Old 10-07-2002, 03:45 PM   #1606
stefan's Avatar
Send a message via AIM to stefan
All of the GRP tires have a different rubber for the front tires (even if they show the same shore rating)
The rear rubber has more traction but wears faster.
stefan is offline   Reply With Quote
Old 10-07-2002, 07:23 PM   #1607
Originally posted by ME-student
i just tried this set up on Saturday, i was impressed by its performance. i expected it to have a lot of bottom end and less top end power since the header length is much longer. but bottom and top end power was as good as the dual chamber pipe. i only ran two laps and didnt get the temp. stupid rain....i will do more testing this coming weekend.
ME-student, did you do more testing on this? I'm interested in doing the same thing on my NTC3 and would like to know how it went. Are you happy with it's performance? The manifolds you used, were they 2 rear exhaust ones or 1 rear and 1 side?
madcat prime is offline   Reply With Quote
Old 10-08-2002, 01:09 AM   #1608
madcat prime: i use 2 rear exhaust headers, but side exhaust header should work too. the result was ok, because my centax clutch wasn't set right. but it did perform like the AE pipe, but alittle hotter. probably around 10-15 degree. i will do more testing this weekend..
i think this set up will be just as good.. or even better than the AE
pipe...
ME-student is offline   Reply With Quote
Old 10-08-2002, 05:03 PM   #1609
Send a message via ICQ to TooFNFast4U Send a message via AIM to TooFNFast4U
anyone know the stock needle settings for a fantom fr.15 slidcarb?
TooFNFast4U is offline   Reply With Quote
Old 10-09-2002, 12:30 AM   #1610
pipe...
Thanks ME-student. Update us on your further testing. I definitely will be doing this as soon as I order the parts needed. Would've tested myself but being in a country where I might be the only NTC3 running, it's hard.
Old 10-09-2002, 12:55 AM   #1611
madcat prime: where do you live?
Old 10-09-2002, 09:38 PM   #1612
glide 1's Avatar
Default Nova CX12 JP Modified
Hi Guys,
Does anyone know where i could get this engine? http://www.jpracing.com/blackengineE/blackE.htm
a link or any info would be appreciated, thanks
glide 1 is offline   Reply With Quote
Old 10-09-2002, 11:52 PM   #1613
I'm in New Zealand ME-student. Guys I know run V one R's so I'm on my own I guess.
Old 10-09-2002, 11:59 PM   #1614
Glide-1, which part of Cebu are you from? I too am from Cebu (lived in Mandaue) but now in New Zealand. Do you have an NTC3 as well? Where'd you get the kit? See you around.....Pit Senyor!
Old 10-10-2002, 07:43 PM   #1615
Francis M.'s Avatar
you could add a little toe to the rear and that should give
you more rear traction for rubber tires stick to 2 degrees camber or changing inserts if you thing you are overheating the tires
to quick
Francis M. is offline   Reply With Quote
Old 10-10-2002, 08:14 PM   #1616
kevink2's Avatar
Nice avatar dude!
kevink2 is offline   Reply With Quote
Old 10-10-2002, 08:33 PM   #1617
Francis M.'s Avatar
THANK FOR THE HELP KEVIN
Old 10-12-2002, 09:59 AM   #1618
JWF, where do you race? I live in fullerton and was looking for some more R/C tracks to go to.
SpeedyOB-4 is offline   Reply With Quote
Old 10-12-2002, 03:43 PM   #1619
Francis M.'s Avatar
i race at revalations in montclair most of the time.
i'm gonna start going to citrus college i heard there
is good competition down there also.
Old 10-14-2002, 04:44 AM   #1620
Default brakes
Hey guys, does the ntc3 stop real quick from full speed just like the Vone Rs? I've noticed they could quickly brake when they want to while my car slows down but keeps rolling before stopping. Is this normal?
