Like Tree2Likes
Rc10ntc3
Old 02-03-2002, 08:04 PM
  #151
Registered User
I bent one in two years racing a conversion, but twisted one out of each side both times I used the oneway! I f your worried about them get the mip shiny cvd you won;t break them. BB
bbntc3 is offline
Old 02-03-2002, 09:05 PM
  #152
ernestf's Avatar
Originally posted by Schuie Driver
Does anyone else find it odd that Associated chose to use aluminum CVD's on a nitro car? Seems to me that those things are going to be bent in a hurry considering the rate at which these cars can travel into walls Trying to decide between the Mugen Pro Spec and the Associated for the upcoming nitro season at our local track and boy it is not an easy decision
I use local-made (Jet hobby from HK) CVD in front for my TC3, and it last for more than 1 yr without any sign of broking/bending. Now I use Jet CVD in all four corners of my NTC3. They are a lot cheaper than the MIP replacement ! (HK$ 90 a pair of CVD vs HK$180 for just a pair of shafts from MIP !)
ernestf is offline
Old 02-03-2002, 11:17 PM
  #153
DanielSon is offline
Old 02-04-2002, 11:05 AM
  #154
over gear's Avatar
Trader Rating: 18 (100%+)
Thumbs up
Who needs a bigger stronger front oneway diff for your NTC3?
I have a Tech Racing TC3 front oneway for sale. I only used it once and I can't handle the extra steering.
This oneway is much bigger than the one from AE. Heavy Duty stuff.
it comes with the diff gear, hub bearings...basically just Plug and Play.
I'm selling it for $40 shipped. email if interested. [email protected]
over gear is online now
Old 02-04-2002, 07:54 PM
  #155
Registered User
OB42TC3's Avatar
Did you snap the pivot ball itself or where the arm holds it? I would think you would have broken the arm first. If the pivot ball broke it was probably defective.
OB42TC3 is offline
Old 02-04-2002, 09:09 PM
  #156
Old 02-04-2002, 10:15 PM
  #157
Craig's Avatar
Is anyone else having problems with the steering.It seems as if the lower swing arms are too flexable or there is too much slop. Also the screw is too long and hits the drive cup. Maybe it needs bearings ?
Craig is offline
Old 02-04-2002, 10:38 PM
  #158
Old 02-05-2002, 04:57 AM
  #159
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Order the swing rack and brake bearing kit from Tower(in stock at the moment,#'s in your associated cat)...I did,and using thise and RPM cups on the front had ZERO slop..............BTW,std. bearings won't fit....the swingrack uses a special thinner bearing on the bottom....also,make sure your bushings you have now are FULLY seated on the steering posts.....If not you'll have clearance problems(do the same with ythe bearings when you get them)
fastharry™ is offline
Old 02-05-2002, 01:01 PM
  #160
Old 02-05-2002, 01:19 PM
  #161
TPhalen's Avatar
Quick tip for the servo saver....
Use a spring off of the slipper assembly for an off road car. It's stronger and won't require you to tighten it all the way down....
TPhalen is offline
Old 02-05-2002, 03:52 PM
  #162
Default Front one-way
Does anybody know if the one-way unit from the TC3 will work in the NTC3? All the places that I've checked don't have the NTC3 one-way in stock, and I wanted to try one for this sunday's race.
SuperMugen is offline
Old 02-05-2002, 04:08 PM
  #163
Craig's Avatar
Thanks guys I will get it fix shortly.Does anyone know if the 32mm foam tires fit? I just put the Lola body on and it needs them to look right.
Tony-how is the car working I havent seen much info about how it is doing? Have you got a chance to run it?
Craig is offline
Old 02-05-2002, 06:58 PM
  #164
ernestf's Avatar
Default Re: Front one-way
the oneway until of TC3 can fit in NTC3, however, the oneway outdrive is much longer in NTC3 ...
ernestf is offline
Old 02-05-2002, 07:00 PM
  #165
ernestf's Avatar
can i have a look on how you fit lola body on ntc3 ? i am now running a PF CLK body with foam. so far, i use front 26mm and rear 30mm (with 1mm to 2mm shim in between the rear rims and drive hex). never try 32mm foam ...
ernestf is offline
