Old 02-09-2002, 05:01 AM   #196
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Kansas racer,the swing rack bearings take a noticeable amount of play out of the steering asembly.....Mine has em',my freinds does not,and you can see the difference....As far as running,the weather in NJ is great,so no racing has been done......but you will see a static difference....I also put in the brake bearings while I was at it.....Don't make the mistake of using std bearings on the steering,the bearings are a tad thinner than std.....get the associated kit(s)............I also used RPM cups up front.......On the steering I used a RPM cup on the servo end and a Robinson on the saver side....That one(robinson) is a little thinner,but has a set screw so you can take up play(they work great)...BTW,if you get them,get the ones marked for HPI,they're short shank..........the reason i didn't use Robinson all around is I used the rpm yellow cups on the steering,along with yellow fuel line,ties,GS yellow RE gasket,and a yellow muffler joint.....what can I say,I like to make em' pretty(I'm such a fag sometimes)..........Also,get the Trinity low profile(thinner) CVD wheel nuts for associated CVD's...they're a much better fit,and they really lock down on the CVD's(more nylon on the axle)......
fastharry™ is offline   Reply With Quote
Old 02-09-2002, 07:24 PM   #197
ernestf's Avatar
Send a message via ICQ to ernestf
Originally posted by Craig
KansasRacer: All I have done is the turnbuckles.I did get the solid Diff and lightweight clutch housing
Associated has launch these optional parts already ??? I hope they will have a better clutch (3 shoe, harder clutch spring) or even a centrax-type clutch !
ernestf is offline   Reply With Quote
Old 02-09-2002, 09:31 PM   #198
Regional Moderator
kansasracer's Avatar
FastHarry:
Thanks, I didn't know there was an associated kit for the braking section.
I ordered the bearings today, should have them next week...anyone using the graphite radio tray yet?
kansasracer is offline   Reply With Quote
Old 02-09-2002, 09:39 PM   #199
fastharry™'s Avatar
Got it,haven't installed it......Like that it has a better mount for antenae,but no place for on off switch......also,it doesn't use posts to attach to chassis......i calleed associated,they told me real racers dont use the switches,and the tray is thick enough not to need post's.........I kindfly explained to them that if they were only going to market the car to racers,they'ed sell 50 of them.......What they're DOING is trying to sell a RACE CAR to the average guy...........Make sense to you???...Anyway,I'll install the tray tommorrow and post back.........I just bought my second Millenium pro,I've been busy putting Deans on everything........
Old 02-09-2002, 10:16 PM   #200
ernestf's Avatar
i found a major problem about the fuel tank ! the pressure intake hole should be opened on the fuel tank cover instead ! now it make the fuel tank work like a washing machine when the engine is on !
Old 02-09-2002, 10:25 PM   #201
dtm
dtm's Avatar
Send a message via ICQ to dtm
Thats good!!! It keeps your fuel CLEAN!!!
dtm is offline   Reply With Quote
Old 02-10-2002, 12:41 AM   #202
Manticore's Avatar
R/C Tech Charter Subscriber
no, it looks like a dish washer !
Manticore is offline   Reply With Quote
Old 02-10-2002, 05:49 AM   #203
Finally got some nice weather so my son and I decided to break in our motors(OS TR) Wow does this car coast.....I can't believe how free wheeling this car is. We never really got a chance to drive it other than up and down the street but so far I am impresssed.
blimey is offline   Reply With Quote
Old 02-10-2002, 07:32 PM   #204
black-knight's Avatar
A question for those using the non pullstart versions of the NTC3...
What make and model starter box are u using??? I need a suitable starter box ASAP.
Thanks.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 02-10-2002, 08:00 PM   #205
Registered User
Send a message via AIM to bbntc3
I made my box out of a hobbyco airplane starter motor, but looks don't bother me, my friend uses a 10258 ofna on his ntc3 it seems to work real good.
bbntc3 is offline   Reply With Quote
Old 02-10-2002, 08:31 PM   #206
Old 02-10-2002, 09:35 PM   #207
fastharry™'s Avatar
just to let you know,I have the graphite(woven,not the 8$ carbon one) radio tray installed....It's pretty sweet.......It allows you to use the GT ant mount or an opt one liek the GS metal......No place to puyt an on-off switch,but I kind of like it,it looks real clean......I'm usinga 1100 trinity nimh,so if I l,eave it on alittle longer,who cares?I have PCM failsafe anyway..........And the car feels just as twist resistant w/o the post...the tray is around 3mm thick,not like the HPI junk...........
Old 02-10-2002, 09:35 PM   #208
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Default Starter Box...
I hear AE is coming out with one soon, TP?
wolfeman09 is offline   Reply With Quote
Old 02-10-2002, 11:30 PM   #209
Registered User
I haven't gotten the NTC3 yet, but I am working on it! Tony, maybe you could help me with getting it all setup for Revelation when I do get one.
4cellovalrcr is offline   Reply With Quote
Old 02-11-2002, 07:39 AM   #210
TPhalen's Avatar
I have pix of my car that I will post tomorrow....Graphite Radio tray, blue alum. shaft, new blade-type swaybar....it's cool!
Let me see...
Kansas Racer: Yes, I run the Mugen motor. Thing is REALLY fast...whew
4cell: I think I am going to a race this weekend in Lake Perris with it. Should be able to put down some good laps. Next week I'm in Dallas again for training with my job, and should be home Sunday. So, the following weekend it's game on!!! All done with the traveling (for my job, anyway) and it's time to get back to racing!!!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
