isuzuguy
ntc3dvr question , one of your club menbers (norman) has that
mod. air filter. on his tc3 has he seen a difference in performance with it or is it for show
Oh I thought You Raced In a Our Club By the way you worded (one of your club menbers (norman)...... Where Do you Race ???
I did See some Improvements With the Filter Deal Because It would Stall Out Or Vapor Lock (what ever you want to Call it)
And It duz Seem To Help In Being able to Lean The Engine Out a Little Better with Temps 160-230 Degrees In The Hot & Humid Florida Temps
Old 03-09-2003, 05:51 PM   #2749
Thumbs up isuzuguy
kool!!! thks i,ll try it... got part numbers?
Old 03-09-2003, 05:53 PM   #2750
Cool jwf frani
frani did you drive the tc3 at second sunday ?
Old 03-09-2003, 06:29 PM   #2751
If you was asking Me about Part # ?? its all Custom made You Can Ask BBNTC3 About How to Go about Getting One He Was the Designer and Builder Of Mine....
Old 03-09-2003, 06:53 PM   #2752
nickko's Avatar
Send a message via MSN to nickko
Default K Factory NTC3 hopups (1)
nickko is offline   Reply With Quote
Old 03-09-2003, 06:55 PM   #2753
nickko's Avatar
K Factory NTC3 hopups (2)
Old 03-09-2003, 07:50 PM   #2754
Send a message via AIM to simonfdr
Does anyone know where to get aluminum arms for the NTC3?
and also a stronger drive shaft?
simonfdr is offline   Reply With Quote
Old 03-09-2003, 09:09 PM   #2755
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
WEIGHT BALANCE
Does anybody out here know how or what is the optimum weight settings for each corner of the ntc3, also front rear %, total weight etc etc
thanks for all replys in advance
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 03-09-2003, 10:33 PM   #2756
rod_b's Avatar
Send a message via AIM to rod_b
These are the GPM arms that can be found at www.hobbyetc.com
rod_b is offline   Reply With Quote
Old 03-09-2003, 10:39 PM   #2757
Ok i need to know i want to free up the drivetrain on the NTC3 and any modification besides the Rear toe in and the Fix.
Yokomo_King is offline   Reply With Quote
Old 03-09-2003, 10:42 PM   #2758
Thanks alot. I knew they had, just couldnt find. Thanks again
Old 03-09-2003, 10:58 PM   #2759
Brett's Avatar
I think they both fit. Its just anodized, won't make it too fat.
it is powder coated
u just take the powered coating off the bearing races and where the side chassis suports toch the upper case
u cant see any any of the paint takin off anyway
Brett is offline   Reply With Quote
Old 03-09-2003, 11:46 PM   #2760
Francis M.'s Avatar
the reds that is my current set up right now purple rear
copper front for revalations.
isuzu yeah I ran the ntc3 today i just got second. i messed
up on my first gear choice and the car just ran out of gear
in the infield.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
