Old 07-09-2008, 02:08 PM   #1
Default NEED INFERNO GT SET UP
please help looking for a set up sheet that some has used and works well for a high grip track please let me know
infernoman2008 is offline   Reply With Quote
Old 07-09-2008, 02:17 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Being such a new class it may be hard to find set-ups. First of all run foam tires if allowed. Secondly, for a high bite track you will probably want to find some stiffer springs and sway bars and go up on your shock oil.
What is the car doing and what do you need it to do better?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-09-2008, 02:28 PM   #3
when turning into corner's the rear end wants to come around causing the car to spin out i hardly even have to turn the wheel to have the car do this, i am running frt and rear sway bars hard , twister tires, what kind of set up do you have on your car also loking for a good ride height to have for frt and rear thanks
Old 07-09-2008, 03:04 PM   #4
Suspended
Default ride hight
on a smooth track about 6mm
airtraficontr is offline   Reply With Quote
Old 07-09-2008, 03:09 PM   #5
Suspended
dirt cars on asphalt for what reason i dont see the point? dirt is cheap cheers dan
Old 07-09-2008, 03:51 PM   #6
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
thank you for that wonderful insight next time i have a dirt car I'll keep it in mind unfortunitly the Inferno GT is marketed and sold as an on road car not an off road car the entire layout has been redesigned to be an on road car. not a buggy with slicks. when setup properly it does handel quite well granted it's no touring car but it gets around very well
do a search for jspeed he posted up a link to his setup in the other IGT thread it is a pretty good baseline although you will need to fine tune it for your track it is a good starting point.
regg151 is offline   Reply With Quote
Old 07-09-2008, 04:23 PM   #7
Zootcapri's Avatar
Pop off the rear sway and move the top rear shock position to the innermost position. You should have 9-10mm ride height.
There is a thread that already has a lot of setup information.
Zootcapri is offline   Reply With Quote
Old 07-09-2008, 06:56 PM   #8
rpespo's Avatar
Try this...
http://infernogt.proboards102.com/in...lay&thread=690
Rich E
Inferno GT1 / LRP Z.28R / Ipanema 2-speed / Dragon Racing / Max Velocity
Monster GT / LRP ZR.30
Spektrum DX3R
rpespo is offline   Reply With Quote
Old 07-09-2008, 08:01 PM   #9
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Droop settings
Hey , these cars hve droop screws, these screws will help with weight transfer.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 07-09-2008, 08:08 PM   #10
Default Touring Car
Yes ,its just like a touring car just bigger, you hve droop settings ,swaybars,springs,different shock postions,foam tires.I cant wait to get the GT2.
RoninRc.com
Basher BT-4
Old 07-09-2008, 08:10 PM   #11
HUMMERH3's Avatar
Default here
Go here youll find everything you need for the GT,look for Jspeed..
http://infernogt.proboards102.com/index.cgi
KYOSHO 777 WC KYOSHO GT
RB///
SIRIO
SPONSORS RIO DENTAL IPANEMA RACING PROD.
HUMMERH3 is offline   Reply With Quote
MBX5, Inferno 7.5, Inferno ST US, Revo, RC10T4 rstnboy R/C Items: For Sale/Trade 7 09-20-2007 08:20 PM
Mini Inferno & Inferno 09 -- post anything here Frost Malaysian R/C Racers 19 09-07-2007 09:06 PM
Largest Kyosho Mini Inferno/half 8 sale all with brushless 2 infernos, 1 inferno ST nobike R/C Items: For Sale/Trade 114 03-27-2007 10:00 AM
wtb rc18t, mini inferno, min inferno st brushless muzzler R/C Items: Wanted to Buy 4 03-02-2007 09:04 AM
KM Concept Mini Inferno/Inferno ST Graphite Conversion kit (blue) SpeedTech Micro and Mini Scales 5 09-06-2006 09:02 PM
