Old 09-25-2002, 08:40 AM   #1501
rcruv's Avatar
NTC3NUT > I'm guessing he wanted to reduce ackerman just a little bit, but wouldn't it too risky to do it when you race for an hour? I'm curious how he made it last for an hour. Was it just a ball end and nut or glued it?
Let us know after you tried it how it differs from stock position.
rcruv is offline   Reply With Quote
Old 09-25-2002, 02:55 PM   #1502
Send a message via AIM to Rifleman Send a message via Yahoo to Rifleman
Does anyone Know what kind of bumper Baker had o nhis car?
Rifleman is offline   Reply With Quote
Old 09-25-2002, 04:31 PM   #1503
NTC3NUT's Avatar
I'm sure he was using the factory bumper. I don't think you'll find too much aftermarket stuff on a factory drivers ride.
NTC3NUT is offline   Reply With Quote
Old 09-26-2002, 09:36 AM   #1504
Thanks, anotehr thing, does wnayone know which geas he was using?
Old 09-26-2002, 10:17 AM   #1505
SpeedTech's Avatar
Hi Guys,
Just want to let you guys know that we got a few more Kawahara NTC3 clutch in stock and also all the 2nd gear pinion gears as well. We also got a few more Zac Project large engine head for the .12 engines.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 09-26-2002, 10:34 AM   #1506
Registered User
OB42TC3's Avatar
The mod does reduce ackerman; I did the mod on my car after I saw that, and it doesn't look like it will affect durability too much, they're still very stout parts. I think the mod was probably done gain a little better turn-in. At high speeds less ackerman is needed, because the radius of the inside and outside tires is nearly identical, too much ackerman effect and the outside slip angle is not high enough and the inside slip angle is too high = less than ideal grip. My car started turning in better with reduced toe-out up front which is a change in the same direction as reduced ackerman, so I figured the next step would be to go to less ackerman (most of the other competition sedans use the single servo setup and less ackerman as well). One thing about the spacers for the rack mod is that it would probably reduce maximum steer angle because the ball cup from the tie rod will hit the steer post sooner.
OB42TC3 is offline   Reply With Quote
Old 09-26-2002, 02:30 PM   #1507
NTC3NUT's Avatar
Rifleman, If you take a close look at the pictures I believe you'll see 27/21 pinions, and 48/54 spurs on all the cars. Associated has Pavidis' set-up sheet posted on their site now.
http://www.rc10.com/racerhub/setup/r...2_worldcup.pdf
Old 09-26-2002, 03:57 PM   #1508
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I am talking to a Machinist in my neigborhood who is going to get me a price quote on M3.5 X .6 Left Handed nuts for the Rear Link mod. If you are interested e-mail me at [email protected] and I will keep you informed on how much it will cost. I think I may have to buy 500 nuts or something like that. We will see.
Let me know.
Mike Webb
[email protected]
mike_Webb is offline   Reply With Quote
Old 09-26-2002, 08:02 PM   #1509
InitialD's Avatar
Wooow, 6 tooth jump... No wonder they need the makers of the engine to be there to tune their engines right...
Old 09-26-2002, 09:48 PM   #1510
Registered User
OB42TC3's Avatar
That's pretty much the only gears you will see used at Cincy.
Old 09-26-2002, 09:54 PM   #1511
Francis M.'s Avatar
that gearing is preaty much the gearing all the locals
at crystal park and revelations race way use here in
socal.
Francis M. is offline   Reply With Quote
Old 09-26-2002, 10:02 PM   #1512
Default Factory NTC3
Any rumors that AE will release this?
elnitro is offline   Reply With Quote
Old 09-26-2002, 10:03 PM   #1513
NTC3NUT's Avatar
I use 21/27-54/48, or 20/26-54/48. Always a 6 tooth split though.
Old 09-26-2002, 10:16 PM   #1514
Registered User
OB42TC3's Avatar
Default Re: Factory NTC3
I believe they are saying one is on the way. That's not really a reason to wait though. IMHO the car needs nothing but foam tires to race. I used to think the sway bars were a must-have, but lately I have been having better setups by using the ~$5 buds sway bar up front, or none at all. It will be interesting to see what they throw in though, like if you get all the gears, the carbon upper deck, titanium PBs, etc. All the lightweight stuff really doesn't do anything for you though because the car is right at the Min weight out of the box.
Old 09-27-2002, 03:42 AM   #1515
Number 11's Avatar
Default One way
Can someone point me in the direction of where I can find more info on one-ways? I see you guys talking about them all the time and it sounds like they are beneficial. What I would like to know is what is the purpose of a one-way and is it only used for a car that is running foam tires? Does anyone have a picture of what a one-way looks like?
Number 11 is offline   Reply With Quote
