Old 11-30-2002, 06:18 AM   #1801
Default Re: Re: PIPE
Originally posted by Corse-R
Pipes when are crushed and 'repaired', never goes to be the same (you experienced it now). My best advise is the same as time ago: change the pipe and choose the 2 chamber. Exhaust is better with the optional one (all AE officials use them and are allowed to use the one chamber). Better stick to the two chambers, is expensive, but notice an improvement on performance.
Thanks, I didn't want to get new pipe yet. It is now cold in NY and not really racing weather. I was going to wait till spring and see if something better comes out. But now I will probably get the 2 chamber pipe soon, just in case we have any decent suprise weekends. Can't believe how addictive this hobby is.
CHUCKMANDO is offline   Reply With Quote
Old 11-30-2002, 10:45 AM   #1802
InitialD's Avatar
Default Re: Re: Sirio 12Trp
Only needed to use the 20/26 one time and few times I used 21/26 with the RB (very strange motor, needs 'some help' for scream on the backstraights, expecting the 215 model is better than the 210).
Rody Roem noted that the design of the NTC3 pipe does not permit the engine to rev high. So to compensate, higher gearing ratios than normally needed should be considered...
Old 11-30-2002, 12:33 PM   #1803
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: tc3
Originally posted by isuzuguy
i've already have downloaded and printed off copies of barry's
set-ups as well as the team drivers ,but there nothing for revelation. and there are alot of tc3 drivers at that track so i though that someone could give me a good set-up they like to run there...
The past couple of times I've run at Rev I've run Barry's foam setup (Yellow/red with 40wt, 1/2deg toe out, etc.) as a baseline with the blade front sway. It's run really well, although I am looking at some gearing changes and I also have made some small adjustments to camber to fit wear.
The track is so big and swoopy that a one-way should work really well, although I haven't tried one yet.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 12-01-2002, 05:17 PM   #1804
Default ntc3 lola
hi , would like to find out if NTC3 can be fittted with a lola body?
if so please advise on whta is required.
thanks
fuse01 is offline   Reply With Quote
Old 12-01-2002, 07:17 PM   #1805
Brett's Avatar
i belive that u have to cut parts out of the body to the fit the front shock tower or some have cut down the shock tower
note i havent had first hand experiance with it thats just what i have seen
Brett is offline   Reply With Quote
Old 12-07-2002, 04:42 PM   #1806
ChrisO's Avatar
Send a message via AIM to ChrisO Send a message via Yahoo to ChrisO
why isnt anyone posting here anymore?
ChrisO is offline   Reply With Quote
Old 12-07-2002, 05:03 PM   #1807
asd
Send a message via ICQ to asd
i don't know. all i know si that the mugen MTX-3 is the most active thread now(i wonder why )
asd is offline   Reply With Quote
Old 12-07-2002, 05:57 PM   #1808
ChrisO's Avatar
yeah, damn mtx3 drew ppl in like zombe's
Old 12-07-2002, 07:01 PM   #1809
nova racer's Avatar
tc3's are junk stock
nova racer is offline   Reply With Quote
Old 12-07-2002, 07:03 PM   #1810
asd
................i beleive u jus started a flame war
everyone!!!! take cover
Old 12-07-2002, 07:04 PM   #1811
nova racer's Avatar
yes i did. lets get it on!
Old 12-07-2002, 07:05 PM   #1812
Brett's Avatar
why say shit thats how shit gets started
Old 12-07-2002, 07:09 PM   #1813
asd
ladies and gentlemen:
in the red corner, weighing 77posts in total, Bbbbbbbbret!
and in the blue corner, wiehging a whopping 155 posts, novaaaaaaaa racer!
Old 12-07-2002, 07:09 PM   #1814
nova racer's Avatar
it was a joke i thought this thred was dead.
kind of like if a tree falls in the woods and nobody is there to hear it did it relly fall.
if a bear farted in his cave and i smlled relly bad, if you werent there to smell it did it smell at all
Old 12-07-2002, 07:10 PM   #1815
asd
lol
