Old 12-15-2002, 10:52 AM   #1876
Send a message via Yahoo to showtime
Default tran case pic
I forgot the pics...
showtime is offline   Reply With Quote
Old 12-15-2002, 10:53 AM   #1877
Default Centax pic...
kawahara pic.
Old 12-15-2002, 11:04 AM   #1878
Craig's Avatar
Send a message via AIM to Craig
How much and where did you get those? I'll take it.
Craig is offline   Reply With Quote
Old 12-15-2002, 11:51 AM   #1879
Default Craig...
Just email me and I will give u the info.
Old 12-15-2002, 01:22 PM   #1880
I have seen them on ebay. Don't want to try them without seeing them first. I would think that is a tough mold. But what do I know anyway, hope they fit well. Then we can work on getting better gears like the team drivers.
CHUCKMANDO is offline   Reply With Quote
Old 12-15-2002, 01:32 PM   #1881
Default they fit
I bought them because my friend has a set, they fit perfectly. They look gr8.
Old 12-15-2002, 06:30 PM   #1882
Default centax
i have swap a kyosho 3D centax clutch spring and the locking collor and it works fine now. thanks for all the help. guess it needs a softer spring.. i have also a mugen spring just in case.
thanks..
fuse01 is offline   Reply With Quote
Old 12-16-2002, 04:36 AM   #1883
thefuzzclub's Avatar
Default Recommended tires for NTC3
What tires can u best recommend for NTC3 for:
- Concrete road parking lot for bashing
- Asphalt track
Someone told me to put foam tires like the team orion fresh kicks tires. Is this best for any type of surface? Need your inputs please.
thefuzzclub is offline   Reply With Quote
Old 12-16-2002, 06:52 AM   #1884
Default Cases Sold
Thx BBNTC3. He bought the cases. I still have the Kawahara centax. Still new in the pack for 80.00...
Old 12-16-2002, 07:03 AM   #1885
NTC3NUT's Avatar
Where did you get the cases?
NTC3NUT is offline   Reply With Quote
Old 12-16-2002, 08:41 AM   #1886
Registered User
Send a message via AIM to bbntc3
40-45 shore front, 35-40 shore rear, should work ok!
bbntc3 is offline   Reply With Quote
Old 12-16-2002, 08:45 AM   #1887
Default Jaco
I used Jaco nitro shoes. 30mm 40 shore rear and 26mm45 shore fronts. The were excellent. Gr8 wear.
Old 12-16-2002, 12:07 PM   #1888
Registered User
CRC TRACK MAGNETS BABY!!!!! I've been using them for 2 years now with very good results. Very good tire wear and cheaper than most other foams.
Old 12-16-2002, 02:32 PM   #1889
Hi, I don't own a NTC3 RTR (but I wish I did ), but my friend is getting one for his birthday, I was wondering if it comes standard (in the RTR version) with a fuel filter, if it does, is it an in-line fuel filter, or is it in the tank? Also, does the NTC3 fuel tank have a primer. I want this expierance to go well for him, he doesn't have the biggest wallet, so I don't want him to ruin his car for a while . Thanks!
racerdx6 is offline   Reply With Quote
Old 12-16-2002, 05:39 PM   #1890
ilaybrk's Avatar
so shotime were did you get tranc cases share the knoldge
ilaybrk is offline   Reply With Quote
