Old 02-17-2003, 12:39 AM   #2491
Default Dynamite setup
Finchy, I have not have a chance to check it yet, it's been raining this whole weekend. Tomorrow's a holiday and hopefully no rain. I'll let you know tomorrow. I looked at the length of the Dynamite header and the AE pipe the header and the bend of the AE pipe are actually the same length believe it or not, the added length is in the RB pipe. I guess we'll see once I run it. I'll let you know if I did loose some top end but that could be hopefully compensated through different gearing.
XtremeMDX is offline   Reply With Quote
Old 02-17-2003, 01:14 AM   #2492
finchy's Avatar
cool xtrememdx, that's for the prompt reply. hopefully will hear form you tommorrow.
finchy is offline   Reply With Quote
Old 02-17-2003, 05:36 AM   #2493
Registered User
Send a message via AIM to bbntc3
XtremeMDX: Are you using the MIP clutch setup for the RC10 GT? Or the racing HPI Clutch? I looked into it some and the clutch shoes for the MIP was alot thinner than the stock AE. I figured it would be less contact on the clutchbell and after a short time the clutch would be slipping. The MIP clutch systems has worked great for me for years. I just got my hands on the new K-Factory 3 shoe clutch option. If it would ever warmup and quit snowing and sleeting here, I could try it!!!
bbntc3 is offline   Reply With Quote
Old 02-17-2003, 05:44 AM   #2494
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I just got the K factory side brace.....thats not bad either.....
BBntc3..go check out the MTX3 forum..and look at the reply I gave,with Mike meyers race report in it..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 02-17-2003, 05:58 AM   #2495
NTC3NUT's Avatar
bbntc3,
MIP makes a clutch now specifically for the NTC3. I think it's like $12 for the clutch shoes & spring, and it fits the 2-shoe flywheel. I haven't seen them locally, but I know that you can get them on Ebay.
NTC3NUT is offline   Reply With Quote
Old 02-17-2003, 06:05 AM   #2496
Registered User
Cool fastharry! Barry could when with a modified TYCO RC product! Barry is DA MAN! I see he was using the Picco this time. Hmm, they must have learned something from the worlds. He had troubles with the Piccos there I heard. Anway, we see who has the win and who's on top for now!
Old 02-17-2003, 06:09 AM   #2497
Registered User
Thanks NTC3NUT. I looked on the MIP site but its not there yet. I knew they would have something out soon for the NTC3.
Old 02-17-2003, 06:10 AM   #2498
fastharry™'s Avatar
heres the clutch kit...
http://www2.towerhobbies.com/cgi-bin...?&I=LXDKY9&P=0
Old 02-17-2003, 06:22 AM   #2499
gearing
so frani
you're saying u use a22 -27 pinion and a 54-48 spurs,,,?
isuzuguy is offline   Reply With Quote
Old 02-17-2003, 08:05 AM   #2500
NTC3NUT's Avatar
Hey guys, check out this rear toe-link set-up and let me know what you think. I just put it together this morning, and I am working on an even better version with 3mm screws and threaded captured balls (Mugen MRX-3 parts). The final version will look much cleaner, and it will work. No more compression, no more popping off.
Old 02-17-2003, 08:11 AM   #2501
NTC3NUT's Avatar
I have a few photos of it at different angles. If you guys have any questions let me know.
Old 02-17-2003, 08:11 AM   #2502
NTC3NUT's Avatar
Photo #3
Old 02-17-2003, 08:12 AM   #2503
NTC3NUT's Avatar
Last one.
Old 02-17-2003, 08:12 AM   #2504
Ntc3nut,
popping off has not really been an issue with most of the guys. I think that the compression is the main issue with the rear toe links. I don't think that having captured ball links does not really solve the problem of compression. It just seems the same as before with the exception that it would not pop off the cups, since it is captured. Keep trying!
sook is offline   Reply With Quote
Old 02-17-2003, 08:24 AM   #2505
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Thumbs up REAR TOE LINK MODS
Originally posted by sook
Ntc3nut,
Surely checking the rear compression is all part of between round maintainance
You cant win a race with popped ball cups
Ntc3nut.....nice mods, have suffered the pop off a couple of times, more annoying than anything else.... will start on my mod today
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
