Old 02-09-2003, 04:56 PM   #2401
Registered User
Send a message via AIM to bbntc3
I saw the airfliter system many months ago and made them myself. Anytime you can get clean and cooler air, it has to help! I now use the center exhaust deal and have had to move the air system to the left side of the car and close to the rear tire, not as good as down the right side but better than that hot air straight behind the head.
bbntc3 is offline   Reply With Quote
Old 02-09-2003, 05:05 PM   #2402
AE is good and Also the new Ofna Starter box cuz Ofna is a Copy of everycompany
http://ofna.com/images/start-multi.jpg
Yokomo_King is offline   Reply With Quote
Old 02-09-2003, 05:14 PM   #2403
I just got the AE box and added a 12v gel cell for power. Works great and is adaptable for other cars as well. Hard to beat at $69.95 plus $22.95 for the battery.
Twist 2 Go is offline   Reply With Quote
Old 02-09-2003, 05:47 PM   #2404
Brett's Avatar
Originally posted by NTC3NUT
I only used the upper case covers, but they worked great. I did have to remove a little material from my carbon corner braces due to the aluminum cases being a little thicker than the plastic cases, but I didn't have to reshim anything, and everything bolted right back into place perfectly. If you have the painted versions, you may have to remove the paint on the bearing races for proper clearance, just scrape it off, or use a wire wheel on your dremel. You may also want to run a 4/40 tap thru the holes, a few of them had a slight bit of paint in them also. All in all, 100% satisfied, you can not beat this stuff for the money. I will put the shock towers on just to see how they fit, and I'll let you guys know.
whats the deal with this painted verson???? i orded mine last wednesday and i orded the blue set i was under the indercation that is was anodised ???????? will i get anodised or will it be paint ????
Brett is offline   Reply With Quote
Old 02-10-2003, 04:17 PM   #2405
Does any body know if these tyres will fit on the NTC3?
Fast Tires - Front 26mm 1:10 DTM Mousse for Mugen
Fast Tires - Rear 30mm 1:10 DTM Mousse for Mugen
Or do i use these (Are the for electric?)
FT-REAR30 Fast Tire - Rear, Wide
Fast Tire - FRONT
Other wise, what tyres do i use to help reduce understeer?
rfree02 is offline   Reply With Quote
Old 02-10-2003, 04:30 PM   #2406
NTC3NUT's Avatar
Brett, They are painted, not anodized. It looks very nice, but it does need to be removed from some of the tighter fitting spots & the threads, no big deal. I got 2 sets, the other set is unpainted and I have begun polishing them. They take a polish very well, looks like chrome in no time! After I polished the upper cases I had second thoughts about using the painted ones. Still a great buy.
NTC3NUT is offline   Reply With Quote
Old 02-10-2003, 04:45 PM   #2407
modellor's Avatar
Fast Tire - FRONT
Both are the same tire but on different rims. The Fast Tyre rims are supposedly to be used for Mugens as their own rim but they fit other makes too.
The DTM Mousse is a multi purpose rim by GRP that fits all makes of touring car. So they should fit the NTC3 just fine.
modellor is offline   Reply With Quote
Old 02-10-2003, 08:39 PM   #2408
Send a message via AIM to simonfdr
Where can I get some prepainted bodies for the NTC3
simonfdr is offline   Reply With Quote
Old 02-10-2003, 08:42 PM   #2409
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
http://www2.towerhobbies.com/cgi-bin...?&I=LXCZD4&P=7
fastharry™ is offline   Reply With Quote
Old 02-10-2003, 08:43 PM   #2410
Send a message via AIM to GrEenGoBlIn
EBAY!!!!
GrEenGoBlIn is offline   Reply With Quote
Old 02-10-2003, 08:43 PM   #2411
fastharry™'s Avatar
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
Old 02-10-2003, 08:44 PM   #2412
BLeh... I need something with more downforce. any hook ups?
Old 02-10-2003, 08:45 PM   #2413
Francis M.'s Avatar
you can pretty much find every thing at ebay
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-10-2003, 08:47 PM   #2414
I wantsomething like this.........
http://www.teamassociated.com/racerh...rHernandez.jpg
Cant seem to find it.
Old 02-10-2003, 09:18 PM   #2415
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Talking DOWNFORCE !!!!
You mean something like this......
We have two Hobby Town USA here in the Kansas City area, these types of bodies are stocked at both stores
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
