Old 03-04-2003, 10:42 PM   #2716
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default upgrade ofna pink starter box
hey all I have a ofna pink starter box. I want to upgrade the motor. Is there anything that you all reccomend??
Thanks Jason
jscamry is offline   Reply With Quote
Old 03-05-2003, 01:44 AM   #2717
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Default JWF_Frani(your posted pic) or anyone....
Is that a lock nut on the shock tower screw? What size? I want to switch to the alumin lock nut because the stock plastic piece can easily be worn out and stripped. After installation of the shock,bushing, nut,etc., there is not enough thread left for the alumin lock nut to "lock". I think the stock screw is 4-40x3/4. I bought some 4-40x1" button head screws. But there's alot of thread left, I'm thinking about dremeling off the excess threads on the screw.
BOLISARIO is offline   Reply With Quote
Old 03-05-2003, 04:02 AM   #2718
WVRACER's Avatar
Send a message via AIM to WVRACER
Cool header seal
well guys i put some tape on a new gs seal and didi the double spring and guess what? dry as a bone thanks a million
wvracer
WVRACER is offline   Reply With Quote
Old 03-05-2003, 05:11 AM   #2719
NTC3NUT's Avatar
BOLISARIO,
You may have to purchase longer 4/40 screws. As for aluminum locknuts, take your pick. Everyone makes them in 4/40. I have used AE, Trinity, and GS to name a few. If you don't want to change your screws, and you don't have enough room for a strandard 4/40 locknut, try a mini 4/40 locknut. You can also get those from AE & Trinity.
NTC3NUT is offline   Reply With Quote
Old 03-05-2003, 07:30 PM   #2720
Tweeter's Avatar
i guess it did work then VW good. i hate to see a clean car get dirty from exhaust crud.
Tweeter is offline   Reply With Quote
Old 03-05-2003, 07:52 PM   #2721
theRED5's Avatar
R/C Tech Charter Subscriber
Default racecar850
I found that if you set you car up with the tool, the car is too wide. I screw the bottom pivot balls in as far as they'll go, the adjust the top pivot ball to get the camber I want, then when I put my 30mm tires on the car still passes tech.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 03-05-2003, 09:01 PM   #2722
Brett's Avatar
it doesnt matter how wide they are, its just how much they are offest
Brett is offline   Reply With Quote
Old 03-06-2003, 03:07 PM   #2723
Send a message via AIM to simonfdr
Whats the stock weight of a NTC3?
simonfdr is offline   Reply With Quote
Old 03-06-2003, 08:20 PM   #2724
My little setup
Old 03-06-2003, 08:58 PM   #2725
Registered User
OB42TC3's Avatar
Default Re: racecar850
I think that depends on how much toe you have on the tires and how tight the 200 mm gauge is; ie they should allow for 3 degrees of toe which is several mms over. The 200 should be to the axle centerline. Using that method and mugen fast tires (30R 26 F) it comes up a little under 200 measuring to axle centerlines. Really just depends on whoever made the tech box.
OB42TC3 is offline   Reply With Quote
Old 03-07-2003, 06:08 AM   #2726
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
And you're supposed to use the bottom width setting tool without the top even connected so that it won't effect the settings.
Jon
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 03-07-2003, 11:45 AM   #2727
racecar850's Avatar
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
TRACK WIDTH ?????
i set mine up as per manual, 5mm (.200") track width gauge etc etc. I am using Fast Tires 30mm rears, and the car still comes in right at 200mm wide
.200" = 5.08mm
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 03-07-2003, 11:50 AM   #2728
racecar850's Avatar
BEARING CARRIERS
are you guys making sure that the carriers are on the correct side, carriers are set up for a left & right fitting
not trying to make any body look silly, but when i built my kit i put right carrier on left side etc etc....all sorts of mix up
Mugen MTX-4 :tire:
Old 03-07-2003, 10:48 PM   #2729
Brett's Avatar
i will say it again it doesnt matter how wide the rims are, its the offset of the rims thats will put u over
Old 03-08-2003, 09:24 AM   #2730
CRASH's Avatar
Trader Rating: 26 (100%+)
Sway Bar vs Front Blade
What difference is there between running the front sway bar and the front blade bar? I see that usually everyone has the front blade on their car, just curious as to what the benefits of this are over the sway bar.
CRASH is offline   Reply With Quote
