Old 08-16-2003, 10:11 PM   #1
Default NTC3 stainless steel screw set better than stock?
i know the stock screws strip out alot and was wondering if these are tougher.
Columbus is offline   Reply With Quote
Old 08-17-2003, 03:33 AM   #2
me43's Avatar
stainless steel is softer than regular steel
so your only other option would be titanium
me43 is offline   Reply With Quote
Old 08-17-2003, 10:10 AM   #3
the stock ones are steel?
Old 08-17-2003, 10:00 PM   #4
sbmon's Avatar
i put the racers edge ones on my back up ntc3 and
i think the stainless screws are definitely softer than the original
associated screws you get withe the kit
sbmon is offline   Reply With Quote
Old 08-17-2003, 11:07 PM   #5
me43's Avatar
i think so
either that or there are a really low grade stainless
cuz one of mines rusted
Old 08-19-2003, 05:48 AM   #6
I have the SS screw kit from RCScrewz. These guys are real professionals, they'll take good care of you! I think the SS screws are much better than the stock screws. I had to do some clutch work, and stripped all 4 engine mount screws. After upgrading to the SS, they don't strip at all. Also, the SS screws seem to thread MUCH better into the plastic than the stockers. Hope that helps!
Tom
Nuke is offline   Reply With Quote
Old 08-20-2003, 08:16 AM   #7
tIANcI's Avatar
Default NTC3 Screws
There is no need to waste your money and time with SS screws, they are no better. My advice is for you to purchase METRIC size screws, I know it might be difficult in the US.
The screws are called M3 screws (3mm shafts), the screws are for 2 mm heads. All you have to do it to get the right lenght, get a little longer ones for the diff cases (x4). They will help your screw stripping problem.
This however will not work for screws that are used into metal.
tIANcI is offline   Reply With Quote
Old 09-05-2003, 02:53 PM   #8
mtx3racer869's Avatar
Default yea
i jsut put the RCscrewz stainless kit on mine and they look good and havent stripped yet. plus u dont want to use titanium on aluminum it will weld together if i gets hot like on te bottom of ur chassis
mtx3racer869 is offline   Reply With Quote
Stainless Steel Screw Set tamidion Monster Trucks 6 07-03-2007 10:56 PM
Stainless Steel Screw Kit for T4? jamescam Electric Off-Road 7 08-22-2005 07:50 PM
Stainless steel screw kit for CRC??? Michal101 Electric On-Road 3 01-25-2005 11:17 PM
Stainless Steel Screw Kits for the HPI Pro 3 capricess R/C Items: For Sale/Trade 1 01-22-2003 01:17 PM
